2 classic helicoid in rotation with different pressure
  • Context: Graduate
  • Thread starter Thread starter Gh778
    Pressure Rotation
The discussion revolves around the dynamics of two classic helicoids rotating under varying pressure conditions. Participants explore the implications of pressure differences on the movement and energy dynamics of the helicoids, considering both theoretical and practical aspects of their interaction.
  • One participant suggests that when two identical helicoids rotate in the same direction, they remain static in the vertical direction, with only rotational movement occurring.
  • Another participant proposes that a pressure of 3P can be applied outside the black helicoid, while a pressure of 2P exists between the helicoids, potentially causing them to rotate in the same direction.
  • Concerns are raised about the energy dynamics, with a participant questioning whether the system can sustain rotation without energy loss, given the proposed pressure configurations.
  • It is noted that the interface between the helicoids, where pressure is 2P, is constant in volume and does not lose energy during vertical movement.
  • Participants discuss the role of gaskets and the configuration of the helicoids, suggesting that the surfaces of the gaskets being vertical may not require energy for vertical movement.
  • One participant expresses uncertainty about the correctness of their points and seeks feedback on potential errors in their reasoning.
Participants do not reach a consensus on the mechanics of the helicoids' movement or the implications of the pressure differences. Multiple competing views and uncertainties remain regarding the energy dynamics and the feasibility of the proposed configurations.
The discussion includes assumptions about the behavior of the helicoids under pressure, the role of gaskets, and the energy implications of the proposed system. Some mathematical and physical details remain unresolved, particularly regarding the energy dynamics and the configuration of pressures.
This discussion may be of interest to those studying fluid dynamics, mechanical engineering, or anyone exploring the principles of rotational motion in complex systems.
Gh778
I try to find the movement of classic helicoids and the sum of energy with 3 different pressures. For me when two identical helicoids turn in the same direction around their axis, they don't move up/down. In fact, when I see helicoids turning I see all static except the helicoid which turn around their axis. Like all is static, for me, it's possible to put pressure 3*P everywhere outside black helicoid except between helicoids where pressure is 2*P. And for red helicoid it's possible to P pressure everywhere outside except between helicoids. The difference of pressure want to turn each helicoid in the same direction. Green separation is there for prevent 3*P pressure to go to P pressure area, this area is static. If helicoids turn they give energy, but like I loss nothing in energy, I think the system can't turn like that or the pressure can't be put like that but I don't know where is the problem here. Sure there are a lot of gaskets, not show on the drawing.
Edit: the green area can be smaller and can be attach to the black helicoid with gaskets.
Edit: helicoids turn at the same speed
Edit: In fact, I see the film with pressure 2P move up (or down), this film can be very small because helicoïds have same pitch, think with internal thread (female) and external thread (male) there is no space between helicoids. Here helicoids are joined at external in a small part but enough for create a torque.
Edit: The intersection of helicoids is a line so maybe the surface is 0. But think with only one interface with 2P pressure, we can oriented helicoids for have a greater surface, one helicoid on Z axis and other make an angle like 2*pitch.
Edit:
I add three 3D views of helicoids for see how is the interface.
I add the volume of the interface when helicoids are vertical. Up and down surface are helicoids surfaces (not gaskets). External and internal surfaces are the gaskets. Like these 2 surfaces of the gasket are verticals they don't loss energy when move up.
The volume of the interface where pressure = 2P is always constant, we don't lost energy
Each helicoid can be envelop with the 3P or P pressure. The green volume is near 0, it's only a film with the adequate pressure for each helicoid. The part of each helicoid where there is P or 3P pressure must be replace by the interface. If the film is very thin the pressure don't lost energy too.
I don't find the solution.
I add a new drawing for show how can be the thin film of pressure around helicoid.
For resume, that I think:
1/ Helicoids turn at the same speed in the same direction, so they don't move up/down.
2/ The interface with 2P pressure put a difference of pressure which want to turn helicoids in the same direction. This give energy
3/ The interface has always the volume = constant.
4/ The interface move vertically only.
5/ The interface is composed with 2 surfaces of helicoids and 2 surfaces of gaskets. Gaskets's surfaces are vertical so zero energy is needed for move up/down the interface.
6/ All system can be put under P pressure like that red helicoid don't need something for retain pressure.
7/ Black helicoid is under pressure 3P, this pressure can be retain by a very thin film of pressure (with a hard material and gaskets for retain pressure). The hard material is moving when the interface is coming. Like the film can be very small, this need to take off very small pressure. The volume of the black helicoid with 3P pressure is constant because the interface is moving (need to take off and need to put 3P pressure). This need zero energy in theory.
One or more points above must be wrong, have you an idea ?
I add a very small video for see two threads when they turn (I can't put more due to the limit). Maybe like this it's easier for explain where is the solution. Maybe if you have 2 wood screws you can test, screws turn at the same speed at the same direction. The interface move only up but like the surfaces of gaskets are vertical this don't require energy. Maybe the screw don't turn with a difference of pressure ?
Nobody can help me ?
  • · Replies 30 ·
  • · Replies 18 ·
  • · Replies 33 ·
  • · Replies 26 ·
  • · Replies 33 ·
  • · Replies 50 ·
