Magnetic pull force with a gap
The discussion centers on recalculating the magnetic pull force of a strip with a specified force of 6.2 lb. per lineal foot, 1" wide, and 0.020" thick, when an air gap of 1/8" is introduced through a transparent material like lexan. It is established that there is no straightforward formula for this calculation; instead, experimental measurement is recommended for accuracy. The approximation of the force can be derived from measuring the force for a single foot of the material with the specified spacing. Calculating the force with assumptions about the magnetism in the strip may lead to significant errors.
  • Understanding of basic magnetism principles
  • Familiarity with magnetic pull force measurements
  • Knowledge of experimental measurement techniques
  • Experience with materials like lexan and their properties
  • Conduct experiments to measure magnetic pull force with varying air gaps
  • Research the effects of air gaps on magnetic force in materials
  • Learn about the properties of lexan and its interaction with magnetic fields
  • Explore advanced magnetism calculations and their assumptions
Cabinetmakers, physicists, engineers, and anyone involved in practical applications of magnetism and material properties will benefit from this discussion.
isaacc
Hello. I'm a cabinetmaker and my college physics courses are 25 years behind me now. I'd consider it a kindness if someone would answer a question for me regarding magnetism.
I have a magnetic strip that is described as having 6.2 lb. of magnetic pull force per lineal foot, 1" wide and 0.020" thick, and at 0" of air gap.
How would I recalculate that for a gap of about 1/8" through a transparent material such as lexan?
I'm hoping it's as simple as applying some co-efficient or simple calculation based on the gap distance.
Thank you.
there isn't a simple way to do it, you'll just need to measure the force for a single foot of the material with the spacing. Even then it will only be an approximation. the force for a single foot will be the force per foot you're looking for.
I think I would try to determine it in experiment. While it is possible to calculate it with some additional assumptions about the magnetism in the strip, I think that the corresponding errors would be quite large.
Edit: Nice timing.
16K
10K
