What physics causes this mirror reflection?
The discussion revolves around the physics behind a mirror screen protector for an iPad, focusing on its reflectivity, transmission properties, and the underlying material structure. Participants explore the optical effects observed, including diffraction and polarization, as well as the implications for practical use.
  • One participant notes the mirror screen protector has a high reflectivity of around 95% and a transmission of approximately 95%, raising questions about the validity of these claims due to the sum exceeding 100%.
  • Another participant suggests that materials with layers of different refractive indices can selectively transmit or reflect wavelengths, referencing the dichroic effect.
  • A participant expresses skepticism about the stated reflectivity, estimating it to be much lower based on visual assessment from a video.
  • Concerns are raised about the practicality of the screen protector, particularly regarding its effect on screen brightness and usability in bright conditions.
  • One participant shares their own measurements, reporting reflectivity of less than 50% and transmission around 80%, aligning more closely with the principle that the sum of reflectivity and transmission should not exceed 100%.
  • Another participant proposes that the material may consist of multiple layers with varying refractive indices and references a scientific paper for further exploration of this idea.
  • Suggestions for improving measurement techniques at home are offered, including using a camera to analyze pixel brightness values for more accurate reflectivity and transmission assessments.
Participants express differing views on the accuracy of the reflectivity and transmission values, with no consensus reached on the actual performance of the screen protector. The discussion remains unresolved regarding the specific optical properties and their implications.
Participants mention various measurement techniques and assumptions about the optical properties, but no definitive methods or results are established. The discussion reflects uncertainty regarding the material's behavior and the accuracy of initial claims.
cahillj
Hi,
I just bought an iPad mirror screen protector and I'm really puzzled about how it works.
You can see a video of the protector here
The mirror quality is very good, of the order of 95% reflectivity, and it's not a metalized film as transmission is ~95%
You can see in the video that there is a diffraction type of coloring at grazing angles.
If I rotate it in front of an LCD screen there is a weak polarization effect.
The manufacturer claims it comprises three layers but doesn't explain the physics.
What is going on?
Thanks!
Science news on Phys.org
if a material is made up of layers of different refractive index it will selectively transmit or reflect a range of wavelengths - lookup dichroic effect in a search engine
Welcome to Physics Forums cahillj :smile:
cahillj said:
Hi,
I'm not sure (yet) what is going on, but these are contradictory statements. Reflectivity and transmission cannot add up to more than 100%. Can you clarify how you got these values? Was it just an "eyeball estimate"?
From the video, it looks to me like reflectivity is a lot less than 95%. I could believe 10%, but that is just an eyeball estimate on my part, and from cheap video footage at that.
Anything like this must have equal transmissions and reflections in either direction. The thing is useless if it reduces the screen brightness by more than a few % and there is an 'assumed' benefit, I guess in having a mirror finish in that you can eliminate annoying individual external light sources by tilting the screen. It could be very good in some circs but in very bright light, you can't afford to chuck away the brightness from the display.
The screen in the movie is not highly reflective - it's just very well polished.
It could be argued that the screen should be lenticular for personal viewing as it channels all the light towards the viewer. It's not for famliy watching.
Hi,
Thanks to all for your comments
Redbelly98 - a good comment about the sum of intensities.
I crudely measured reflectivity at less than 50% with transmission around 80%, much closer to "sum not greater than 100%"
Crudely = DSLR+digitally generated image of bands of grey which I also printed+mirror+iPad part covered by mirror +different ASA+ImageJ
Any better suggestions to make measurements at home?
Sophiecentaur - as a screen protector this stuff is terrible! I wouldn't recommend it BUT it is an interesting material. Next time you are on Amazon buy a cheap sample <$5
Sambristol - I think you got the closest, I'm thinking it is made up of materials of many layers of different RI and I've just found this paper, which I intend to read through.
Giant Birefringent Optics in Multilayer Polymer Mirrors
Science 31 March 2000:
Vol. 287 no. 5462 pp. 2451-2456
this link might work http://www.sciencemag.org/content/287/5462/2451.full
fun, fun, fun!
cahillj said:
Hi,
Using a camera is a good idea. But I would look at the actual pixel brightness values in the images -- try to take a rough average over some area of the image. Camera settings (aperture, exposure time) should be such that the reference image (looking directly at the light source) has pixel brightness less than the full 255. If the brightness is 255, you are saturating the sensor and you'll need to reduce the aperture or exposure time until it is less than 255.
EDIT added: make sure your reflection and transmission measurements are both as close to normal incidence as possible. Tricky to do for reflection, since at normal incidence the camera is blocking the light source, but try to get as close to normal incidence as you can.
  • · Replies 19 ·
9K
