Trig Integration Discrepancy in Fourier Series Analysis
  • Thread starter Thread starter NewtonianAlch
    Integral Trig
The forum discussion centers on discrepancies in the results of Fourier Series integrals used in Circuit Analysis, specifically regarding the integration of piecewise functions defined as f(t) = 5 for 0 < t < 1 and f(t) = 10 for 1 < t < 2. The user confirmed their calculations using MAPLE, which produced results that differed from the solutions manual. The MAPLE output was 5(1 + cos(1/2 nπ) - 2 cos(nπ))/(nπ), while the book provided an alternative answer that led to inconsistencies in subsequent calculations and plots.
  • Understanding of Fourier Series and their application in Circuit Analysis
  • Proficiency in using MAPLE for mathematical computations
  • Knowledge of trigonometric identities, particularly cos(nπ) and cos(nπ/2)
  • Familiarity with piecewise functions and their integration
  • Research the properties of Fourier Series in Circuit Analysis
  • Learn advanced techniques for using MAPLE in solving integrals
  • Study trigonometric identities and their implications in Fourier analysis
  • Explore common errors in Fourier Series calculations and how to avoid them
This discussion is beneficial for students and professionals in electrical engineering, particularly those focusing on Circuit Analysis and Fourier Series, as well as anyone using MAPLE for mathematical modeling and analysis.
NewtonianAlch
This question is part of Fourier Series in Circuit Analysis. There were fairly straightforward integrals which I calculated and confirmed using MAPLE to be correct, however the book gives somewhat different answers. I would presume that what I did was correct and the solutions manual made an error, however since it's a fairly large question with answers being carried forward I want to make doubly sure. Sorry about the size of the images, I will remove them after the problem
This is the integral essentially, the definite integral from 2 to 4 is left out because it's zero,
http://img189.imageshack.us/img189/1379/dsc0007ob.jpg
cos (Pi/2) = (-1)[itex]^{\frac{n-1}{2}}[/itex]
cos (Pi) = (-1)[itex]^{n}[/itex]
My answer came to this:
http://img542.imageshack.us/img542/7613/dsc0008ryz.jpg
EDIT: cos(nPi/2) goes to (-1)^n/2 - still doesn't reconcile my answers with the book though.
The MAPLE output was:
[itex]5\,{\frac {1+\cos \left( 1/2\,n\pi \right) -2\,\cos \left( n\pi <br /> \right) }{n\pi }}[/itex]
The answer in the book was (last line before the table):
http://img600.imageshack.us/img600/9624/dsc0009cm.jpg
As you can imagine, because the answers are different, the values in the table are going to be different and hence whatever I have to plot afterwards will be different.
##(-1)^{integer}## cannot produce any zeros, it can only produce +1 or -1. So it doesn't replace ##cos(n \pi / 2)##.
I should have been clearer, cos (n*Pi/2) is replaced by (-1)^n/2
So if n = 3, I'm guessing that term is ignored because you can't compute that. At least that's the identity they gave in the book.
  • · Replies 26 ·
