Velocity of falling object from different heights using DE
The discussion revolves around finding the velocity of a 180 lb object falling from various heights (5 ft, 15 ft, 25 ft, and 45 ft) while considering the effects of drag. The problem involves the differential equation f=mg-Kv², where g is the acceleration due to gravity, m is the mass, and v is the velocity. The terminal velocity is given as 120 mph.
  • Mixed
  • Participants explore the use of the differential equation m(dv/dt)=mg-Kv² and discuss methods such as separation of variables and integration techniques. Some express uncertainty about how to incorporate drag into their calculations and whether height and time can be interchanged. Others question the correctness of their integration steps and the implications of initial conditions.
There is an ongoing exploration of different integration methods and their implications for the problem. Some participants have suggested alternative approaches and clarified the relationship between variables, while others are still seeking confirmation of their reasoning and calculations.
Participants note the complexity of the problem due to the drag force and the need to account for different heights, which may require distinct solutions for each height. There is also mention of the initial conditions affecting the integration results.
sunnyceej
Find the velocity of a 180 lb object falling from a state of rest from 5 ft, 15 ft, 25 ft, and 45 ft
using the formula f=mg-Kv2, where g is the acceleration due to gravity, m the mass of the body, v its velocity. The terminal velocity is 120mph.
I tried using f=m(dv/dt) so m(dv/dt)=mg-Kv2, since mg = 180 and I know terminal velocity, I converted 120mph to fps and got k=1.614E-6. Using g=32fps2, I got m=5.6. Then dividing by m, I get dv/dx=32 -1.614E-6v^2/5.6.
I've used Kinematic equations to get times at all of the heights, and from there I can get velocity, but none of this considers the drag, or uses the equation I was given.
I have no idea how to use the equation I was given to get the velocity for the different heights or times. The equation doesn't seem separable, or like I could use an integrating factor. I've tired Bernoulli's method too. None of them seem to help solve the problem.
Please help!
Please help!
Of course it's separable.
m(dv/dt)=mg-Kv2 → [itex]\displaystyle \frac{dv}{mg-Kv^2}=\frac{dt}{m}\,.[/itex]
If mg, and k =1, then I know I would get arctanh v. It's been a while since calc, so I'm not sure what to do with the constants.
My other thought is to go the natural log route:
ln(mg-kv2)=t/m+c
then raising both sides to e:
mg-kv2=cet/m
using v(0)=0 as my initial condition, c=180, and plugging in other values (mentioned in first post) gives me
180-1.614E-6v2=180et/5.6
Am I on the right track?
If so, this gives me time, do I plug in my times from using the Kinematic equations to find the different velocities? My only hesitation here is that the times I found don't take into account the drag force. So, how do I account for the different heights? Or are the height and time interchangeable (can I replace t with h)?
After thinking more, differentiating with respect to height would not change my equation (except from t to h), but my initial value would be different for each height. So I would have a different specific solution for each height.
I'm still curious as to whether I solved the equation correctly though.
ln(mg-kv2)=t/m+c
mg-kv2=cet/m
The constants can be taken care of through substitution.
While the integration can result in an arctanh function, it's fairly straight forward to express it as a sum of logarithms.
To get the integrand into workable form:
[itex]\displaystyle \frac{1}{mg-Kv^2}=\frac{1}{\displaystyle mg\left(1-\frac{K}{mg}v^2\right)}=\frac{1}{\displaystyle mg\left(1-\left(\sqrt{\frac{K}{mg}}v\right)^2\right)}[/itex]​
[itex]\displaystyle \text{Let }u=\sqrt{\frac{K}{mg}}\,v\,,\text{ then }du=\sqrt{\frac{K}{mg}}\ dv\,.[/itex]
The integral then becomes:
[itex]\displaystyle \int \frac{dv}{mg-Kv^2}= \sqrt{\frac{1}{Kmg}}\ \int\frac{du}{1-u^2}\,.[/itex]​
Notice that [itex]\displaystyle\frac{1}{1-u^2}=\frac{1}{2(1+u)}+\frac{1}{2(1-u)}\ .[/itex]
So this gives me
[itex]\int\frac{dv}{mg-kv^{2}}[/itex] = [itex]\int\frac{dt}{m}[/itex]
with u substitution:
[itex]\sqrt{\frac{k}{mg}v}[/itex]([itex]\frac{1}{2}[/itex][itex]\int\frac{du}{1+u}[/itex] + [itex]\frac{1}{2}[/itex][itex]\int\frac{du}{1-u}[/itex]) = [itex]\int\frac{dt}{m}[/itex]
becomes
[itex]\sqrt{\frac{k}{mg}v}(\frac{1}{2}[/itex]ln[itex]\left|1+u\right|[/itex] + [itex]\frac{1}{2}[/itex]ln[itex]\left|1-u\right|[/itex]) = [itex]\frac{t}{m}[/itex]+c
then
[itex]\sqrt{\frac{k}{mg}v}(ln\sqrt{1+u}[/itex]+ln[itex]\sqrt{1-u}[/itex])= [itex]\frac{t}{m}[/itex]+c
[itex]\sqrt{\frac{k}{mg}v}(ln\sqrt{1-u^{2}}[/itex])=[itex]\frac{t}{m}[/itex]+c
and finally sub back in for u to get:
[itex]\sqrt{\frac{k}{mg}v}*ln\sqrt{1-\frac{k}{mg}v^{2}}[/itex]=[itex]\frac{t}{m}[/itex]+c
Is this right?
sunnyceej said:
So this gives me
becomes
That should be a minus sign.
[itex]\displaystyle\sqrt{\frac{k}{mg}v}(\frac{1}{2}[/itex]ln[itex]\left|1+u\right|[/itex] [itex]\frac{1}{2}[/itex]ln[itex]\left|1-u\right|[/itex]) = [itex]\frac{t}{m}[/itex]+c
Ok. I see why. I also now see why I should have 1/[itex]\sqrt{kmg}[/itex] in front instead of what I had.
So I now have [itex]\frac{1}{\sqrt{kmg}}[/itex][itex]\left(ln\sqrt{1+u}-ln\sqrt{1-u}\right)[/itex]=[itex]\frac{t}{m}+c[/itex]
[itex]\left(ln\sqrt{1+u}-ln\sqrt{1-u}\right)[/itex]=[itex]\frac{1}{\sqrt{kmg}}[/itex][itex]\left(\frac{t}{m}+c\right)[/itex]
e[itex]^{ln\sqrt{1+u}}[/itex]e[itex]^{-ln\sqrt{1-u}}[/itex]=ce[itex]^{\frac{t\sqrt{kmg}}{m}}[/itex]
e[itex]^{ln\sqrt{1+\sqrt{\frac{k}{mg}}v}}[/itex]e[itex]^{-ln\sqrt{1-\sqrt{\frac{k}{mg}}v}}[/itex]=ce[itex]^{\frac{t\sqrt{kmg}}{m}}[/itex]
With the initial condition: v(0)=0, c=1 and
e[itex]^{ln\sqrt{1+\sqrt{\frac{k}{mg}v}}}[/itex]e[itex]^{-ln\sqrt{1+\sqrt{\frac{k}{mg}v}}}[/itex]=e[itex]^{\frac{t\sqrt{kmg}}{m}}[/itex]
This gives me velocity if I know time, but I know height instead. How do I figure that into my problem?
OK.
Let's go back & start from scratch.
You have:
[itex]\displaystyle m(dv/dt)=mg-Kv^2\,.[/itex]​
If v is regarded to be a function of x rather than a function of t, use the chain rule.
[itex]\displaystyle \frac{dv}{dt}=\frac{dv}{dx}\frac{dx}{dt}=v\frac{dv}{dx}[/itex]
So your differential equation becomes:
[itex]\displaystyle mv\frac{dv}{dx}=mg-Kv^2\,.[/itex]​
After separation of variables, this looks easier to integrate than the initial differential equation.
Thanks. That is a lot easier to integrate. After integrating, I get
v2=[itex]\frac{mg}{k}[/itex]-ce[itex]^{\frac{2kx}{m}}[/itex]
with initial value V(0)=0, I get c=[itex]\frac{mg}{k}[/itex]
so v=[itex]\sqrt{\frac{mg}{k}\left(1-e^{\frac{2kx}{m}}\right)}[/itex]
x would have to represent the height fallen, and it will have to be negative, otherwise I get an imaginary number.
Is this right?
Thanks for all your help SammyS!
Is this right?
Sorry, I didn't get to this yesterday !
I got a similar, but a little different, result.
[itex]\displaystyle v^2=\frac{m}{K}\left(g-Ce^{-(2K/m)x}\right)\,,[/itex] with C = g .
This is the same as what you got except for the sign of the exponent.
I reworked the problem and got a negative exponent as well.
Thanks again for all your help!
  • · Replies 18 ·
