Question on spring constant w/potential energy
The discussion centers on a physics homework problem involving a spring and a mass, specifically the relationship between the compression distance D and the initial compression distance d. The key equations used are derived from the conservation of energy principle, where the total mechanical energy at different positions is equated. The correct spring constant k is determined to be k = mg / d, leading to the conclusion that D = 2d. The misunderstanding arises from confusing the conditions of oscillation with those of static equilibrium.
  • Understanding of conservation of energy principles in physics
  • Familiarity with potential energy equations, specifically gravitational and elastic potential energy
  • Basic knowledge of spring mechanics and Hooke's Law
  • Ability to solve algebraic equations involving kinetic and potential energy
  • Study the principles of oscillation in spring systems, focusing on energy transformations
  • Learn about Hooke's Law and its applications in real-world scenarios
  • Explore the concept of damping in oscillatory systems and its effects on energy conservation
  • Practice solving problems involving multiple energy states in mechanical systems
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for examples of spring dynamics and oscillatory motion.
yumemirai
Hi all. I'm having trouble understanding a homework problem. Here it is...
The question, from my book, is: "When a mass m sits at rest on a spring, the spring is compressed by a distance d from its undeformed length. Suppose instead tht the mass is released from rest when it barely touches the undeformed spring. Find the distance D that the spring is compressed before it is able to stop the mass. Does D = d?"
In my own words: there is a spring attached to the ground, sticking up vertically. A person holds an object at the top of the spring, in contact with the spring but not compressing it at all (Position 1). The person let's go, and the mass drops, compresses the spring, until the spring stops the mass (Position 2). Then it goes back and forth until it settles (Position 3).
2. Homework Equations / The attempt at a solution
The chapter is "Conservation of Energy" so that's the formula I'm using. I start by finding K, Ugrav and Uel at each position:
Position 1:
K = 0 (velocity = 0)
Ugrav = mg * 0 (we choose the undeformed length of the spring as x = 0)
Uel = 1/2 * k * 02 (again, x = 0)
Position 2:
Ugrav = -mgD (we choose the maximum compression before the spring stops the object as x = D. D is downward so we use a negative sign. Our goal is to find D in terms of d.)
Uel = 1/2 * k * D2
Position 3:
Ugrav = -mgd
Uel = 1/2 * k * d2
So far, so good, right? Now, the total mechanical energy at one position is equal to that at any other, right? I might have the terminology wrong, but what it means is:
E1 = E2 = E3
∴ K1 + U1 = K2 + U2 = K3 + U3
∴ 0 = 1/2 * k * D2 - mgD = 1/2 * k * d2 - mgd
Now, in order to solve for D in terms of d, I need to eliminate the other unknown: k. I do it like this:
E1 = E3
∴ 0 = 1/2 * k * d2 - mgd
∴ k = 2mg / d
BUT
I can also do this:
Since F = ma, and F = kx
then mg = kx
∴ k = mg / d
I have two different possibilities for k.
According to the book, the k = mg / d result is correct; plugging that into the previous formula using E1 = E2 results in
mgD = mgD2 / 2d
D = D2 / 2d
2d = D
and that is the answer.
But, if you use k = 2mg / d, then d = D. That's what I'm missing: how do I know what the right way to solve k is? I'm pretty sure I have my formulas and my math right, so is there just a conceptual element that I'm not thinking of? What is it?
Thanks in advance.
"∴ 0 = 1/2 * k * D2 - mgD = 1/2 * k * d2 - mgd"
You are using conservation of energy on two different problems. One is when the system oscillates. The other is when the system is at rest. During oscillation, the kinetic energy is not zero when it passes the neutral point.
Okay, I think I get it... because when I say
I'm not specifying when we're at "d"... and obviously it will have a velocity as soon as you let go of the object and it passes that point, whereas if you leave the system alone for an hour and let it... settle... or whatever the term is, then it won't have velocity... and this equation can't account for that.
We haven't done anything with oscillation so this bit's foreign to me, but I think I see now.
  • · Replies 17 ·
