Heat Transfer Through SS Corrugated Tubing
  • Thread starter Thread starter greatbigsea26
    Heat Heat transfer
The discussion focuses on utilizing flexible stainless steel corrugated tubing as a heat exchanger immersed in a tank. The user seeks technical data beyond surface area and conductivity coefficients, emphasizing the importance of surface area in heat exchange efficiency. They propose that one meter of corrugated tubing, with double the surface area of smooth tubing, could function equivalently to two meters of smooth tubing for heat exchange purposes. The user has reached out to the manufacturer for more information but has not yet received a response.
  • Understanding of heat exchanger principles
  • Familiarity with thermal conductivity coefficients
  • Knowledge of surface area calculations for tubing
  • Experience with stainless steel properties
  • Research heat transfer calculations specific to corrugated tubing
  • Explore thermal conductivity data for stainless steel
  • Investigate existing heat exchanger design software
  • Review technical datasheets for similar heat exchanger materials
Engineers, thermal system designers, and anyone involved in heat exchanger design and optimization will benefit from this discussion.
greatbigsea26
I am looking to utilize flexible stainless steel corrugated tubing similar to this:
http://www.pipesystems.com/site/index.cfm?id_art=24995&vsprache=EN
as a heat exchanger immersed in a tank but have been having a tough time locating technical data on it other than the "surface area" and of course the conductivity coefficient of steel. Do any of you know any way I could find out anything about the heat exchange this type of piping? I contacted the manufacturer in the above link but have yet to receive a response. Does there exist some type of calculation or data sheet I could use?
Thank you for your help
I don't know how accurate you need to be. As a first guess, I would say that surface area is the dominant property. Therefore, if one meter of corrugated tubing has twice the surface area as one meter of smooth tubing, I would say that it is equivalent to two meters of smooth tubing for heat exchanger purposes.
You can find tables and calculators for smooth tubing.
  • · Replies 34 ·
