- 9,563
- 2,682
Spin-Analyser said:It's old light from outside the horizon coming at you from inside the horizon of light that hasn't reached the horizon yet?
I give up. I write English, you twist into word soup.
The discussion centers around the behavior of gravitational acceleration (g) near a simple (non-rotating, uncharged) black hole, specifically in relation to its event horizon and singularity. Participants explore theoretical implications, mathematical interpretations, and the applicability of Newtonian physics in this context.
Participants express multiple competing views regarding the behavior of gravity near a black hole, particularly concerning the event horizon and singularity. The discussion remains unresolved, with no consensus reached on several key points.
Participants note that the discussion involves complex mathematical concepts and varying interpretations of gravitational behavior, which may depend on specific definitions and coordinate systems.
No, it's old light from outside the horizon that has never been inside the horizon.Spin-Analyser said:It's old light from outside the horizon coming at you from inside the horizon of light that hasn't reached the horizon yet?
Sorry but I cannot agree with this.DrGreg said:If you and your partner are both falling into the black hole, then from your point of view, you and your partner are stationary and the event horizon is rushing towards you at the speed of light. You see your partner 10 feet in front of you at all times.
Passionflower said:Sorry but I cannot agree with this.
I think you are forgetting the tidal forces between them.
As you approach you see objects in front of you crossing the horizon, and you're seeing light from the other side of the event horizon. When you move away the light from previous observers moves back across the event horizon. So what if you stop one plank length away from the horizon and the one in front of you never reached the horizon either? The event horizon is no longer in one place. If you moved alongside and hovered next to the one in front of you then you would still be outside the horizon. It doesn't work. The event horizon must be moving inwards at c, not outwards.DrGreg said:No, it's old light from outside the horizon that has never been inside the horizon.
If you and your partner are both falling into the black hole, then from your point of view, you and your partner are stationary and the event horizon is rushing towards you at the speed of light. You see your partner 10 feet in front of you at all times. The image you see has been delayed 10 nanoseconds; you see where your partner was 10 ns ago.
At exactly the moment you reach the event horizon (i.e. at a distance of zero, not a distance of 1 Planck length) you see, 10 feet in front of you, what your partner was doing 10 ns earlier, which was crossing the event horizon. (10 ns ago the event horizon was 10 ft in front of you, as was your partner.)
If you decide at the last minute to brake and hover at a small fixed distance outside the event horizon, you see your partner's image slow down, red-shift and darken and never actually cross the horizon. This illustrated in the right-hand spacetime diagram below.
Spin-Analyser said:As you approach you see objects in front of you crossing the horizon, and you're seeing light from the other side of the event horizon. When you move away the light from previous observers moves back across the event horizon.
