What is the actual 'mechanism' of friction
  • Context: Undergrad
  • Thread starter Thread starter lntz
    Friction Mechanism
The discussion centers on the complex nature of friction, emphasizing that it is not solely determined by surface roughness. Participants highlight that friction arises from a combination of factors, including intermolecular forces and molecular adhesion between materials. While surface texture plays a role, the interactions at the molecular level, including electron interactions, significantly influence the frictional force experienced. The consensus is that friction is a multifaceted phenomenon that is not completely understood, with various materials exhibiting different coefficients of friction due to these underlying interactions.
  • Understanding of basic mechanics and physics principles
  • Familiarity with surface roughness and its effects on material interactions
  • Knowledge of intermolecular forces and molecular adhesion
  • Basic grasp of material science concepts
  • Research the role of intermolecular forces in friction
  • Explore the concept of molecular adhesion and its impact on material properties
  • Study the coefficient of friction for various materials and their applications
  • Investigate advanced friction models in physics and engineering
Students and professionals in physics, material science, and engineering who seek a deeper understanding of friction and its underlying mechanisms.
lntz
in mechanics and physics we are forever talking about friction and using it to solve problems.
but what actually is friction?
is it as simple as saying how rough a surface is? that doesn't sound adequate to me.
if that were the case then i'd expect all materials to have the same coefficient of friction if they were as flat as a mirror for example.
i have a feeling that it probably has something to do with interactions between electrons on the surfaces of the two materials in contact.
please can somebody describe the actual reason we feel a friction force.
thanks.
Roughness does play a part, but not the only part. I don't know about electrons, but as you suggest there are also intermolecular forces at play that determine friction.
Ultimately there are many factors. Books have been written on the subject, and you're certainly not the only one who doesn't uderstand it. In fact, nobody fully does.
I'm just taking a little bit of a wild stab at this, but I would assume that certain materials have a molecular adhesion or attraction which causes much more friction!
  • · Replies 17 ·
  • · Replies 35 ·
  • · Replies 22 ·
  • · Replies 17 ·
