How Can You Prove an Atlas Is Maximal?
  • Context: Graduate
  • Thread starter Thread starter Identity
    Atlas
The discussion revolves around the concept of maximal atlases in differential geometry, specifically how to prove that a given atlas is maximal. Participants explore the implications of having a maximal atlas versus merely a compatible atlas that covers a manifold, and the necessity of proving maximality in the context of differentiable structures.
  • One participant questions how to show that an atlas is maximal, noting the challenge of proving compatibility with an arbitrary chart not included in the atlas.
  • Another participant suggests that having any compatible atlas that covers the manifold suffices for studying the manifold, implying that maximality may not be essential.
  • A third participant points out that many texts define a manifold in terms of having a maximal atlas, indicating its importance in formal definitions.
  • Some participants argue that proving maximality is not trivial and that while a maximal atlas exists by definition if at least one atlas is present, finding it can be complex.
  • One participant mentions that the condition of maximality helps avoid the need to define equivalence of atlases, which they consider relatively unimportant.
  • Another participant highlights the convenience of working with a maximal atlas for various operations, such as restricting domains and using bump functions.
  • It is noted that when establishing an atlas, the goal is to cover the manifold with as few charts as possible, and once sufficient charts are established, one can include all compatible charts without needing to verify maximality for each specific case.
Participants express differing views on the necessity and importance of proving that an atlas is maximal. While some see it as a formal requirement, others argue that it may not be crucial for practical purposes.
Participants acknowledge that the discussion involves assumptions about the definitions of atlases and differentiable structures, and the implications of maximality may depend on the context of the discussion.
Identity
I've been looking in various books in differential geometry, and usually when they show that a smooth manifold has a differentiable structure, they just show that the atlas is [itex]C^\infty[/itex] compatible, and forget about showing it is maximal.
Which got me thinking. Given an atlas, how DOES one show that it is maximal?
After all, you need to show that a completely arbitrary chart that is not in the atlas cannot be compatible with the atlas. But how do you show compatibility if you don't even know what this chart is? And isn't this an important step in showing that a manifold has a differentiable structure?
i don't know the answer, but i cannot think of any situation where i have ever cared about the answer to this question. i.e. all you need is an atlas that covers the manifold. then you can study the manifold. of course every question is interesting, so maybe i can think more about it. but actually all you want is any compatible atlas that covers the manifold. then you just enlarge it to a maximal one if you wish. i.e. a differentiable structure exists if and only if an atlas exists that covers. then a maximal one also exists.
Thanks, yeah I also thought that having a maximal atlas wouldn't be that important as long as you had compatible charts. But anyway every text I read has it as a condition, which I thought was interesting:
"A (smooth) differential manifold [itex]M^m[/itex] of dimension m is a topological manifold of dimension m together with a maximal (smooth) atlas on it." - An Introduction to Differential Manifolds, Barden, Thomas
"A maximal [itex]C^\infty[/itex] atlas [itex]A[/itex] on [itex]M[/itex] is called a smooth structure on [itex]M[/itex]" - Differentiable Manifolds, Conlon
"A smooth or [itex]C^\infty[/itex] manifold is a topological manifold [itex]M[/itex] together with a maximal atlas." - An Introduction to Manifolds, Tu
A maximal atlas is also the third condition for a differentiable structure (after covering and compatible charts) in my lecture notes.
assume that it isn't maximal. so you have another mapping on an object with differentiable structure. but wait! you didn't add it to the collection! therefore maximal.
Haha, I like this one.
I don't think it's trivial, given some atlas of the manifold, to prove that it's maximal. However, as long as my manifold at least admits one atlas (one set of charts which are compatible and cover the whole manifold), then the existence of a maximal atlas is true by definition.
Finding it may be another issue.
it is just a condition used in order to avoid having to define equivalence of atlases. I.e. if you don';t make the atlases maximal in your definition then you have to say when two atlases are equivalent, which is actually pretty easy and useful, so I still think it rather unimportant.
Another reason it's nice to work in a maximal atlas is that it's convenient to be able to restrict domains, do things with bump functions, straighten out tangent vectors, etc., without constantly having to say whether the resulting chart is in the atlas.
good points. it depends on what you are doing. when trying to show you have an atlas you want to produce as few charts as possible, just enough to cover the manifold. then when you have enough, you just say "now throw in all compatible charts". of course whenever you use one of those, you still have to show it is compatible with the ones you started from. but you essentially never have to answer the question: is a particular specific atlas maximal?
e.g. if working with a sphere, just put say the 6 obvious coordinate hemispheres on it and then you have an atlas. now use the fact that all open subsets of charts are also compatible charts, and you have pretty much all the specific charts you need.
  • · Replies 50 ·
  • · Replies 19 ·
  • · Replies 16 ·
