Acceleration due to gravity, and the force of landing on the ground
The discussion revolves around the concepts of impact force, weight, and momentum in the context of a person falling from a height, specifically a 5-story building. Participants explore how to calculate the force upon impact and the effects of different landing surfaces, such as concrete versus a trampoline or blanket. The scope includes theoretical considerations and practical implications of these calculations, while ignoring air resistance.
  • One participant expresses confusion about calculating the impact force and its relationship to momentum when falling from a height.
  • Another participant notes that the "force of landing" is not well-defined without additional information, emphasizing the need for distance or time to calculate force accurately.
  • It is suggested that using energy considerations may be more straightforward than calculating force directly, particularly in real-world scenarios.
  • A participant questions the assumption of instantaneous stopping, indicating that it would imply an infinite force, which is unrealistic.
  • Another participant agrees that focusing on energy and momentum is more practical than delving into the complexities of the stopping process.
Participants generally agree that calculating impact force is complex and that assumptions about stopping conditions can lead to unrealistic conclusions. However, there is no consensus on the best approach to model the impact force, as different perspectives on the stopping process and its implications are presented.
The discussion highlights limitations in defining the "force of landing" without specific parameters such as stopping distance or time. The complexities of real-world applications and the variability of landing surfaces are acknowledged but not resolved.
SignSeeker7
I'm quite confused about impact force and weight, as well as momentum. Assuming someone were to fall from a 5-story building, about 20 m, how would you calculate the force upon impact? I know it involves momentum, but I can't quite grasp it.
Also, if someone fell from the building, but instead of landing on the concrete below, they instead landed on a trampoline or blanket suspended above the ground, something that would slow them down without being lethal, how would you show that? Would it involve the same equation?
EDIT: I'm ignoring air resistance as well. In case that changes things.
The reason you are confused about the "force of landing" is that this is not a well-defined concept without more information being given. You know the force of gravity, and the acceleration it produces (that's just g, a constant), so it's easy to get the velocity upon impact. But how do you convert that into a force? You need to know either the distance over which the falling person is stopped, or the time to stop them. Either of those will let you calculate the force, but even then you have to assume the force is constant, which is not a very good assumption at all. So anything you do is going to be pretty rough. However, if you do have a constant force of impact, and you know the distance over which it applies (so a harder surface would compress a smaller distance, for example), then you just say the force times the distance equals the kinetic energy of the falling person, and you do it all with energy. If you instead know the time it takes the person to stop, you would do it with momentum-- the force times the time must equal the momentum that the falling person acquired while falling.
But what I really want to stress is that you wouldn't know these things in any real application-- you would need a much more complete model of the response of the ground or trampoline or whatever. Then you would need to do a careful calculation of the stopping process, that was much more difficult than the simple calculation of the falling process. So that's why you really don't encounter the "force of impact" very often in basic physics problems.
So would it be bad to assume that the person would stop instantaneously? I would think that would be incredibly difficult to happen in real life.
Yes, instantaneous stopping would require an infinite force. The fact is, we usually choose not to care what the force of stopping is, instead we focus on what is much easier to know-- the energy released when the person is stopped, and the momentum required to stop them. Going deeper into the stopping process is an issue for paratroopers and basketball sneaker designers!
  • · Replies 25 ·
  • · Replies 22 ·
