Complicated Catapult/Conservation of Energy Test Question
  • Context: Undergrad
  • Thread starter Thread starter ccmuggs13
    Energy Test
The discussion revolves around a physics test question involving a catapult, focusing on the application of conservation of energy principles and the calculation of elastic potential energy. Participants explore the relationship between linear and angular motion, the role of the spring constant, and the implications of different equilibrium positions on the system's energy dynamics.
  • One participant questions how to determine the compression of the spring (x) and presents two different methods for calculation, leading to differing results.
  • Another participant suggests that the displacement depends on the attachment point of the spring, indicating that the correct value for x could vary based on this detail.
  • Participants discuss the importance of the spring constant (2000 N/m) and how it affects the energy calculations, particularly in relation to the equilibrium position of the spring.
  • There is a consideration of whether to use linear or angular kinetic energy formulas, with one participant noting the test's focus on angular motion and the moment of inertia of the bar.
  • Concerns are raised about obtaining negative kinetic energy values, prompting discussions about the adequacy of the spring's energy to return the catapult to its equilibrium position.
  • One participant proposes a specific formula for calculating x based on trigonometric relationships, indicating a potential alternative approach to the problem.
  • A later reply discusses the conditions under which the arm of the catapult can swing past the equilibrium point, suggesting that it must be pulled down to a specific angle before release.
Participants express differing views on the correct method to calculate the spring compression and the implications of various equilibrium positions. There is no consensus on whether the spring has sufficient energy to return the catapult to its starting position, as some calculations yield negative kinetic energy values.
Participants highlight the dependence of energy calculations on the definitions of equilibrium used and the specific parameters of the system, such as the spring constant and the angles involved. Unresolved mathematical steps and assumptions about the system's configuration contribute to the ongoing uncertainty.
ccmuggs13
I just took a physics test today and there was one problem that I cannot figure out if I did correctly. The problem involves a catapult pictured here: http://i39.tinypic.com/a2t76h.jpg
The bar is 2m long and has a mass of 3kg. The rock at the end of it has a mass of 5kg. The spring is .3m from the pivot. As shown, when the spring is unstretched/uncompressed the bar makes an angle of 30° above the horizontal. It is then pushed down so it now makes an angle of 30° below the horizontal. My first question is what is the x for the spring when determining the elastic potential energy? Because I just set up triangles and figured it out to be .3m but my friend used the relationship between linear and angular distance, d=θr, and got x to be larger. But I believe that gives the arc length traveled by the end of the spring as it is compressed rather than how much it is actually compressed but I could be wrong. Here is a picture of what I think it is like: http://i44.tinypic.com/5zm6om.jpg
And so after you figure out what x is, what the problem asks for is the velocity of the rock as it passes back through the original position? (Using conservation of energy) So how would this be done and what is the answer? Because I ended up with a negative value while trying to find the answer meaning the spring did not have enough energy to get the catapult back to the starting position but this is probably wrong because that would be a dumb test question. Sorry this post is so long but please help! I've been going nuts trying to figure out what I did wrong!
The displacement would depend on where the other end of the spring is attached. If it's right bellow the point where it's attached to arm at equilibrium, your value of .3m is correct. I would go with that given no other information.
Do you happen to remember what the spring constant is? Also, is the equilibrium position equilibrium for the spring, equilibrium for unloaded catapult, or equilibrium for loaded catapult? Each of these would give you different results. In the final case, the speed will be maximum through equilibrium. But in the first two cases the kinetic energy might work out to be negative if the spring coefficient was too low.
The gravitational potential energy as function of angle looks like this.
[tex]U = sin(\theta)\frac{1}{2}mgL + sin(\theta)MgL[/tex]
Kinetic energy as function of velocity.
[tex]T = \frac{1}{6}mv^2 + \frac{1}{2}Mv^2[/tex]
Where L is the length of the arm, m is mass of the arm, M is mass of the boulder, and v is velocity of the boulder. The angle is measured from horizontal.
Assuming equilibrium is equilibrium for the spring, the rest is easy. Add spring potential to gravitational potential at lower point, subtract of gravitational potential at the equilibrium point, and that's your kinetic energy. Solve for v, and you're done. If some other equilibrium condition is meant, you'll have to correct for it.
Oh yea I completely forgot about the spring constant, it was 2000N/m. And the equilibrium position is equilibrium for the spring.
Also can you use the linear kinetic energy formula for this? Because a large portion of our test involved angular velocity and the problem gave us a hint reminding us of the formula for the moment of inertia of a bar about its end so I assumed we needed to use angular velocity and kenetic energy and such.
Oh I think I see that you did take angular motion into account as opposed to just linear which is why you have the kinetic energy of the bar start with 1/6 as opposed to 1/2
But unless I am doing my calculations wrong I am still getting a negative kinetic energy... Please check the calculations. This is a very dumb question if the spring really does not have enough energy to return to equilibrium
I think x=2(.3)tan30° since Cos30°=-Cos30°
If you remembered all the numbers correctly, and the equilibrium is equilibrium for the spring, you are absolutely correct. Here is a plot of kinetic energy as function of angle. The points where the curve crosses zero are turning points. The angles are in radians. So the arm will get just a little past 0°, and then start coming down again, never reaching the equilibrium point. To get the arm to swing past equilibrium, you must pull the arm down past -60° before firing.
  • · Replies 39 ·
  • · Replies 51 ·
12K
