Integration of multiple variables
The problem involves finding the volume of a solid under the plane defined by the equation x − 2y + z = 8 and above a specific region bounded by the curves x + y = 1 and x² + y = 1. Participants are discussing their attempts to set up the integral for this volume calculation.
  • Exploratory, Assumption checking, Mathematical reasoning
  • The original poster attempts to set up a double integral but questions whether their setup is correct after receiving a different answer from software. Other participants confirm their own calculations yield the same result, leading to discussions about potential errors in the setup or interpretation of the problem.
Participants are actively engaging with each other's reasoning, identifying errors in their calculations, and exploring the implications of these errors. There is a recognition of similar mistakes among participants, but no consensus on the correct approach has been reached yet.
Participants express frustration with the software's output and question the reliability of the answers provided. There is also a focus on the specific expressions used in the integration process, indicating a need for clarity on the correct formulation of the problem.
ElijahRockers
Find the volume of the given solid.
Under the plane x − 2y + z = 8 and above the region bounded by x + y = 1 and x2 + y = 1
Here's how I set it up.
[itex]\int^1_0 \int^{1-x^2}_{1-x} (8-x+2y) dydx[/itex]
When I do the math, I get 21/20. I have gone several different routes using a calculator and I keep getting that answer. The software tells me the answer is 29/20.
So am I setting it up wrong?
For what it's worth, I get 21/20 as well.
Well, I copied and pasted the question directly from the software this time. Stupid software.
Well, assuming we are right, I doubt the software figured out the answer. Somebody told it what the answer should be. They are to blame.
Hmm I found an error in my work. The anti derivative of 8-x+2y is 8x-xy+y^2.
I had 8x-xy-y^2.
I had 8x-xy-y^2.
I think it's 8y-xy-y^2. Are you changing your answer? I'm not.
But if x-2y+z=8, then z=8-x+2y dz/dy = 8y -xy +y^2. I haven't gone through the problem, I did a similar one with different numbers and got it right
You are integrating z, not differentiating it. I thought you did go through it and got 21/20?? I'm not sure where you are going with this. I think you did it right the first time.
Oh yeah, sorry, by dz/dy i mean the anti derivative.
And yes, i got 21/20 when i used 8x-xy-y^2. I noticed my error, but by that time had already gotten the question right with a different set of values.
I posted my error here just incase you were wondering, and to see if, by some bizarre one in a million coincidence, you made the same exact error I did. (not likely, especially considering you are probably much more careful than I am)
Wow. Apparently I'm not much more careful than you. I made a completely different error. I integrated z=8-x-2y instead of z=8-x+2y and got 21/20. Figured since I got the same as you did, no need to double check. Oooops. Yeah, the odds are pretty low for this to happen.
...Actually, the odds drop drastically when we consider that you actually didn't make a completely different error, but you made the same exact error I did, completely separately from me. Look at the post where I mentioned my error.
Ok, yeah. I get you, it's wasn't the 8x instead of the 8y, it was the sign on the 2y. That does cut the odds.
  • · Replies 34 ·
  • · Replies 19 ·
