sophiecentaur
Homework Helper
- 30,525
- 7,515
There is a direct similarity between light emerging from a narrow slit and being diffracted into a wide (180degree) beam and the signal from a radio antenna (vertical dipole / omnidirectional). The detection of the illumination pattern of the screen by the light depends as much on the sensitivity of the light measuring equipment (your eye) as it does on the right tuning of the radio receiver. In the one case we have two slits with coherent light hitting them from behind (essential) and in the other case we have two antennae fed with the same RF signal (the two transmitted signals are also coherent). The pattern with one experiment can be an exact scale model of the pattern with the other if you get the ratios of dimensions and wavelengths right. I we assume that the receive antenna has a wide directivity - just the same assumption as for the projector screen.fimaun said:Let's forget about the 'particle-like' nature once for all then.
I am not sure how one can take this example as an equivalent one to the double-slit experiment. For it to be so, whether a given antenna emits or not would depend on the receiver. Depending on where the receiver would be, an interference pattern would be received or just a single-wave one. And if one receiver able to receive only a single-wave pattern does receive it, then a second observer in principle able to see an interference pattern wouldn't have a chance to see it.
Am I right?
Does that address your problem? (I think that must be your point.)
Don't forget, this is the basic principle of all directional radio antenna arrays.
