What happens when a neutron star collapses into a black hole?
The discussion centers on the fate of identical fermions in a neutron star as it accumulates mass and potentially collapses into a black hole. Participants explore the implications of the Pauli exclusion principle, the conditions under which neutron stars might collapse, and the formation processes of black holes, touching on theoretical and observational aspects of these phenomena.
  • Some participants question what happens to identical fermions in a neutron star under the Pauli exclusion principle as the star gains mass and approaches black hole formation.
  • Others propose that neutron stars may not typically collapse into black holes, suggesting that black holes are primarily formed from larger stars collapsing.
  • A participant mentions a possible mass limit for neutron stars around 1.97 solar masses, speculating on mechanisms that might prevent further mass accumulation.
  • Another viewpoint suggests that the supernova process may play a crucial role in limiting neutron star mass due to material ejection during formation.
  • Some contributions highlight the significant mass gap between the most massive neutron stars and the least massive black holes, indicating a lack of observational support for a smooth transition between these states.
  • There are discussions about the role of various physical processes, such as neutrino energy transfer and nuclear reactions, in the dynamics of neutron stars and black holes.
  • A participant speculates that as energy levels change under extreme conditions, Pauli pressure may no longer prevent collapse, allowing for more particles to occupy the same energy state.
Participants express multiple competing views regarding the formation of black holes from neutron stars, the implications of the Pauli exclusion principle, and the physical processes at play. The discussion remains unresolved with no consensus on the mechanisms involved.
There are limitations in the current understanding of the transition from neutron stars to black holes, with unresolved questions about the underlying physics, including the role of quantum gravity and other complex interactions.
  • #31
chill_factor said:
now, is it so much of a stretch to think that at even higher pressures, neutrons, or quarks, have interactions that are favorable to production of a type of boson that we haven't yet observed?
It's possible once you reach GUT densities. On the other hand there are some constraints that tell you what is likely to happen.
This boson would then have no such degeneracy pressure and the entire star could just collapse to however big this boson was (subatomic scales).
The thing about degeneracy pressure is that you can show that degeneracy pressure always disappears if you crank up the gravity enough. So even if the fermions stay fermions, the degeneracy pressure disappears.
Astronomy news on Phys.org
  • #32
So there is no pressure caused by radiation and relativistic particles, approximately equal to (rho)(c^2)/3 ?
  • #33
No degeneracy pressure. I walk on a floor of wood, I don't fall through the floor. If I create a floor of photons, then I can't walk on it.
The problem with non-degeneracy pressure is that it doesn't generate much force. If I take a gas, and increase the density, the pressure only goes up slightly, which means that you don't have much force to resist gravity. If I take a solid, and increase the density even slightly, the pressure increases by a huge amount. So while photons do exert pressure, it's the dependency between density and pressure that matters, and for non-degenerate matter even if the pressure is high, increasing the density only increases the pressure slightly.
As things go relativistic all particles start behaving more like photons, so once the floor of wood goes relativistic it's like a floor of photons (i.e. you can't walk on it).
On thing about these sorts of arguments is that they are independent of the details. We don't know exactly at what mass neutron stars will collapse, but if special relativity is correct, then at some mass they'll collapse.
Also you can put upper limits. If you assume an unknown particle that increases the number of energy states available, so any unknown particle is going to decrease the critical mass. If you look at the estimated critical mass of neutron stars over time, it's gone down, because as you discover new particle interactions, you make the material softer.
One other note, is one big difference between neutron stars and black holes is that neutron stars have a hard surface whereas black holes don't. What this means is that if you look at a one solar mass object, you see big radiation flashes whereas with eight solar mass objects you don't. The explanation for this is that with neutron stars, sometimes matter will bunch up and hit the surface and when that happens there is a huge radiation burst. With black holes, there is no surface, so no radiation bursts.
  • #34
the degeneracy pressure doesn't really disappear i think, its just that there's really enough energy to force the fermions into very high energy states close to each other (or inside each other). if it did actually disappear i'd think there'd be many problems with even chemistry that we could observe.
accretion disks, converting angular momentum and gravitational potential energy to radiation?
as things go relativistic, can we think of it as "thermalizing" the degenerate materials such that they attain a more "Boltzmann-like" distribution?
  • #35
Nope. What happens is that there are more energy states available, and so the effect of having the limited number of energy states disappears.
Great!
If you can have fermions at relativistic states, then degeneracy pressure should disappear. Now figuring out how to set up that sort of experiment in the lab is something I'll leave for other people to do.
Not quite. What happens is that the energy levels change so that fermi and Boltzmann distributions converge to something that is different than non-relativistic gases.
http://en.wikipedia.org/wiki/Chandrasekhar_limit
  • #36
Great!
ok i think i understand what you're saying. in the Boltzmann limit the energy states are far apart and degeneracy doesn't matter. in the "relativistic fermi distribution", if there's enough total system energy, the particles will be forced to be far apart which is the end result. ordinarily that results in degeneracy pressure, which is the resistance of the particles to be in such high energy states, but if there's enough gravitational potential it will happen anyways.
i don't think that process will ever be obervable in the lab except with probably diamond anvils creating metallic hydrogen, which is sort of degenerate.
  • #37
"If I create a floor of photons, then I can't walk on it."
Then why is radiation pressure dominant in the largest stars, but radiation or relativistic pressure not at work in a stellar collapse? According to http://en.wikipedia.org/wiki/Radiation_pressure#In_stellar_interiors "In the Sun, radiation pressure is still quite small when compared to the gas pressure. In the heaviest stars, radiation pressure is the dominant pressure component.[6]"
Also see: http://hyperphysics.phy-astr.gsu.edu/hbase/starlog/staradpre.html which states "Extremely massive stars (more than approximately 40 solar masses), which are very luminous and thus have very rapid stellar winds, lose mass so rapidly due to radiation pressure that they tend to strip off their own envelopes before they can expand to become red supergiants, and thus retain extremely high surface temperatures (and blue-white color) from their main sequence time onwards. Stars cannot be more than about 120 solar masses because the outer layers would be expelled by the extreme radiation."
  • #38
It's not so much the amount of pressure rather than how the pressure changes with density. Photons can be viewed as a gas, and gas is "soft" whereas when you have degeneracy pressure it starts acting like a solid, and solids are "hard".
Also, in the case of neutron stars, there's nothing generating radiation pressure so that all you have is degeneracy pressure.
  • #39
This is about the amount of pressure after collapse, the point being that after collapse (rho)(c^2)/3 would exert more pressure than the degeneracy pressure of neutrons was capable of. Of course there's nothing generating radiation pressure in a neutron star; the radiation comes after collapse, and this thread is about what happens if a neutron star collapses. After there are no longer neutrons there is no neutron degeneracy pressure. But whatever the neutrons collapse to is capable of exerting pressure. Its correct for you to call it a "soft photon gas", but this soft neutron gas would crush your "hard" neutrons.
A minor detail about neutron hardness or neutrons acting like a solid (although it doesn't matter after neutron collapse): as neutrons near collapse their shape is apparently no longer round as the space between them fills up. Neutrons just ain't hard enough at collapse. But I am always amazed at the strength of neutrons up to collapse; the pressure numbers are staggering almost beyond belief.
  • #40
My mistake, a typo. The above should read: "Its correct for you to call it a "soft photon gas", but this soft photon gas would crush your "hard" neutrons."
  • #41
It turns out that the total amount of pressure doesn't matter. What matters are pressure differences. If you inflate a balloon to 100 psi, but it's in a 100 psi environment, nothing happens. Now if you inflate the balloon to 0.5 psi but put it into a vacuum, it blows up.
So pressure is irrelevant. What matter is the difference in pressure, and how pressure changes when you change the physical situation. Take that balloon. If you blow it up to 1000 psi and squeeze it. If the pressure in that balloon stays 1000 psi, then it will not react when you squeeze it.
No. If the neutrons break up into smaller particles, that the number of states and that reduces pressure. Now if the neutrons combined and formed *bigger* particles, then you'd reduce the number of states and that would stop the collapse until you add even more mass. However, we haven't seen any particles that are larger than the one's we know, and there are good reasons for thinking that even if those particles did exist they would decay into smaller particles.
One thing about astrophysics is that you stop being impressed by large numbers. What's important is the order of magnitude, and when I think about neutron stars, I think of the number 15. The density at the core of the neutron star is 10^15 g/cm^3. So when I think about astrophysical objects, I just look at the order of magnitude. My brain can't handle thinking about 10^51 or 10^54, but it can handle 51 and 54.
  • #42
i hate to be one of those annoying nitpickers but whether the balloon blows up or not depends on structural strength of the plastic.
also, do neutrons actually repel each other? not through degeneracy pressure, but through other means?
  • #43
Neutrons are electrically neutral so aside from Pauli exclusion there is no known repulsive force between neutrons.
  • #44
This thread is about what happens if a neutron star collapses. Are you saying there is no relativistic pressure of about (rho)(c^2)/3 after neutron collapse?
  • #45
Neutron star core pressure is about equivalent to supporting the entire weight of the sun on one square inch of the Earth's surface. Or setting off over a billion H-bombs and containing it in 1 cc. That impresses me. A neutron is a mighty strong thing.
When a neutron collapses it does not turn into nothing, it turns into something and there is conservation of mass-energy. Logically that something is quark type matter and radiation.
  • #46
It's actually P = \rho ^(4/3). What you'll find is that when P = \rho ^(4/3) there are no stable solutions so that the object must collapse. What matters is not whether or not there is pressure but how the pressure changes with density.
  • #47
So what?
The problem is that you can't do arithmetic with it. Imagine a billion H-bombs going off at the same time. Now imagine a million. Now imagine a trillion. The pictures look the same, but a trillion H-bombs is a very different situation than a million H-bombs.
It helps a lot *not* to get impressed by large numbers, and then think of 6, 9, and 12.
Except that because quarks are lighter than neutrons they are even more unstable to collapse than raw neutrons.
The problem is that until relativity breaks down, there is nothing that can stop the collapse.
  • #48
we're making progress. A billion or a trillion H-bombs contained in 1 cc is impressive to me, so is the weight of the sun on 1 square inch of the earth.
When neutrons collapse they should convert to mostly radiation and only a small amount of quark matter, so the net pressure should be pretty close to (rho)(c^2)/3. If the quarks ultimately collapse to radiation that's OK too. Where do you get the coefficient (4/3) from? My guess it is from a pressure formula that is not applicable here.
What do you mean by until relativity breaks down? Effects at a neutron stars surface or core, or effects at a black holes surface or core?
  • #49
That's not possible without breaking the standard model. It doesn't conserve baryon number. Neutrons have to break down to quarks.
Also when the neutron star starts to collapse into a black hole, the densities aren't extraordinarily high.
At black hole singularity, relativity has to break done.
  • #50
Well, super collider experiments show a smashed nucleus breaks down to mostly radiation plus 3 quarks and a little bit of other small exotic particles. I always considered densities rather large in a neutron star. At a black hole singularity, relativity and everything breaks down; that's why I don't believe in a point singularity. On the other hand if a 2 solar mass neutron star of 12 km radius was to hypothetically entirely collapse to a radiation/quark star of 4 km radius , the average density would go up by a factor of 27. Thats large density too. Larger radiation/quark stars would have less density and core pressure than smaller radiation/quark stars.
  • #51
Particles collide at enormous energies inside of colliders, and it is that extra energy that is converted to radiation and other particles. I'm not sure if you would say that a nucleus "breaks down" under enormous pressures or not. It seems to me that as the pressure increases the atom is converted into a higher energy state as the electrons and protons are transformed into neutrons. Beyond that, if the neutrons form quark matter, then wouldn't they be in an even higher energy state, and not release particles or radiation? Looks like the nucleons "merge" together in a quark soup or something.
  • #52
"Beyond that, if the neutrons form quark matter, then wouldn't they be in an even higher energy state, and not release particles or radiation? Looks like the nucleons "merge" together in a quark soup or something."
I could go along with that. I want to calculate the radius of a star of relativistic material using the viral theorem. Do you have a suggested pressure formula as a function of density for this quark soup?
  • #53
I think the pressure of this quark soup would also be (rho)(c^2)/3. See:
http://www.strw.leidenuniv.nl/~nefs/FermionGas.pdf
  • #54
Pressure of (rho)(c^2)/3 is enormous and I think this would prevent collapse of the quark star, although the radius would be smaller than the Schwarzschild radius.
  • #55
I think this star gravitationally is Newtonian, except for an atmosphere where effective gravity shifts to relativistic.
(rho)(c^2)/3 indicates a supporting energy of M(c^2)/3 , which indicates gravitational potential energy of 2M(c^2)/3 .
  • #56
Neutron stars if not anything else, are composed mostly of fundamental particles called quarks and gluons in the form of degenerate neutrons. And according to Loop Quantum Gravity (LQG), when a neutron star collapses, the matter inside a black hole becomes a relativistic quark-gluon plasma, which gravitationally collapses and rebounds in an oscillation on the order of a Planck singularity. In this sense, black hole cores are the ultimate atom smashers in the Universe.
The pressures and densities cited by this thread are used to describe the pressure and densities inside neutron stars, also known as a 'Fermion gas', which depending on the mathematical model of their Equation of State, can be relativistic or non-relativistic, and inside black holes, with the consideration of relativistic quark-gluon plasma pressures and densities, curve into relativistic Planck pressure and Planck density.
The pressures and densities inside the core of a black hole are on the order of Planck pressure and Planck density.
[/Color]
Reference:
Loop quantum gravity - Wikipedia
  • #57
The Wiki article on Loop quantum gravity is vague. Can you give an equation for the Plank pressure or density in a black hole?
I think a gravitationally contained quark matter star would experience a pressure of about (rho)(c^2)/3 and have a radius between R = (1.2GM)/(c^2) and R = (1.5GM)/(c^2).
  • #58
I did the calculation for gravitational potential energy using a density profile of
[1 - (r^2)/(R^2)] and came up with 1.1 G (M^2)/R. Not sure if this is correct. Does anybody have the equation for gravitational potential energy using a density profile of
[1 - (r^2)/(R^2)] ?
  • #59
1.1 G (M^2)/R seems too high for the Newtonian gravitational energy based on [1 - (r^2)/(R^2)] ... I think at most it should be 1.0 G (M^2)/R ... I'll go over it again and will post it here, but won't get to it for several days.
  • · Replies 48 ·
  • · Replies 17 ·
  • · Replies 0 ·
