Find V0 in Nodal Analysis Problem with Annotated Circuit and Equations
The discussion revolves around finding the voltage V0 in a circuit using nodal analysis. Participants share their equations and reasoning related to the circuit's node potentials, current sources, and resistances, exploring the relationships between these variables.
  • One participant presents a set of equations for the circuit but expresses uncertainty about their correctness, particularly regarding the current i1.
  • Another participant points out that V2 and V3 are node potentials rather than voltage drops across resistors, suggesting that some equations are incorrect and that V3 should equal V0.
  • Participants discuss the number of independent nodes in the circuit, with one participant identifying two nodes and the ground rail as the reference node.
  • There are suggestions to eliminate unnecessary variables and focus on the node equations, with a later participant proposing a third equation based on node potentials.
  • One participant attempts to derive V0 using substitutions from the node equations but later revises their calculations after realizing an error.
  • Another participant confirms the correctness of a derived value for V0 but emphasizes the importance of careful equation writing in nodal analysis.
  • Throughout the discussion, there are corrections and refinements of earlier claims, with participants questioning each other's interpretations and approaches.
Participants do not reach a consensus on the correctness of the initial equations, and there are multiple competing views on how to approach the problem. The discussion remains unresolved regarding the final value of V0 and the validity of the derived equations.
Some participants express confusion about the definitions of node potentials versus voltage drops, indicating potential misunderstandings in the application of nodal analysis. The discussion also highlights the need for careful consideration of independent nodes and the relationships between them.
Readers interested in circuit analysis, particularly those studying nodal analysis and its application in electrical engineering, may find this discussion beneficial.
Lancelot59
I need to find V0 in the given circuit. I've uploaded both the problem, and an annotated one with the variables I chose.
These are the equations I got for the system:
[tex]V_{0}=30-V_{2}-V_{3}[/tex]
[tex]V_{2}=30-i_{1}(10\Omega )[/tex]
[tex]V_{2}=I_{X}(2\Omega )[/tex]
[tex]V_{3}=30-V_{2}-(-i_{1})(1\Omega )[/tex]
[tex]V_{0}=i_{4}(5\Omega )[/tex]
[tex]I_{X}=i_{1}+i_{2}[/tex]
[tex]4I_{X}=i_{2}+i_{4}[/tex]
Does this look right? I'm fairly certain I'm doing this wrong, as I got -15/7A for the current i1.
You V2 and V3 represent node potentials, not potential differences across the 10 and 1 Ohms resistances. So your first equation is not correct; The same problem exists in several of your other equations, and you've introduced current variables I1 and I2 which are not necessary for writing the node equations.
Clearly V3 and Vo must be the the potentials at the same node (they are connected by a wire), so V3 is in fact equal to Vo and there's no need to have duplicate variables.
How many independent nodes do you count for your circuit? You only need that many node equations, plus one equation for each controlled power supply.
Okay. Well then I can count 2 nodes. One after the 10Ohm resistor, and one after the 1Ohm resistor. I also want to count the ground rail.
Okay, so then you should write two equations for the two independent nodes that you've identified (the ground rail is the reference node and doesn't require a separate equation) and one equation that gives the controlled current source value in terms of node potentials.
Thus far I have:
Node1
[tex]I_{x}=i_{1}+i_{2}[/tex]
[tex]\frac{V_{1}}{2}=\frac{30-V_{1}}{10}+\frac{V_{2}-V_{1}}{1}[/tex]
Node 2
[tex]4I_{x}=i_{2}+i_{3}[/tex]
[tex]4I_{x}=\frac{V_{2}-V_{1}}{1}+\frac{V_{0}}{5}[/tex]
I should be able to eliminate a variable since V0 will be equal to V2.
Lancelot59 said:
Thus far I have:
Node1
[tex]I_{x}=i_{1}+i_{2}[/tex] [itex]\nearrow[/itex] Not required
Node 2
[tex]4I_{x}=i_{2}+i_{3}[/tex] [itex]\nearrow[/itex] Not required
Yes. You also don't need variables i1 or i2, since Ix can be easily obtained from the node voltage V1. That's the "other" equation I was referring to with regards to the controlled source.
Idea! I pulled a third equation:
[tex]30=V_{1}+V_{2}[/tex]
and therefore:
[tex]30=V_{1}+V_{0}[/tex]
I got some numbers by using this form.
V0=222/5
V1=237/8
I posted this just as you replied. I'll review what you said and take a look at it.
This is not true! V1 and V2 are NODE POTENTIALS, not resistor voltage drops.
You should be able to find Ix from a node potential though... (in fact, it's included as a term in your Node1 equation :wink:)
Why not though? At V2 the only two branches are the resistor and the current source. Therefore V2 is the only potential left to drop before it hits the ground rail.
I do have Ix there, but there are only two equations. I have three variables...
Node 2 has three connections: the path to node 1, the path to the controlled current source, and the path to the load resistor.
NOTE: Node voltages ARE NOT RESISTOR DROPS. They are the potentials, w.r.t. ground, of those nodes. If a resistor happens to be connected between a given node and ground, then it will THEN also be that resistor's potential drop. But you should know this already by HOW you write the node equations, right? You take the DIFFERENCE between node potentials for the resistance that lies between the two nodes.
Yes, so you want to write an equation for Ix. Hint: You've already incorporated an expression for Ix in your equation for node 1.
NOTE: Node voltages ARE NOT RESISTOR DROPS. They are the potentials, w.r.t. ground, of those nodes. If a resistor happens to be connected between a given node and ground, then it will THEN also be that resistor's potential drop. But you should know this already by HOW you write the node equations, right? You take the DIFFERENCE between node potentials for the resistance that lies between the two nodes.Yes, so you want to write an equation for Ix. Hint: You've already incorporated an expression for Ix in your equation for node 1.
I see what you mean there. I was looking at it the wrong way. I think this is the equation you're referring to:
[tex]V_{1}=I_{x}*2\Omega[/tex]
Since the drop across that will be equivalent to V1.
Doing that substitution I found V0 to be 15/19
Your expression for Ix looks fine, but I think your reduction for Vo from the node equations does not look correct. Can you detail your work?
On review I botched something along the way. Revised work:
Rearranged node 1:
[tex]\frac{8}{5}V_{1}=3+V_{2}[/tex]
[tex]V_{1}=\frac{5}{8}(3+V_{2})[/tex]
[tex]V_{1}=\frac{15}{8}+V_{2}[/tex]
Node 2 rearranged to:
[tex]3V_{1}=\frac{6}{5}V_{0}[/tex]
after first using this equation:
[tex]3V_{1}=2I_{x}[/tex]
to sub out the Ix term from it.
Combining them together, and replacing any instances of V2 with V0:
[tex]3(\frac{15}{8}+V_{0})=\frac{6}{5}V_{0}[/tex]
I then got V0 to be -25/3
That looks better :smile:
Be sure to add the appropriate units to the final value.
Yes, V0 = -8.33V, so that's correct.
With questions involving nodal analysis, I find it easiest to write out the set of node equations really carefully as you're going to need them to solve for the other variables and the slightest error will obviously follow through and then it's a mess having to troubleshoot 3 or 4 equations. Along the way you will see relevant aspects like that Ix = V1/2 which you're going to need to sub in later for your second node equation.
Well thanks for the help! This has me off to a good start. I'll just practice the method now.
Lancelot,
Two equations with two unknowns. No need to figure out sub currents.
Ratch
