Direction of rotation, brushless or brushed DC motor
The discussion focuses on the operational principles of brushless and brushed DC motors, specifically addressing the direction of rotation. It is established that the commutator in brushed motors plays a crucial role in changing the current direction to prevent the rotor from getting stuck. For brushless motors, the startup sequence relies on a controller that assumes an initial rotor position and gradually increases speed until it can utilize back EMF for further operation. This mechanism ensures that the motor can start and maintain rotation without ambiguity in direction.
  • Understanding of DC motor types: brushed and brushless
  • Knowledge of commutation in electric motors
  • Familiarity with back EMF concepts
  • Basic principles of electromagnetic fields and torque generation
  • Research the function of commutators in brushed DC motors
  • Learn about brushless motor controllers and their startup sequences
  • Explore the role of back EMF in motor operation
  • Investigate torque generation in multi-pole DC motors
Electrical engineers, hobbyists working with robotics, and anyone interested in the mechanics of motor operation and control systems.
mjbourquin
I still don't understand why these types of motors tend to spin in one direction or another. In theory the direction of spin should be random since when the north pole of the rotor magnet is lined up with the north pole of the electromagnet in the stator the rotor could be repelled clockwise or counterclockwise and so could spin in either direction. Then in another half a cycle the direction is known because of momentum but at the start how do you know?
This is because of the commutator on the rotor. It changes the poles just in time, by sending the current to another coil.
You don't know which direction the motor will initially move. For a 3 (or more) phase brushless motor controller, the start up cycle just assumes the initial rotor will line up with some phase position after 1 or 2 steps using fixed delays between the first steps, then cycles "forwards" at an ever increasing pace until enough cycles and speed has occurred to switch to using back emf as input.
I'm not sure how a DC brushed motor with just two poles avoids getting stuck in a short circuit and/or zero torque state at startup. 3 or more poles solves the issue.
  • · Replies 16 ·
  • · Replies 25 ·
13K
