FTIR:What is the proper instrument for liquid samples?
  • Thread starter Thread starter source2
    Instrument Liquid
The discussion revolves around the appropriate instruments and techniques for performing FTIR measurements on liquid samples, particularly in a vacuum environment. Participants share their experiences and inquire about the best practices and equipment for such measurements.
  • Exploratory, Technical explanation, Debate/contested
  • One participant seeks advice on suitable holders or instruments for measuring liquid samples under vacuum, noting issues with transmission at certain wavelengths.
  • Another participant describes using small transparent pucks made of inorganic salt for liquid samples, which fit into a demountable cell for FTIR analysis.
  • A participant shares past experience with NaCl and CaF2 cell windows, highlighting differences in IR absorption patterns and cleaning challenges associated with these materials.
  • There is mention of a technique involving syringe injection of liquid samples and cleaning cells between spectra using air, which was effective for volatile liquids.
  • A question is raised about the viability of measuring in ATR mode instead of using traditional cells, with an inquiry into the spectrum quality achievable with ATR.
  • One participant notes that ATR is best suited for neat or concentrated samples but expresses uncertainty about the availability of ATR fixtures for vacuum use.
Participants express differing views on the best methods and instruments for FTIR measurements of liquid samples, indicating that no consensus has been reached regarding the optimal approach.
Participants mention specific materials and techniques that may have limitations, such as the hygroscopic nature of NaCl and the need for special cleaning methods, but these aspects remain unresolved in the discussion.
Researchers and practitioners in the fields of spectroscopy, chemistry, and materials science who are interested in FTIR techniques for liquid samples, particularly in vacuum conditions.
source2
Hi everyone;
I read some of FTIR threads in forums and they were at the different parts of forums so I decided that it's the best place for this question. But if I am wrong please move the thread.
I'm new for FTIR measurements. First of all I want to say that I'm doing this kind of measurements only for scientific purpose.
I use an FTIR machine which operates under vacuum. I tried a holder/instrument but it is not useful due to the fact that it has no transmission at some wavelengths.
What kind of holder/instrument are you using to measure liquid samples under vacuum?
Where can I find these holders/instruments?
Thanks for your help.
I've not used the FTIR at work but as far as I see the kit used it comes with some form of small transparent pucks that are for the purpose. Can't say what they are made of, they come with the kit. I think it is some form of inorganic salt. You put a drop of liquid on one, then put the other on top. You get a film of the liquid between the two pucks and they [are made to the right size to] fit in a demountable cell that slots into the analysing channel of the machine.
Edit; something like... http://www.perkinelmer.com/Catalog/...able Cell and Cell Parts for 1600 Series FTIR
..windows for same; http://www.perkinelmer.com/Catalog/Family/ID/Circular Demountable Cell Windows for 1600 Series FTIR
I'm reading one of the links. Thank you for your help. I really appreciate it.
I worked with an IR spectroscopy group 12 years ago and the cell windows were NaCl and CaF2. We ran spectra with both because IR absorption patterns were different for the two salts. The windows are hard to clean. The NaCl especially tends to absorb water and requires a special polishing kit. Also, we used to inject liquid samples with a syringe and clean the cells between spectra by blowing air through them, a technique that worked in our case because the liquids used (bromobenzene derivatives) were highly volatile. So, in a nutshell, you can expect to need different cell windows. I used the CaF2 whenever possible because it was less hygroscopic and then used NaCl to cover wavelengths absorbed by the CaF2 window.
Thank you for the answer and also for sharing your experience. It helped a lot.
I have one more question,
Is it a good choice to measure in ATR mode instead of using these cells?
Could I get same spectrum quality with this method? I mean in ATR mode.
Thermo Scientific has one in their accessory catalog. Item number 0030-101.
ATR is best for neat or very concentrated samples. I've never seen an ATR fixture for vacuum though.
