Why Are Red Giants More Luminous Than Other Stars?
  • Thread starter Thread starter ehabmozart
    Luminosity
Red giants are more luminous than other stars due to their significant increase in surface area as they expand, despite a decrease in temperature. The energy produced from helium fusion under immense pressure leads to this expansion, which results in a higher luminosity despite the cooling effect. The relationship between luminosity, surface area, and temperature is governed by the Stefan-Boltzmann law, where an increase in radius can lead to a substantial increase in luminosity. While the temperature may drop, the vast increase in size compensates, allowing red giants to emit much more energy overall. Understanding the physics of stellar evolution and opacity can provide deeper insights into this phenomenon.
ehabmozart
Well, I've seen in almost all sites and books that Red Giants are more luminous than the star itself... Particularly, let us take our sun as an example... First of all, we know that due to the He- Fusion and the enormous pressure acting on the H- on the surface, it IGNITES or fuses faster... Thus, the energy is vast causing it's Surface area to increase... This is the main cause of y red giants appear more luminous.. However, to my point of view .. L= σ A T^4 ... The temperature will decrease by this increase in volume and the area is increasing.. If we take each by scale. Temperature should rule the way the red giant luminates.. If there is an increase in area, temperature will decrease with the scale of FOUR... Shouldn't it be less luminous ... I need clarification in this part... Thanks in advance to whoever helps!
Astronomy news on Phys.org
I believe the luminosity of the star is a measure of the total energy output, regardless of where in the spectrum it is at. As the surface area increases the same amount of energy must still be released, meaning the star cools off and releases it's energy accordingly. So no matter how big or small the star gets, as long as the reactions inside the star release the same amount of energy then the star stays the same luminosity regardless of it's physical size.
This is not the case for red giants. While the temperature might change by a factor of ~2, the radius can increase by a factor of ~100. I did not check the numbers, but they should give you an idea. This could give a factor of 100^2 * (1/2)^4 = ~500 more luminosity.
Edit: Wikipedia gives a factor of ~200 for the sun. And a temperature drop by more than a factor of 10 would make it invisible, therefore the sun as a red giant will have a higher total luminosity.
A Red Giant is a bit like a very hot white dwarf (the hydrogen-depleted core) surrounded by a shell of furiously fusing hydrogen, and then a very large, diffuse atmosphere which down-shifts the ultra-high frequencies emitted from the shell-core into a rosy glow. So, in a sense, the core has brightened intensely, but the rest of the Sun dilutes that fierce glow from below.
Read some good papers on stellar evolution and you'll have a better idea of the physics involved. The classics are the paper by Boothroyd & Sackmann (+Kraemer) and the later paper by Schroeder & Connon Smith...
Boothroyd, Sackmann & Kraemer Our Sun. III. Present and Future
Schroeder & Connon Smith Distant future of the Sun and Earth revisited
Plus there's the work by Laughlin, Adams & Bodenheimer on low-mass stars:
The End of the Main Sequence
Explore these and you'll know a lot more.
One more reference with a very simple explanation (ok, so there's a bit of maths) is this paper by Adams, Laughlin & Graves...
Red Dwarfs and the End of the Main Sequence
...which explains how the Red Giant inflation is driven by opacity. "Opacity", very roughly, is how hard energy escapes from a star's substance, and can very quite significantly through the body of the star.
3I/ATLAS, also known as C/2025 N1 (ATLAS) and formerly designated as A11pl3Z, is an iinterstellar comet. It was discovered by the Asteroid Terrestrial-impact Last Alert System (ATLAS) station at Río Hurtado, Chile on 1 July 2025. Note: it was mentioned (as A11pl3Z) by DaveE in a new member's introductory thread. https://www.physicsforums.com/threads/brian-cox-lead-me-here.1081670/post-7274146 https://earthsky.org/space/new-interstellar-object-candidate-heading-toward-the-sun-a11pl3z/ One...
