Standing waves, frequency, wavelength and speed D; Help
The discussion focuses on calculating the wavelength of interfering waves in a standing wave scenario with a frequency of 10.0 Hz. The distance between the third and sixth nodes is given as 54 cm. Using the relationship between nodes and wavelength, it is established that the distance between nodes is equal to half the wavelength (1/2λ). Therefore, the wavelength (λ) is determined to be 36 cm, as it is twice the distance between the nodes.
  • Understanding of standing waves and nodes
  • Knowledge of wave frequency and wavelength relationships
  • Familiarity with basic wave equations (v = fλ)
  • Ability to convert units (e.g., cm to meters)
  • Study the properties of standing waves in different mediums
  • Learn about wave speed calculations in various contexts
  • Explore the effects of tension and mass on wave frequency in strings
  • Investigate real-world applications of standing waves in musical instruments
Students studying physics, particularly those focusing on wave mechanics, as well as educators looking for examples of standing wave calculations.
milliex51
What is the wavelength of the interfering waves?
Standing waves are produced in a string by sources at each end with a frequency of 10.0 Hz. The distance between the third node and the sixth node is 54 cm.
a) What is the wavelength of the interfering waves? b) What is their speed?
I believe I should use: T= 1/f, v=λ/T or v=fλ or v=Δd/Δt
Using those equations, write out what each symbol is and what the given value in the question for that is:
Wavelength (λ) = ?
Frequency (f) = 10Hz
It should be more clear then.
Remeaber that the distance between a node and its nearest a connecting node is equal to 1/2λ. Hope this helps :)
