PHYSICS 30 - The Nature Of Matter
The discussion focuses on calculating the charge of a positively charged ion (mass = 3.34 x 10^-26 kg) accelerated through a potential difference of 1.66 x 10^4 V, which then enters a magnetic field (B = 3.20 x 10^-2 T). The magnetic force acting on the ion is given as 5.78 x 10^-15 N. To find the charge (q), the equations F = qvB and KE = qV are utilized, where the velocity (v) can be derived from the kinetic energy equation. The correct approach involves first calculating the velocity using the kinetic energy and then substituting it back to find the charge.
  • Understanding of classical mechanics, specifically kinetic energy equations.
  • Familiarity with electromagnetic theory, particularly the magnetic force on charged particles.
  • Knowledge of unit conversions and dimensional analysis.
  • Basic algebra skills for rearranging and solving equations.
  • Study the relationship between kinetic energy and potential difference in charged particles.
  • Learn about the derivation and application of the magnetic force equation F = qvB.
  • Explore the concept of velocity calculation from kinetic energy using v = √(2KE/m).
  • Investigate the effects of magnetic fields on charged particles in motion.
Students studying physics, particularly those focusing on electromagnetism and mechanics, as well as educators seeking to clarify concepts related to charged particles in magnetic fields.
Invisible
I'm stuck on this question and I'm not sure where to start. :confused:
A positively charged ion (m = 3.34 x 10^-26 kg) was accelerated from rest through a potential difference of 1.66 x 10^4 V. This ion now enters a region where there is a magnetic field (B = 3.20 x 10^-2 T) that is perpendicular to the direction of its motion. If the magnetic force on the ion is 5.78 x 10^-15 N, what is the charge on the ion?
I've done this question many times, and it seems that there's on unknown I have to find first (I think the speed), but I can't get it for some reason. I also tried equating formulas...that worked, but I got the wrong answer afterwards.
What is the increase in kinetic energy of a charged particle when it is accelerated through a potential difference V?
Hi there,
It looks like you are trying to solve for the charge of the ion in this problem. To do so, you will need to use the equation for the magnetic force on a charged particle:
F = qvB
Where q is the charge of the particle, v is its velocity, and B is the magnetic field. You already have values for F, B, and m (mass of the ion). To find the velocity, you can use the equation for the kinetic energy of a charged particle accelerated through a potential difference:
KE = qV
Where KE is the kinetic energy, q is the charge, and V is the potential difference. You can rearrange this equation to solve for v:
v = √(2KE/m)
Substitute in the values you have and solve for v. Once you have the velocity, you can plug it into the first equation along with the values for F and B to solve for q. Make sure to pay attention to units and use the correct signs for the force and velocity.
I hope this helps and good luck with your problem solving!
  • · Replies 16 ·
