The Relativity of Simultaneity: A Fundamental Concept in Special Relativity
The discussion centers on the concept of the relativity of simultaneity (RoS) within the framework of special relativity. Participants explore the relationship between RoS, Lorentz contractions, and time dilation, seeking to clarify how these concepts interrelate and their implications for understanding simultaneity in different frames of reference.
  • Some participants propose that RoS is a consequence of Lorentz contractions and time dilation, while others argue it is not a separate component but rather a shorthand for these effects.
  • A participant illustrates their understanding by suggesting that absolute simultaneity would exist if all observers were at rest relative to each other, with RoS arising only when an observer moves relative to that frame.
  • Another participant emphasizes the importance of understanding frames of reference, stating that simultaneity is defined by the time coordinates of events in a given frame.
  • Some participants question whether RoS can exist independently of time dilation, suggesting that absolute simultaneity might be a universal feature rather than a relative one.
  • There are discussions about the nature of events and their coordinates, with one participant asserting that events do not "experience" anything, and simultaneity is determined by the synchronization of time coordinates in a frame of reference.
Participants express differing views on the relationship between RoS, time dilation, and Lorentz contractions. No consensus is reached regarding whether RoS can exist without time dilation or if it is merely a reflection of other relativistic effects.
Some discussions highlight the limitations of defining simultaneity in the universe, suggesting that it may depend on the chosen frame of reference and the definitions applied to remote time.
  • #151
bobc2 said:
Your logic looks good to me, mangaroosh, but I do not want to hijack this into another block universe discussion.
Ah yes, I forgot to mention that - ok then, I do that now!
Mangaroush you may be interested in this topic:
https://www.physicsforums.com/showthread.php?t=583606
mangaroosh said:
Lorentzian relativity used the LT though, and doesn't incorporate RoS; no?
The LT certainly incorporates RoS, and Lorentz was perhaps the first to introduce the "local time" concept (note: it was probably Poincare who first understood what that means for clocks).
What Lorentzian relativity doesn't incorporate is the "block universe" interpretation, about which a still open discussion exists in the other thread.
  • #152
GeorgeDishman said:
SR was derived from the observation of the independence of the speed of light from the speed of the source so as such it doesn't need any assumptions. Rather, the old aether model and SR's geometric model are two diametrically opposed philosophical interpretations of the same mathematical theory, the Lorentz Transforms. While it is useful to compare and contrast them, you can't mix them.
For example you say "my metre stick is contracted such that 'my meter' is shorter than 'your metre'" but that only applies in the aether interpretation. In SR, the metre stick is unchanged and the shortening is due to coordinate projection, a purely geometric effect. Mixing the models will usually create confusion simply because of their different interpretations and I butted in because I think that may be part of the cause of the difference of opinions.
The point being made though, is that all we ever have is a measurement of c; however, an ivariant measurement of c, by itself, doesn't imply RoS; only if RoS is assumed along with the measurement of c, can we conclude that RoS prevails - but this would be circular reasoning. That is, we have to assume RoS to arrive at the Eisteinian interpretation, but RoS is one of the conclusions of the Einsteinian interpretation, and so it appears to be circular reasoning.
Lorentz aether theory, or rather neo-Lorentzian relativity, has supposedly been divested of the concept of the aether
  • #153
mangaroosh said:
But RoS is a consequence of the actual speed of light remaining invariant. If the distinction between measured and actual values is made, then RoS doesn't arise.
Again, the distinction between actual and measured values is unimportant. Scientifically, all that matters is the measurements, so all of my statements here refer to measurements. If there is a hidden actuality that cannot be measured then it is irrelevant to physics.
mangaroosh said:
It doesn't have RoS as a necessity though, does it? Again, RoS is not a part of Lorentzian relativity which uses the same transform, no?
No. The RoS falls directly from the Lorentz transform. It is a testable part of any theory which uses the Lorentz transform for experimental predictions. As you have been told multiple times by multiple people now.
  • #154
harrylin said:
It was just a precision in my comment on you saying "physical effect"; however that is not the topic here, and that is why I did not elaborate on it. :smile:
ah OK, I'm still none the wiser though :redface:
harrylin said:
No, here is at least one, but likely two errors in one sentence (not regarding a glitch on top of it):
- you mix up reality with a point of view: what I measure with my inertial frame cannot be claimed more "reality" than what you measure with your inertial frame. That is even the basis of SR.
But it isn't being claimed that one measurement is more real than another, it is simply being stated that the same figure of measurement, using different length instruments, means a different actual measurement.
harrylin said:
- With my reference frame, the same light ray took - if for example your lab is moving in the same direction as the light ray - a little longer than a second to travel a distance greater than 300,000 km. That is because I measure the speed to be 300,000 km/s.
But if my clock is ticking slower, then it means that "my second" is longer than your second; and if "my metre" is contracted, it means that "my metre" is shorter than "your metre"; so, if I measure the speed of light to be 300,00 km/s and you measure it to be the same, but our measuring instruments are of different lengths, then the actual measurement represented by those units are different - unless the contractions don't acutally occur, and are only illusory.
harrylin said:
If you like to suggest that to yourself, then it will look that way; what it suggests to me is what I replied to you earlier. :smile:
:smile:
That isn't so much what I would like to suggest to myself, as opposed to what has been suggested to me by others. I'm not really clear how your formulation differs though.
The example that has been used to demonstrate this, is the lightning rod thought experiment, where the observers disagree about the simultaneity of the events; the observer on the train sees the lightning at the "forward" rod before the "rear" rod, while the observer on the platform sees them as simultaneous; where t=0 is the time when the lightning strikes the rods in the platform observers reference frame, and the time when the train observer is in-line with the platform observer.
The train observer calculates that the flash at B occurred at a time before t=0, while the platform observer calculates that they both occurred at t=0. In order for the platform observer to accept this, he must make an assumption about the existence of the lightning event before t=0, as well as the event after t=0. The train observer must make similar assumptions.
harrylin said:
That kind of conclusions from the suggestion that you fell for suggest to me that it is likely a wrong one. :-p
As Bobc2 mentiosn above, it appears to be necessary to accept the concept of "the block universe", or even RoS.
  • #155
I don't think that is necessarily contrary to emprical evidence, but again, I don't want to get into this any further.
Thanks bob.
I'm not sure if it makes a difference, as the thread starter, to say that I don't think you'd be hijacking it; it seems to be a related concept.
  • #156
The point above demonstrates that it is an important distinction, because an invariant measurement of c doesn't necessarily imply RoS.
This conflicts with what has been said about Lorentzian relativity though, by multiple people, multiple times; that Lorentzian relativity doesn't include RoS, but yet it does use the Lorentz transform. If this is true, then it is a non-sequitir to suggest that RoS is necessarily a consequence of the LT.
As has also been stated by miltiple people, multiple times, RoS is a consequence of an invariant speed of light.
Again, as has been demonstrated, an invariant measurement of c does not imply an invariant actual speed of c.
That it may be a hidden actuality isn't relevant, it's that one interpretation appears to rely on circular reasoning, while the other doesn't.
  • #157
If you look at his paper though, you find he didn't assume RoS, his two postulates were only that light moved at a speed which was independent of the speed of the source and that the laws of electrodynamics and optics apply in any inertial frame. The RoS is then derived from those.
http://www.fourmilab.ch/etexts/einstein/specrel/www/
Really? Lorentz's interpretation was that objects shrank by an amount determined by their speed relative to the aether in the direction of motion. How can that speed be defined without an aether? It not only must exist, it must also provide a reference against which motion can be measured (which is a much stricter requirement).
  • #158
so, if I measure the speed of light to be 300,00 km/s and you measure it to be the same, but our measuring instruments are of different lengths, then the actual measurement represented by those units are different [..]
Yes i can agree with that. :smile:
Now assume that by chance (just for simplicity of discussion) that the train is at rest in the ether (Lorentz interpretation). Then everything will be measured as Einstein described. And then there is nothing mind-boggling going on at all.
Historically you can choose between the Lorentz interpretation (stationary ether) and the Minkowski interpretation (block universe), and in recent years a few more subtle variants have appeared (I think we had a recent topic on that). But all those interpretations of RoS should not be confounded with the RoS itself, which as Dalespam mentioned is a feature of the equations that we call Lorentz Transformations, and which apply to certain reference systems that are set up in a certain way.
  • #159
I agree. That is why I said [itex](\text{C} \cap \text{PoR})\rightarrow \text{RoS}[/itex] and not [itex]\text{C}\rightarrow \text{RoS}[/itex]
OK, point well made, we cannot appeal to numbers of sources for a correct analysis. That is why math derivations are so important. I can and have backed up all of my claims mathematically.
RoS is an unavoidable and testable consequence of any theory which uses the LT for its experimental predictions. Any assertion to that any Lorentz-transform based theory does not have RoS is either wrong or deliberately referring to something untestable and therefore scientifically irrelevant.
  • #160
The point being made, though, is that an invariant measurement of c is different to the actual speed of c remaining invariant; where only an invariant actual speed of c results in RoS, and a measurement of c doesn't necessarily.
Given that we only ever have a measurement of c, RoS would have to be assumed; although the points being raised by DaleSpam and Harrylin, below, might offer a different interpretation.
I'm not so sure that the alternative that time and space are affected by the motion of an object is any less fantastical, particularly when the effects can only be measured using the objects that Lorentzian relativity claims would shrink. Also, I think neo-Lorentzian relativity does away with the concept of the aether, and instead uses the concept of an absolute rest frame.
Without the ether the speed could probably be defined by defining a "rest frame" for measurements, as opposed to an ether.
  • #161
I think you've mentioned the difference between the two kinds of RoS before, but I'm not entirely clear on what is meant. The issue gets somewhat muddied for me when you mention the alternatives as being the block universe and a stationary ether, because I've read that the concept of the ether has been effectively removed from neo-Lorentzian relativity, with the concept of an "absolute rest" frame being retained.
When I think of RoS I think of it as contrasted with absolute simultaneity, or the idea that only the present moment exists.
Have to run, will try and finish this at home
  • #162
The idea that only the present moment exists is called presentism, and is contrasted with the idea that past present and future all exist on equal footing, which is called eternalism. They are both philosophical concepts that do not have any scientific meaning (i.e. they do not lead to testable predictions).
Simultaneity is the concept of whether or not two different events happened at the same time. Two things may be simultaneous regardless of if you accept eternalism or presentism.
The relativity of simultaneity means that two observers moving relative to one another will disagree about whether or not two events are simultaneous. Any theory which uses the Lorentz transform for its experimental predictions automatically incorporates the relativity of simultaneity into its measurements.
  • #163
You need to explain to me what you mean by "actual speed" if it isn't what is measured.
RoS will always occur if the universe is Lorentz Invariant irrespective of interpretation as 'DaleSpam' has said.
No, it follows as a consequence. You can define a method for synchronising clocks by sending a light signal from A to B and back to A for example. If you apply that method in two frames, you get different decisions as to whether two events are simultaneous. It turns out that all other physically possible methods are equivalent.
I would probably agree but that's not an interpretation I've ever heard of, the only ones I know are LET and SR.
Also, I think neo-Lorentzian relativity does away with the concept of the aether, and instead uses the concept of an absolute rest frame. Without the ether the speed could probably be defined by defining a "rest frame" for measurements, as opposed to an ether.
You will see that suggestion made by people who don't understand LET (or basic physics for that matter) but it has never been a theory. In LET, the mechanism that causes the various effects is an interaction with the aether hence the velocity that goes into the transforms is that of the object relative to the aether. Without some physical substance against which to measure velocity, there is no way to define the quantity. Note you can't even measure speed relative to something which is continuous, a uniform electric potential for example.
  • #164
I'm not sure that is true, doesn't presentism require an aether-like approach to avoid temporal displacement in the twins scenario?
This is probably a topic better discussed in the philosophy forum though.
  • #165
What is the difference, except for words?
When I think of RoS I think of it as contrasted with absolute simultaneity, or the idea that only the present moment exists. [..]
That sounds like the block universe interpretation to me.
A good start for such philosophical issues may be Newton's mechanics, which defines "absolute" and "relative" velocities. Newton's mechanics compares to classical mechanics as Lorentzian mechanics to special relativity.
Here's another one: in England people live in another time than in Germany. Do you think that such time definitions have anything to do with existence of a present moment or not?
Cheers,
Harald
  • #166
That depends on the interpretation of the PoR. If the measurement of c remains invariant, then an observer cannot conduct an experiment to distinguish their reference frame from any other, but this still wouldn't necessarily imply RoS.
RoS isn't testable either though, is it?
Do you, by any chance, know what people might be referring to when they say that Lorentzian relativity incorporates absolute simultaneity, and not RoS?
  • #167
Yes, it does necessarily imply RoS. That was one of the points of sections 2 and 3 of Einstein's paper "On the Electrodynamics of Moving Bodies".
Yes, it is. Synchronize two sets of clocks moving relative to each other, measure the time of two events, and see if they agree on the simultaneity.
  • #168
OK, but is there an issue with the logic, as outlined above, that it doesn't necessarily imply it, because you can have an invariant measurement of c without implying RoS; only an invariant actual measurement of c results in RoS; and we can't make such deductions from only an invariant measurement of c.
The consequence of the PoR would also remain intact.
There is an assumption in that which relates to a closed thread (which is under appeal) so I'm not sure how explicit I can be, without risking an infraction. The thread is in the general discussion section an pertains to the mechanics of a clock.
If, however, we take the example of two relatively moving atomic clocks, which use a laser and detector (or photon and detector) to "measure the time of two events"; the relatively moving clocks might tick at different rates because the photon in each clock has a different distance to travel to the detector. This wouldn't demonstrate RoS, rather slower ticking clocks.
  • #169
Is RoS compatible with presentism? My understanding is that it isn't.
My understanding is also that Lorentzian relativity includes presentism, and hence why I am of the understanding that it doesn't include RoS.
  • #170
The point was that if two observers measure the speed of light to be 300,000km/s but the instruments of one of the observers are contracted, such that his metre stick is shorter than the metre stick of his counterpart, and his clock ticks slower than his counterparts clock, then the actual speeds represented by those two measurements are not the same.
OK, but people on here have mentioned that Lorentzian relativity includes absolute simultaneity (presentism) and not RoS.
This requires the assumption that it takes an equal amount of time for the light to travel in each direction, doesn't it?
Does SR not suggest that time and space are affected by the motion of an observer, such that time slows down and space contracts?
I know that LET includes the aether, but what is termed neo-Lorentzian relativity supposedly has been divested of the concept of the aether
the last vestiges of a substantial ether had been eliminated from Lorentz's "ether" theory, and it became both empirically and deductively equivalent to special relativity. The only difference was the metaphysical[C 7] postulate of a unique absolute rest frame, which was empirically undetectable and played no role in the physical predictions of the theory. As a result, the term "Lorentz ether theory" is sometimes used today to refer to a neo-Lorentzian interpretation of special relativity
  • #171
I'm not sure to be honest. My understanding is that neo-Lorentzian relativity includes, or is compatible with, presentism, but that presentism isn't compatible with RoS, which would lead to the conclusion that neo-Lorentzian relativity doesn't include RoS and so the Lorentz transform doesn't necessarily include RoS.
But, if RoS is included by necessity in the LT, then there must be two different interpretations of RoS - unless there is an issue with the reasoning above.
Are there other interpretations of RoS?
Apologies, I don't fully understand the comparison.
Nothing whatsoever I would say. I would say that when it is 2pm in England, it is 3pm in Germany, but both exist, simultaneously, in the present moment.
  • #172
OK, but is there an issue with the reasoning, outlined above, that an invariant measurement of c doesn't imply RoS, that it is only an actual measurement of c that implies it?
Given that the oft stated consequence of the the PoR would remain intact i.e. no experiment could distinguish between reference frames.
Lorentzian relativity would suggest that the different time measurements of the clocks would be down to the mechanical effects on the clock, wouldn't it, and not due to time slowing down; this would preserve the concept of absolute simultaneity wouldn't it?
How would we determine that time, as opposed to the mechanics of the clock, has been affected?
  • #173
"Speed" is a measurement. If the length of his ruler and times on his clock comply with the physical definition of the metre and second, then the actual speed he has measured is c.
Lorentz's aether assumed Galilean Relativity and proposed ad hoc physical changes in objects due to an unknown mechanical interation between matter and the substance of the aether to explain the invariance of the speed of light so it is compatible with both presentism and eternalism. However the Relativity of Simultaneity refers to events having different separation of their time coordinates in mutually moving frames so it still occurs in LET. LET offers an alternative philosophical explanation for the RoS but since it is an observed effect, it could not discard it without being falsified.
c can be derived from the permitivity and permeability in Maxwell's Equations. Both are scalar hence the speed must be scalar and therefore it must be isotropic.
No, SR says that spacetime has fixed Reimann geometry. Draw two dots on a plain white sheet of paper. Place a grid drawn on a transparent sheet over the top and measure the X and Y coordinates of the dots. Now rotate the transparency a little. You get different coordinate separations but the white sheet of paper has neither shrunk nor stretched and the dots haven't moved. SR says changing your coordinate scheme will change the numbers that label an event but that's all. Spacetime intervals are invariant for the same reason that Pythagoras will give the same result for the separation of the dots regardless of how you orient the transparency with the gridlines.
  • #174
Scientifically there is no issue since, as I have mentioned several times, any unmeasurable aspects are scientifically irrelevant. This site is for discussing science, not philosophy.
Correct, as we have discussed previously TD and RoS are two entirely different concepts.
  • #175
No. In LET local time exhibits RoS.
We cannot. That is why the distinction is scientifically meaningless.
  • #176
mangaroosh said:
[..] My understanding is that neo-Lorentzian relativity includes, or is compatible with, presentism, but that presentism isn't compatible with RoS, which would lead to the conclusion that neo-Lorentzian relativity doesn't include RoS and so the Lorentz transform doesn't necessarily include RoS.
I don't know what you call "neo-Lorentzian relativity". Do you have a quality reference for that? And is it useful?
Yes, and several of us have mentioned and explained this several times to you...
Sure - as you know. Lorentz's "Local time" is RoS with an interpretation that differs from Minkowski's interpretation.
It's useful to first understand the basis of such discussions - thus, can you explain how there can be both absolute and relative velocity in Newton's mechanics? Or, in other words, is velocity absolute or relative in his theory?
In SR (that is, the Lorentz transformation), when a certain clock of S indicates for example 2PM, another clock of S' that passes that clock at that time (thus at the same place and moment) will indicate for example 3PM. For some reason (a reason that escapes me), you think that this has big philosophical implications, while a similar case with time zones on Earth has none...
  • #177
Yes, but if the instruments used by one observer are contracted compared to anothers, then the same measurement of 300,000 km/s would represent different actual speeds.
Apologies, I thought I had posted this already in this thread, but it must have been a different one:
This suggests, and has been echoed by others on here, that the concept of the aether has been removed from Lorentzian relativity, leaving just the concept of an "absolute reference frame".
The RoS in Lorentzian relativity is materially different to Einsteinian; indeed, absolute simultaneity is incorporated in Lorentzian relativity - as it must if presentism is to prevail - so I think referring to it as RoS is somewhat of a misnomer - but that might just be my interpretation of the concepts of absolute simultaneity and RoS.
Would you say that absolute simultaneity is compatible with RoS?
apologies, I don't fully understand the point pertaining to the P & P in Maxwell's equations.
I'm not sure if it would help to give some context for the discussion, but this thread stems from a different discussion, where the contention was that the speed of c from Maxwell's equations tacitly assumes the Earth as the rest frame for measurements, so the conclusion would be that Maxwell's equations include the tacit assumption that the constancy of c is relative to the earth.
To avoid dragging this thread off on a tangent, here is a link to the constancy of c thread.
Is spacetime a physical property/substance?
  • #178
Is this site not also for discussing the philosophy of science, no? The conclusions drawn from experiments are largely a matter of philosophy, as this discussion on RoS is demonstrating.
We cannot determine that the actual speed of light remains constant, but some of the conclusions drawn assume it to be so; insofar as those conclusions are scientifically relevant, then so to are the unmeasurable aspects.
OK, this is where we are at cross purposes I think.
It has been mentioned in a thread on Lorentzian relativity that it incorporates absolute simultaneity, in the form of presentism; to my mind - and this could be where the issue lies - RoS is not compatible with absolute simultaneity.
Again, to my understanding, form discussions on here and elsewhere, local time in LR isn't "real" time; the difference in time co-ordinates is due to the mechanics of the clock being affected by motion, as opposed to "time itself" being affected.
Again, how I understand it is, under an LR interpretation, absolute simultaneity, and a shared present moment, prevails, while under ER, the present moment is entirely relative and one observers past can be another's present, while one observers future can be another observers present; and other such combinations.
That is the distinction I would draw between RoS and absolute simultaneity; which I think is necessary because it refers to the simultaneity of physical events, as opposed to the ascription of mathematical time co-ordinates.
I don't think it is scientifically meaningless when distinction materially affects the scientific models; where claims to the physicality of time are made, surely it is an important distinction.
  • #179
If the length of his ruler complies with the physical definition of the metre, his ruler is not contracted, though he might question that of the other observer. As I said "actual speed he has measured is c" unless you have some other meaning of "actual".
No apology needed, you had it at the bottom of your previous message but I had already commented on it in the one before so I skipped repeating it:
To be blunt, the idea that you can have an aether theory without an aether is brain-dead nonsense posted by idiots. You will see it said in many places but popularity is not a usable indicator.
Aether theory was not based on presentism, it comes from assuming Galilean relativity and the "absolute time" defined by Newton in the Principia. See the third paragraph here:
http://plato.stanford.edu/entries/Newton-stm/scholium.html
I think I said before though perhaps not clearly, RoS refers to the time coordinates given to events so it is occurs in LET as much as SR. LET only provides an alternative interpretation of why it is unavoidable so I would state it differently, I would say that presentism is not compatible with the non-existence of an aether. I also suspect that an aether-based model s not compatible with the observation of polarisation of light. Philosophically, that leads me to a perdurantist view, but that should really be left to the philosophy forum.
1/√(ε*μ)
If ε and μ are just scalar numbers then they cannot have different values in different directions. That means the speed of light cannot have different values in different directions, but that is what is required in aether theory for any observer moving relative to the aether.
I'm not sure if it would help to give some context for the discussion, but this thread stems from a different discussion, where the contention was that the speed of c from Maxwell's equations tacitly assumes the Earth as the rest frame for measurements ...
That's another common error made by clueless cranks, if that were the case, the velocity of the observer relative to the Earth would appear in Maxwell's Equations. In fact they are independent of the choice of frame.
That's a whole different question ;-)
http://plato.stanford.edu/entries/spacetime-holearg/
For SR, the question needn't arise as long as you can assume that a hypothetical right-triangle in empty space still obeys Pythagoras Theorem. SR says the vacuum is 4-dimensional and extends Pythagoras as:
s^2 = x^2 + y^2 + z^2 - (ct)^2
All we need say is that the vacuum of SR has the property that it exhibits Euclidean geometry in any spatial 3D slice and Riemann geometry with signature {+++-} in 4D.
  • #180
I've come across it in a few places.
the last vestiges of a substantial ether had been eliminated from Lorentz's "ether" theory, and it became both empirically and deductively equivalent to special relativity. The only difference was the metaphysical[C 7] postulate of a unique absolute rest frame, which was empirically undetectable and played no role in the physical predictions of the theory. As a result, the term "Lorentz ether theory" is sometimes used today to refer to a neo-Lorentzian interpretation of special relativity. The prefix "neo" is used in recognition of the fact that the interpretation must now be applied to physical entities and processes (such as the standard model of quantum field theory) that were unknown in Lorentz's day.
wiki
I've come across it in a few other papers too, by Brown & Pooley, Gürel & Gürel, among others.
OK, I think I understand the distinction now. As I mentioned in the post to DS, to my understanding LR includes absolute simultaneity, in the form of presentism; for that reason I think it is a misnomer to refere to RoS with respect to LR, because it implies two different notions of simultaneity of events.
Are both concepts not included? I'm not entirely sure how they might be, but I thought I had read that both were; just as both are in Galilean relativity (aren't they?)
I don't think the fact that the clocks in S and S' tick at different rates should have big philosophical implications at all; the philosophical implications arise with the interpretation that it is time that is ticking slower or faster, as opposed to the mechanics of the clock being affected.
We can - and do - arbitrarily wind the clocks in each time zone to afford us more daylight hours; some time zones do this, while others don't; but we don't conclude that time moves forward or backward when we do so.
  • · Replies 17 ·
  • · Replies 36 ·
  • · Replies 54 ·
  • · Replies 17 ·
  • · Replies 116 ·
10K
  • · Replies 20 ·
  • · Replies 89 ·
10K
