How to Locate the Center of Gravity
The discussion revolves around locating the center of gravity (COG) for objects made of different materials, particularly in the context of structures that may be homogeneous or non-homogeneous. Participants explore methods for calculating the COG, including integration techniques and weighted averages, while seeking clarification and examples to better understand the concepts involved.
  • Homework-related
  • Siukwok questions whether a homogeneous structure means it is made of the same material and how to find the COG for non-homogeneous elements.
  • Some participants clarify that a homogeneous object has constant density and suggest integrating density to find the mass for non-homogeneous objects.
  • HallsofIvy provides a formula for calculating the COG using integrals and discusses finding the COG of multiple uniform pieces through a weighted average based on mass.
  • Siukwok presents a specific example involving two cuboids of different densities and dimensions, asking for guidance on locating the COG of the combined object.
  • Another participant suggests finding the center of mass of each block and then using their coordinates and masses to calculate the overall COG using a weighted average approach.
Participants generally agree on the methods for calculating the COG, but there is no consensus on the specific application to Siukwok's example, as further clarification and examples are requested.
Participants express a need for examples to fully grasp the application of theoretical concepts, indicating that the discussion may involve assumptions about the simplicity of the geometry and the nature of the materials involved.
siukwok
Hi,
I have some questions regarding on the locating of the center of gravity. I have read some txtbk regarding on finding the COG for structure/element that is homogeneous. Therefore, the COG will conincide with the centroid of the the volume. Am i right to say that homogeneous structure/element means that it is made up of the same material? How am i supposed to find the COG if the element is made up of different materials? Lastly, if i know the COG of several components (of different materials) which are subsequently fixed together, am i right to say that it has to be treated as a problem in relation to non-homogeneous element? My boss has tasked me to find out how this is done but i have difficulties finding relevant reading materials for the above problems. Your help is greatly appreciated.
Thanks!
Siukwok
Yes, saying that an object is "homogeneous" means it made of the same material throughout so, in particular, the density is constant. if the objecft is not homogeneously but the density varies continuously, and the geometry of the figure is reasonably simple, you can try integrating the density to find the mass: [itex]M= \int\int\int_V \rho dV[/itex] where [itex]\rho[/itex] is the density funcdtion.
Then the x, y, and z coordinates of the center of mass are given by
[tex]\overline{x}= \int\int\int x\rho dV/M[/tex]
[tex]\overline{y}= \int\int\int y\rho dV/M[/tex]
[tex]\overline{z}= \int\int\int z\rho dV/M[/tex]
If the the object can be divided into several pieces, each being uniform, you can find the center of mass of each piece then form a "weighted" average of the coordinates, weighted by the mass of each piece.
Hi HallsofIvy,
Thanks for ur swift reply. However, i probably need some examples to get a better idea of how it is done. I have sketched an object made up of 2 cuboids as attached. The one on top is of 50x70x55 mm^3 and the one below is 100x150x40 mm^3. Say the density for the cuboid on top is 7800 kg/m^3 and the density for the cuboid at the bottom is 7000 kg/m^3. The COG for both cuboids are apparently at the center of the respective cuboids. How am i supposed to locate the COG of the object as a whole?
Thanks!
Siukwok
wish you were able to get it worked out!http://www.hergoods.info/avatar1.jpg
First find the center of mass of each block. For a symmetric object made of the same material, its just the geometric center. Now fix the blocks together and write their center locations in terms of some overall coordinate system. (for instance, if two blocks are combined and then place flat on a table, you would say the upper block's center is 3 inches from the tabletop, y2 = 3, and the bottom block's center is 0.5 inch from the tabletop, y1 = 0.5; the upper block's center is 5 inches from the table edge, x2 = 5, etc.) Also measure the mass of each block. The center of mass of the two blocks combined is then:
x = (m1 x1 + m2 x2)/(m1 + m2)
y = (m1 y1 + m2 y2)/(m1 + m2)
z = (m1 z1 + m2 z2)/(m1 + m2)
This is what HallsofIvy meant by a weighted average, but this is really just a simplified version of the integrals he gave.
Thank you so much! =)
  • · Replies 49 ·
  • · Replies 20 ·
12K
26K
11K
