Is it possible for all truths to be known?
  • Thread starter Thread starter lugita15
The discussion centers around the philosophical question of whether all true statements are knowable, specifically through the lens of Fitch's Paradox of Knowability. Participants explore the implications of unknown truths and the nature of knowledge, touching on modal notions such as knowledge, possibility, and morality.
  • Some participants present Fitch's Paradox, arguing that if there exists an unknown truth, then there must also be an unknowable truth, challenging the idea that all truths are knowable.
  • Others question the initial hypothesis of an unknown truth, suggesting that it is nonsensical to call something a truth if it is unknown.
  • One viewpoint emphasizes that for a proposition to be true, it must be verifiable, arguing against the existence of unknowable truths.
  • Another participant highlights the distinction between knowledge and belief, asserting that knowledge requires justification and cannot coexist with unknowability.
  • Some participants express confusion over the concept of an unknown truth, questioning how one can assert the existence of a truth without knowing it.
Participants express differing views on the validity of the hypothesis regarding unknown truths. While some find the concept plausible, others argue it is fundamentally flawed, indicating a lack of consensus on the matter.
The discussion reveals limitations in the definitions of truth and knowledge being used, as well as the assumptions underlying the arguments presented. The varying interpretations of what constitutes a truth and the criteria for knowability remain unresolved.
  • #31
I think the term "knowable" is more relevant than "known" here. But it doesn't change the fact that nonsensical propositions cannot be knowable.
  • #32
Now that we're done on that one, I wonder where lugita15 got to. Interested to hear more of his/her modal paradoxes
  • #33
Sure, I can go on to other ones. (And it's a he by the way.) But let me first explain my preferred resolution to Fitch's paradox. I came up with it on my own soon after reading about the paradox a while back, but then I later found out that Joseph Melia thought of more or less the same solution in 1991; see the attached paper. The key idea is this: Fitch's "argument presupposes that we can discover a statement's truth value without affecting that statement's truth value. But this is not so: there exist statements which are true, yet which would have been false had we performed the procedures necessary to discover that statement's truth value."
To illustrate this point, suppose for sake of argument that it were possible for someone to be omniscient (i.e. knowing literally everything) but that no one was actually omniscient. Now consider the statement "No one is omniscient." That would be a true statement. But could it be known? Well, since we're assuming that omniscience is possible, by definition it would be possible for someone to know literally all true statements. But in that case "no one is omniscient" would not be a true statement, so it obviously wouldn't be known. So the thesis "all truths are knowable" doesn't make much sense, only because if the truth value of some true statements were found out they would no longer be true, and thus no longer be in the set of statements people can know (because you can't know a false statement).
So how do we remedy that? Surely "all truths are knowable" does try to capture some sensible and debatable sentiment, namely the belief that there are no limits to human knowledge. A better way of expressing that sentiment, one that does not fall victim to Fitch's paradox, is to say, "all truths are verifiable" or to put it another way "the truth value of any statement is knowable". To put it in more formal language, "For all statements P, either P is knowable or not P is knowable." You might think that that's equivalent to "For true statements P, P is knowable and for all false statement P, not P is knowable." But that's not true. Because your knowledge of the truth value of P may change the truth value of P (e.g. "the statement "there is no light in the room" becomes false if you turn on the light to test whether there's any light in the room!). But the important point is that Fitch's paradox allows for the possibility that you can find out the truth value of any statement, and if that's the case then surely it does not put any limitations on human knowledge.
Does that make sense to everyone? If not, look at the attached paper, and if you still have questions I'm happy to try and clarify matters.
  • #34
Hurkyl said:
The Knowability Principle from your link:
[tex]\forall p: (p \to \diamond Kp)[/tex]​
is highly implausible:
  • If we assume two-valued truth semantics, then this seriously opposes the various incompleteness results of logic.
  • No, contrary to popular belief Godel's theorem does NOT say there is a single statement that is undecidable in all sufficiently strong axiomatic systems. Rather, it says that for each sufficiently strong axiomatic system, there exists a statement in that system, but easily decidable in other systems. To conclude that there exist absolutely undecidable statements requires more work and assumptions, as Godel outlined in his famous Gibbs lecture; see here or the attached paper. (Personally I think the attached Shapiro paper is a more interesting read than the linked Feferman paper.)
  • #35
Now for another modal paradox. This one is pretty simple and unlike Fitch's paradox, where I heavily insisted that it wasn't just a simple case of word play, this one can more justifiably be called playing with words (although it can still be expressed in symbolic form). It goes as follows: Benjamin Franklin was the inventor of bifocals, glasses that correct for both near-sightedness and far-sightedness. And since he was the inventor of bifocals, e.g. Albert Einstein was not the inventor of bifocals. But we can readily imagine alternate histories in which all kinds of things happened, like the Confederates winning the civil war or Japan not attacking us on Pearl Harbor. Similarly, we can say that although Benjamin Franklin invented bifocals, he did not have to be; someone else could have done it instead. So we can say "It is possible that Benjamin Franklin did not invent bifocals."
But there's nothing special about Ben, is there? It's also true that we can think up alternative histories in which Albert Einstein did not invent bifocals; in fact, we don't even need to go to alternate histories, because in our actual world Einstein didn't invent them! So it's fair to say "For all persons X, it is possible that X did not invent bifocals." Particular instances of that general thesis are "It is possible that William Shakespeare did not invent bifocals" or "It is possible that the discoverer of general relativity did not invent bifocals." So far so good? But let's say we make the particular substitution X="the inventor of bifocals." Then our statement reads "It is possible that the inventor of bifocals did not invent bifocals." But that seems absurd, doesn't it? Surely the inventor of bifocals invented bifocals, so what's going on here?
As I said, this is a much simpler paradox to resolve. For a hint, try solving it along similar lines as my preferred resolution to Fitch's paradox, outlined above.
  • #36
Of course; the proof of this is trivial: given any undecidable statement P in a theory claimed to be absolutely undecidable, simply construct a new theory by adding P as an axiom. Contradiction!
And, in particular, Godel's theorem applies to any (computable) scheme for constructing a sequence of progressively more inclusive axiomatic systems.
But don't forget we're talking about the informal notion of "known"; even if we assume there is a notion of objective truth, given our knowledge of incompleteness theorems, what sort of scheme could possibly produce any objective through and still be plausibly called "known"?
(the only loopholes I can imagine require some sort of temporal logic; e.g. depend on us having a non-deterministic oracle we have absolute faith into give us new "known" statements, which have a chance of producing any truth sometime in the future. But then, is that really plausible?)
  • #37
I do see where you're coming from. Allow me to tell you how it runs with me.
Your statement .. suppose for sake of argument that it were possible for someone to be omniscient (i.e. knowing literally everything) .. seems contradictory. I cannot believe that a person, with a limited brain, intelligence, life span, etc (i.e., finite), can ever literally know everything (i.e., infinite). Can you even imagine someone having infinite knowledge ? He would need an infinite space to put it all in, and probably, an infinite span of time to assimilate it - particularly given that new and further knowledge of infinitely more things and events would be coming up all the time.
Thus, the juxtaposition of 'person' and 'omniscient' in the real world, is to me nonsensical, and if I supposed it, would simultaneously suppose that anything flowing from it would be also.
We cannot take a term such as 'someone', i.e., a human being, and suppose upon him omniscience, because for a start, that is not the ordinary definition of a person. And BTW, I was interested to read on another thread, where a contributor was railing against too narrow a definition of words on these forums, another contributor pointed out that these forums rules require for words to be used only in accordance with their dictionary meaning. And in no dictionary will you find omniscience as a description of a normal person.
Now, I'm NOT trying to pull rules here - I'm sure I sail against the wind myself on the odd occasion. And I do like the odd flight of fancy myself. But it IS a flight of fancy to say 'suppose someone is omniscient'. No logical discourse can follow from that.
I personally believe that these paradoxes (certainly the one in question) arise from different folk attributing different meanings to words - a nuance here, an inflection there, a not so subtle leap of faith elsewhere .. before you know it - confusion and chaos.
But anyway, I do enjoy the interaction and thinking about these things, and by no means am I trying to assert a superiority of view here - I'm just sayin' how I see it.
PS - will read the one on #35 soon.
  • #38
It was just a hypothetical situation designed to illustrate my point. But if things like infinite knowledge trouble you, just imagine a simpler world in which there were, say, only 50 or a 100 truths to be known. Then surely you can imagine not all of the truths being known but it would be possible for you to learn all of them.
People use fantastical examples to illustrate logical or philosophical points all the time.
That can't possibly be the case, at least not in the sense you're thinking of, because Fitch's paradox can be put into unambiguous symbolic language.
I look forward to your thoughts on it. As I said, it's a pretty simple one, so hopefully we can settle it fairly quickly and move to yet another one.
By the way, did you read the Melia paper I attached in post #33?
  • #39
It is again nonsensical, and takes us right back to the start. To know there are (say) 100 truths to be known, means that you must know they are truths, else, you couldn't call them truths - could you ? How could you call them truths up front if you didn't know they were that ?
Ergo they are not unknown truths, but known truths. Unless of course, you reply that you defer to a higher authority who knows they ARE truths even if you don't, in which case I go straight to that higher authority (but I don't think you're saying that).
Yes, using fantastical examples certainly does broadens the options, doesn’t it ? Did you have some examples of using fantastical examples to arrive at logical truths, other than by accident, or by the use of metaphor, parable, simile, etc ?
I think it is very true (my earlier statement about fluid use of language). As an overt example, consider this;
Nothing is better than complete happiness in life. A strawberry ice cream cone is better than nothing. Therefore, a strawberry ice cream cone is better than complete happiness in life. But surely it isn't. So have we stumbled upon some deep metaphysical, paradoxical mystery here, or is it just fluid use of language - in this case, that word singularly least disabused of ambiguity, 'nothing' ?
Also, you mentioned symbolic language before. Do I have to learn a new language to 'grok' with you ? Modern English is a very fine and complex language - as good as any. I know it well, and you seem to be adequate in it :-)
To defer to a more obscure or symbolic language, hints of a dodge to me. Fitch's paradox must stand on it's own two feet as it were .. that being the language in which it's presented. And it still clearly to me, nothing more than word play. I repeat part of our earlier dialogue;
You said ; .. So to review, we started with the hypothesis that P is an unknown truth .."
I replied .. "But even at the start, that hypothesis seems a little shaky .."
Nothing further to this has really been added, so far as I can discern.Tell me - what do you really think Fitch's paradox is doing ? You said earlier that you heavily insisted it wasn't just a simple case of word play. So is it revealing some deep metaphysical truth ? Some new science ? Some unknown mystery or secret ? Some undiscovered incongruity in or of human existence, of knowledge... or WHAT ? I'd really like you to give me a specific answer to this question, and in the language we are presently using.
I will dowload it now.
  • #40
Again, some lassitude of, umm, 'crisp' word meaning here.
It WAS possible that BJ did not (or would not) invent bifocals. But he did as it turned out. So it is IMPOSSIBLE that BJ did not invent bifocals, because he DID.
  • #41
It's easy. As a simple example, if I have a standard deck of cards, I know exactly one of the following statements is a truth:
  • The first card is the ace of spades
  • The second card is the ace of spades
  • The third card is the ace of spades
And yet, I cannot identify any particular statement as being a truth.
If I didn't know the deck was standard, there is still exactly one truth among those statements, but I wouldn't even know that!
  • #42
I'm not saying that you know that these specific 100 truths were there to be known. I'm just saying, consider a hypothetical world in which there were only a hundred truths to be known. In such a world, it might be easy for someone to know everything, but it might just happen to be the case that they don't know everything.
I'm not using a fantastical example to PROVE a logical point. I'm using it to illustrate a logical point.
Yes, that is really just playing with words, because the word nothing is ambiguous. But Fitch's paradox is not just playing off of an ambiguity in this trivial sense.
But the thing is, English is full of ambiguities and vagaries, so you might assume that Fitch's paradox arose from one of those flaws of the English language. But in fact, Fitch's reasoning can be expressed in the language of symbolic logic, where there is no room for ambiguities or semantic tricks. I'm not asking you to learn the symbolic language (although it's not too hard to learn), just to trust me that the reasoning still works when you translate to the symbolic language, so Fitch's paradox is not as trivial as you might think.
But I've given you examples, like the number of hairs on Obama's head, which you've dismissed them as absurd. But the thing is, reductio ad absurdum doesn't mean that anything you feel is absurd should just be dismissed. The "absurd" part in the context of reductio ad absurdum means getting an actual contradiction, like a statement of the form "P and not P". Absurd in this logical context does not just mean anything you find wacky or silly.
And if you don't like my examples, what about Hurkyl's example of the playing cards in post #41?
If Fitch's paradox had no resolution, then it would reduce the arguable statement "all truths are knowable", which conveys the sentiment that there are no limits to human knowledge, to the naive statement "all truths are known". Thus from the weak assumption that humans do not know all the truths they could know, Fitch's paradox would somehow be able to place fundamental barriers on the reach of human knowledge.
But at least in my opinion, the reasoning given in Melia's paper (which as I said I thought of independently) satisfactorily resolves Fitch's paradox. So in my view, all Fitch's paradox tells us is that the statement "all truths are knowable" is a bad way of representing the claim that there are no limits to human knowledge.
OK, I look forward to hearing your thoughts on it.
  • #43
OK, if that bothers you feel free to change all my instances of "it is possible" to "it was possible". That's not the important part of the reasoning.
  • #44
That's a good example!
By the way, have you had a chance to look at the paradox I outlined in post #35?
  • #45
lugita15 said:
That statement you quoted isn't a paradox at all. It's just an assumption used in the paradox.
We're not talking about you asserting "P is an unknown truth." Here is the logic of the paradox again.
We start with the assumption that there is some truth P which is unknown to you, but perhaps known to others. Now consider the statement Q, which says "P is a truth unknown to you." By assumption, Q is true. Now the question is, can Q be known to you? Well, suppose that Q were known to you. Then you would know the statement "P is a truth unknown to you". But if you knew that, you would know that P is true and that P is unknown to you, or in other words P would be both known to you and unknown to you, which is impossible. Thus the supposition that Q is known to you leads to a contradiction, and thus it is impossible for Q to be known to you, or in other words Q is unknowable to you. Thus we can disprove the thesis that all truths are knowable to you.
Sorry, If I missed something by not following the whole thread. But the thread looks like cycling around anyways. :)
lugita15 said:
assumption that there is some truth P which is unknown to you,but perhaps known to others.
Good, enough assumption, I accept that.
Re-writing: Q = "There exist some truth P, which is unknown to you (but may be know to others". If this Re-writing is allowed, then
Q, just repeats our assumption. So, it must be true. (Because, Assumption means we take it to be true for granted)
Well, Q = Our assumption. We got to know our assumption when working on a problem, don't we? :)
Well, it was assumed, so we have been knowing it all way along.
If I knew my assumption (which is what you are referring by the word 'that'), I would know that there exist some truth P, which is unknown to me. I would know nothing whatsoever about what the truth exactly is.
I can't understand how you jumped to the conclusion that P is known to me? The only thing known to me is my assumption, which states that there exist some truth P, which is unknown to me.
To my knowledge, P is just an unknown variable (like the x in algebra). I am yet to solve the puzzle and find out what particular truth P contains.
I am not a philosophy student, but just sometimes get interested in such things.
  • #46
lugita15 said:
I'm not saying that you know that these specific 100 truths were there to be known. I'm just saying, consider a hypothetical world in which there were only a hundred truths to be known. In such a world, it might be easy for someone to know everything, but it might just happen to be the case that they don't know everything. I'm not using a fantastical example to PROVE a logical point. I'm using it to illustrate a logical point. Yes, that is really just playing with words, because the word nothing is ambiguous. But Fitch's paradox is not just playing off of an ambiguity in this trivial sense. But the thing is, English is full of ambiguities and vagaries, so you might assume that Fitch's paradox arose from one of those flaws of the English language. But in fact, Fitch's reasoning can be expressed in the language of symbolic logic, where there is no room for ambiguities or semantic tricks. I'm not asking you to learn the symbolic language (although it's not too hard to learn), just to trust me that the reasoning still works when you translate to the symbolic language, so Fitch's paradox is not as trivial as you might think.But I've given you examples, like the number of hairs on Obama's head, which you've dismissed them as absurd. But the thing is, reductio ad absurdum doesn't mean that anything you feel is absurd should just be dismissed. The "absurd" part in the context of reductio ad absurdum means getting an actual contradiction, like a statement of the form "P and not P". Absurd in this logical context does not just mean anything you find wacky or silly.
And if you don't like my examples, what about Hurkyl's example of the playing cards in post #41? If Fitch's paradox had no resolution, then it would reduce the arguable statement "all truths are knowable", which conveys the sentiment that there are no limits to human knowledge, to the naive statement "all truths are known". Thus from the weak assumption that humans do not know all the truths they could know, Fitch's paradox would somehow be able to place fundamental barriers on the reach of human knowledge.
OK - I don't disagree with your view (underlined). Other than this, to comment any further on the above would only be repeating what we've discussed earlier.
I still maintain that I do not believe there is such a thing as an unkown truth - at least if not reduced to the absurd. I'm not deliberatley being obstinate about this - I really haven't seen any proof of any unknown truth here. Will try to address Hurkyl's post soon.
  • #47
The conclusion to this 'paradox' is that "it is possible that Benjamin Franklin did not invent bifocals."
My response was that it may have been possible at one time, but now it isn't, because manifestly, he did. So the conclusion is wrong.
It is IMPOSSIBLE that BF did not invent bifocals.
  • #48
And I told you, feel free to substitute "it was possible" for "it is possible".
  • #49
Wrt to Fitch's paradox we can just assume that all truths aren't necessarily knowable ... which seems to be a most reasonable assumption.
  • #50
But the thing is, even if there are unknowable truths, one would not expect so trivial a disproof of an arguable viewpoint like the belief that all truths are knowable. For my preferred resolution to this, see post #33 and the paper attached with that post.
  • #51
Having set up the initial finite alternatives (standard deck) of course one of them is the ace of spades. There is nothing, no unknown truth here. You'll know it in up to 52 guesses. Similarly, I could make, say, 50,000 guesses about the number of hairs on Obamas head, and I'm sure I'd get it right.
If you didn't know the deck was standard, how would you know if it contained an ace of spades ?
  • #52
I did - again, you said;
Wrong conclusion. It WAS possible that BF did not or would not invent bifocals (before he did so) but when he did invent bi focals, he invented them.
Therefore, it is now IMPOSSIBLE that BF did not invent bifocals.
Glad we got that sorted.
Next !
  • #53
Underlined .. yep - that's part of what I've been trying to say all along. I think it arises from a degree of word play.
  • #54
You're interchanging "asserting P to be true" with "knowing P to be true" here
  • #55
Sorry, a lot of your confusion is because I didn't word things well enough. The "you" that I'm discussing the argument with is different from the "you" whose knowledge we're discussing. So instead of using "you", let me call the individual John, and let me restate the argument in that way.
Assume that the truth P is unknown to John. Let Q be the statement "P is a truth unknown to John." The question is, is Q knowable by John? Well, suppose Q were known to John. Then John would know that P is a truth unknown to him. But if he knew that P is a truth, that's the same as knowing P. So he would know P and he would know that P is a truth unknown to him. But if he knew P, then it would be incorrect to say that P is a truth unknown to him, so Q would be false, and you can't know a false statement. Thus from the supposition that Q were known to John we get a contradiction, so it must be impossible for John to know Q. Hence Q is a truth unknowable by John, and therefore not all truths are knowable to John. Now do you get it?
  • #56
You literally don't think there are any true statements that are unknown? Don't you think the results of the 2016 US Presidential election are unknown? When you flip a coin in the air, don't you think it's unknown which side it will land on?
  • #57
Perhaps you'll know it after you check each one of your 52 guesses, but do you agree that right when your handed the deck you don't know which place the Ace of Spades is? So if the Ace of Spades is in the 10th place, then at that moment wouldn't "The Ace of Spades is in the 10th place" be an unknown truth?
  • #58
How many times do I have to say this? You can change "it is possible" to "it was possible" if you want. That's not the important part of the logic. Let me change it myself, so there's no confusion.
Benjamin Franklin invented the bifocals. But we can imagine alternative histories, so we can say "It was possible for Ben Franklin to not have been the inventor of bifocals". And for any person X, we can say "It was possible for X to not have been the inventor of bifocals." For instance, X can be "William Shakespeare" or "The inventor of special relativity" or "The eighth president of the United States", etc. Thus we can let X = "the inventor of bifocals" and thus we reach the conclusion "It was possible for the inventor of the bifocals to not have been to inventor of the bifocals." But that seems absurd, because obviously the inventor of bifocals had to be the inventor of bifocals. How can you have the inventor of bifocals not be the inventor of bifocals?
Now do you understand the paradox?
  • #59
My gut feeling says that the resolution of the paradox is that the bifocals don't have to be invented, so assuming there is an inventor is a fallacy. However the way that it's worded makes the whole premise absurd
If the statement "it was possible for the inventor of the bifocals to not invent the bifocals" is a paradox, then the statement "it was possible for Benjamin Franklin to not invent the bifocals" is the exact same paradox, because Benjamin Franklin IS the inventor of the bifocals (so you can freely substitute 'inventor of the bifocals' for him).
  • #60
"The inventor of bifocals" is a well-defined* 'variable constant'.
The informal argument that "it is not necessary that X invented bifocals" makes critical use of X being a non-'variable' constant. Roughly speaking, it boils down to observing "X does not vary with 'the inventor of bifocals'", and therefore it is possible for "X" and "the inventor of bifocals" to be different.
The argument, of course, doesn't work if X is a constant that does vary along with 'the inventor of bifocals'.*: Ignoring the technicalities of whether there is an inventor and it is unique
  • · Replies 64 ·
  • · Replies 17 ·
  • · Replies 22 ·
  • · Replies 16 ·
