Calculate 3D Fourier Transform for f(x) = (1 + |x|2)-1 on ℝ3
The discussion revolves around calculating the Fourier transform of the function f(x) = (1 + |x|²)⁻¹ in three-dimensional space. Participants are exploring the setup of the integral and the implications of the function's properties on the transform.
  • Participants discuss the setup of the Fourier transform integral and consider the simplification by aligning the vector k along the z-axis. There are attempts to evaluate the resulting integral and questions about its integrability. Some participants express uncertainty regarding the aesthetics of the outcome based on their calculations.
The discussion is ongoing, with participants providing insights and suggestions for simplifying the integral. There is acknowledgment of the challenges involved in evaluating the integral, and some guidance is offered regarding the use of residues and contour integration techniques.
There are mentions of potential poles in the integral and the need to consider the behavior of the function in different half-planes. Participants also note the original poster's unfamiliarity with LaTeX formatting, which has been addressed in the discussion.
Ansatz7
Calculate the Fourier transform of f(x) = (1 + |x|2)-1, x[itex]\in[/itex]ℝ3
The attempt at a solution
As far as I can tell, the integral we are supposed to set up is:
Mod note: Fixed your equation. You don't want to mix equation-writing methods. Just stick to LaTeX.
$$\int \frac{e^{-2\pi i (\vec{k}\cdot\vec{x})}}{1+|\vec{x}|^2}dV = \int \frac{e^{-2\pi i r(k_1\sin\theta\cos\phi + k_2 \sin\theta\sin\phi + k_3\cos\theta)}}{1+r^2} r^2\sin\theta\,d\theta\,d\phi\,dr$$but I have no idea how to perform this integral. Any ideas appreciated! (Also, sorry about the fractions - I have no idea why they aren't working because I have no tex experience).
The first step is to use that your f(x) doesn't depend on the direction of the vector x. So the Fourier transform won't depend on the direction of k. So you can choose a k that points along the z-axis. That simplifies thing a lot.
*facepalm* Of course, that at least makes the angular part of the integral simple. After the angular integral I ended up with:
$$\frac{2}{k}\int \frac{r\sin2\pi kr}{1+r^2}\,dr$$
I don't think this is integrable, but that makes sense based on the way the question was posed.I think it ought to be square integrable though. I tried to compute this using residues - I was hoping to get something analogous to the 1D Fourier transform
$$f(x) = \frac{1}{1 + x^2},
\hat{f}(k) = e^{-2\pi x|k|}$$
but from the look of the residue I have so far it doesn't seem like it will be so aesthetically pleasing. At any rate, thanks for your help, and thanks vela for editing my equation. I've never used LaTex so I was guessing.
I'm not checking the details here, so I hope you are keeping track of all of the signs and factors. But that looks integrable to me. There are poles at i and -i. You'll have to split the sin up into exponentials so you can decide which half-plane to close the contours in, but it looks routine to me.
Deleted
