Time variant RC and RL circuits
  • Context: Engineering
  • Thread starter Thread starter Badger33
    Circuits Rc Time
This discussion focuses on the behavior of time-variant RC (Resistor-Capacitor) and RL (Resistor-Inductor) circuits, particularly under different conditions of switching. Key points include the conditions under which capacitors and inductors act as open circuits, short circuits, and voltage/current sources. For capacitors, at t=0- it acts as an open circuit, at t=0+ as a short circuit, and at infinity as a voltage source. For inductors, at t=0- it behaves like a short circuit, at t=0+ as an open circuit, and at infinity as a current source. Understanding these principles is essential for analyzing circuit responses over time.
  • Understanding of RC and RL circuit fundamentals
  • Knowledge of time-domain analysis in electrical circuits
  • Familiarity with differential equations related to circuit analysis
  • Basic concepts of steady-state and transient responses
  • Study the derivation of the initial-final response equations for RC and RL circuits
  • Learn about the Laplace Transform for circuit analysis
  • Explore the concept of reactance in AC circuits, specifically for capacitors and inductors
  • Investigate the application of Kirchhoff's laws in time-variant circuits
Electrical engineering students, circuit designers, and anyone involved in analyzing or designing time-variant RC and RL circuits will benefit from this discussion.
Badger33
Ok so I have some topic overview questions. I think I am on the right track but would like to make sure I am thinking about this the correct way.
When I say time variant I simply mean there is a simple switch in the circuit. This is link to a were I found my supplemental material and it has a switch like I am talking about. http://www.allaboutcircuits.com/vol_1/chpt_16/2.html
Question 1:
Under what conditions does a Capacitor act like (A) an open circuit? (B) a short circuit? (C) a voltage source?
Question 2:
Under what conditions does an Inductor act like (A) a short circuit? (B) an open circuit? (C) a current source?
MY ANSWERS:
1a) at t=0-
because initially fully discharged thus empty and open circuit
1b) at t=0+
because the V across would be 0 thus short circuit
1c) at ∞
because capacitors remember/store voltage thus voltage source
2a) at t=0-
because initially like nothing is there thus short circuit
2b) at t=0+
because the I across would be 0 thus an open circuit
2c) at ∞
because inductors remember all current sources thus would act like a current source
SOME ADDITIONAL QUESTIONS:
When we look at initial-final response equations:
y(t)=yF + (yi - yF)e-t/τ
y=v,i as asked fot
yi=y(0+)
yF=y(∞)
τ= RC or L/R depending on the circuit
3) How do you find y(0+) for a capacitor?
4) How do you find y(0+) for current through an inductor?
5) How do you find y(0+) for voltage on a resistor?
6) How do you find y(∞)?
I do not know the answer to 3-6. I am obviously kind of confused when it comes to the addition of the on/off switch into the circuit network.
HELP on the 0+, 0- and ∞ times would be great!
Simple my friend...
Resistance or reactance of a capacitor is 1/JWC
Reactance of an inductor is JWL
Current thru a capacitor is C*dv/dt=i(t)
Voltage across an inductor is L*di/dt=v(t)
W= radians per second...or 2*pi*frequency.
Draw a circuit with a battery source and a capacitor and resistor in series.. Find the current at steady state...W=0 in a battery...so you have infinite resistance across capacitor at steady state. Voltage across cap will equal battery since there is no voltage drop across resistor.
Draw same circuit with inductor and resistor in series. W=0 in battery...zero resistance...short circuit. Zero voltage across inductor...voltage across resistor will equal your battery.
Draw cap circuit now with AC source (leave out resistor for ease of learning) Plug in your frequency into 1/JWC...use V=IR to find current. Record your answer.
Draw inductor circuit with AC source. (leave out resistor for ease of learning) Plug in your frequency into JWL...use V=IR to find current. Record your answer.
Now draw the same cap and inductor circuits again with an AC source...try 170sin(377t) Now use C*dv/dt=it and L*di/dt=v(t). IN other words take the derivative of that voltage source...You should get the exact same answers as the ones you recorded.
To gain a clear understanding of what you are doing, you need to absorb what I just wrote. If you get my drift...all your above questions will be answered. Understanding steady state is key...then the transient part is just a matter of plugging and chugging into the transient formulas available to you.
for that circuit, imagine that the capacitor is fully discharged.
Q=VC says that the voltage across a discharged capacitor is zero, and since the switch is open no current flows, so no voltage across R. when the switch is closed, at t=0 there's now 15V across R and C, but no charge has built up in C, so it must all be across R.
its at this point that C acts like a short circuit, and I flows through R to satisfy ohms law.
that current charges C, so over time a V builds across the capacitor. note that this voltage counteracts the supply voltage, and V across R is reduced, consequently I is reduced, and the rate that the capacitor charges is reduced. this is the i(t) = C*dv/dt differential equation.
after a long time I is (almost) 0. this happens when the capacitor has enough charge that
the voltage matches the supply voltage. at this point, there is no voltage across the resistor, so no current flows. at this point the Capacitor acts like an open circuit.
