Hey im so confused about moment of inertia. ?
Moment of inertia (I) is defined as I=mr^2, indicating that it depends on the mass distribution relative to the axis of rotation, with greater distances resulting in higher inertia. In the context of a seesaw, while it may seem that less torque is needed for objects farther from the pivot, the reality is that more torque is required to balance those weights due to their higher moment of inertia. Torque is related to angular acceleration, with the equation T=lα, illustrating that a smaller mass will accelerate more than a larger one under the same torque. The discussion highlights the distinction between moment of inertia and torque, emphasizing that moment of inertia affects how much angular acceleration a mass will experience when a force is applied. Understanding these concepts clarifies the apparent contradictions in rotational dynamics.
reyrey389
I=mr^2 I know moment of inertia depends on how for a object how far a bit of mass of that object is from the axis of rotation. i.e. farther from the axis = higher moment of inertia-= more torque is needed to cause rotation. this just doesn't make any sense for the seesaw example, on the seesaw the farther the object is from the axis of rotation, the LESS torque you actually need. (you need more torque closer to the pivot) this e.g. just contradicts my first sentence.
can you please help I've been confused on this for quite awhile...
Torque is not something that is "needed to cause rotation". Torque is the rate of change of angular momentum and a good way to think about is, is like you do about forces. The second law is F=ma similarly T=lα where α is the angular acceleration. When you apply a force F, on two different masses , the acceleration of the smaller mass will be higher. In the same way if you have two object of different moments of inertia and you apply the same torque the angular acceleration of the smaller l will be higher.So in the case of the seesaw if you want to have the same angular acceleration for a mass close to the pivot and one far. You will need a higher torque for the far mass and a smaller torque for the close one.
Moment of inertia is telling you how your mass is distributed throughout your object (it literally is a moment), and, therefore, how angular momentum and energy act on it.
A good way to think about this (given by Richard Feynman) is to think about a door, partly open. With one finger try to close it by pressing hard near the hinge edge - almost impossible. Now apply the same force near the edge away from the henge - easy.
The farther your friend is from the pivot point, the MORE torque you need to balance his weight. :shy:
Umm. Isn't that more a matter of Moments rather than Moment of Inertia? You are accelerating the same door in each case, about the same hinge. Pushing further out just produces a given torque with less force. The MI tells you how much acceleration you will produce - it's not about the equilibrium situation.
I should say that an example to introduce the idea of MI would be to think of a mass on a light pole. The pole is on a bearing at one end and the position of the mass on the pole is adjustable. If you were to push at a point near the pivot, you would find that the angular acceleration of the mass-on-pole would be much greater when the mass is near the pivot than it would be at the end - for a given force. The angular acceleration for a given force (at a given position) is inversely proportional to the square of the distance of the mass from the pivot. The MI is Mx2, where x is the distance from the pivot.
For a set of masses (or a large object with distributed mass) you just add up all the masses times their x2s to give the total Moment of inertia.
The MI formula happens to be just the same as the Standard deviation of a statistical distribution - which used sometimes to be referred to as the second moment of a distribution.
Hi there, im studying nanoscience at the university in Basel. Today I looked at the topic of intertial and non-inertial reference frames and the existence of fictitious forces. I understand that you call forces real in physics if they appear in interplay. Meaning that a force is real when there is the "actio" partner to the "reactio" partner. If this condition is not satisfied the force is not real. I also understand that if you specifically look at non-inertial reference frames you can...
This has been discussed many times on PF, and will likely come up again, so the video might come handy. Previous threads: https://www.physicsforums.com/threads/is-a-treadmill-incline-just-a-marketing-gimmick.937725/ https://www.physicsforums.com/threads/work-done-running-on-an-inclined-treadmill.927825/ https://www.physicsforums.com/threads/how-do-we-calculate-the-energy-we-used-to-do-something.1052162/
I have recently been really interested in the derivation of Hamiltons Principle. On my research I found that with the term ##m \cdot \frac{d}{dt} (\frac{dr}{dt} \cdot \delta r) = 0## (1) one may derivate ##\delta \int (T - V) dt = 0## (2). The derivation itself I understood quiet good, but what I don't understand is where the equation (1) came from, because in my research it was just given and not derived from anywhere. Does anybody know where (1) comes from or why from it the...
