Is the multiverse cosmology or metaphysics?
The discussion centers on the multiverse concept in cosmology, examining whether it should be considered a legitimate cosmological theory or merely a metaphysical idea. Participants explore the implications of the multiverse in relation to fine-tuning problems and the nature of scientific predictions.
  • One participant argues that the multiverse may be viewed as a metaphysical conviction rather than a scientific theory, citing the need for theories to make "risky" predictions that could potentially fail.
  • The same participant presents an analogy involving a card game to illustrate different interpretations of fine-tuning, suggesting that the selection of a special hand could be attributed to various factors, paralleling multiverse explanations.
  • Another participant references video talks from the Perimeter Institute that discuss challenges related to eternal inflation and fine-tuning, indicating that these talks present multiple sides of the controversy surrounding the multiverse idea.
  • A different participant criticizes common assumptions about inflation being triggered solely by random fluctuations, suggesting that there may be alternative mechanisms that do not necessitate a multiverse perspective.
Participants express differing views on the validity of the multiverse concept, with some supporting its scientific relevance and others questioning its metaphysical implications. The discussion remains unresolved, with multiple competing perspectives presented.
Participants highlight the limitations of current theories and the challenges in distinguishing between different interpretations of fine-tuning and inflation, indicating that assumptions and definitions play a significant role in the debate.
  • #31
Ken G said:
Yes, I realize there is a factory for spitting out multiverse models for people to talk about, which are capable of fitting essentially anything. That was one of the points I made, it's a prescription for rationalization until a model is generated that makes risky predictions that weren't already verified before the model was built to rationalize them.
And I'd argue that it isn't as long as the theory factory creates mathematically unambiguous predictions, and excludes some possibilities.
The reason that I believe this is that this is the situation in most "ordinary physics." We don't know how supernova work. We know that they exist. If someone can create a "logical chain" from "physical principles" to "known outcome" this is useful, because the fact that each part of the chain is "logically strong" keeps you from making up anything that you want.
It gets a bit harder with the early universe because you don't have basic "physical premises" to anchor the chain, but with more observations we can "anchor that chain."
That's not even a ramification of string theory, that's a ramification of the fact that string theory leaves open the question of what the parameters could be.
No it doesn't. String theory makes the prediction that force coupling constants are quantum mechanically *random*. They are determined by vacuum energy and that is a value which an undetermined value until you have a wave function collapse. Note that string theory doesn't say that *all physical constants are random*, merely the force coupling constants. Within string theory, Planck's constant and the speed of light are going to be the same in all parts of the multiverse, and you can use things like the fact that the speed of light is the same everywhere to infer things about the other universes.
It is the ultimate rationalistic stretch to assert that just because the theory allows a lot of different possibilities, that every one of those possibilities has to be another existing universe.
But that's not what is going on...
That comes out as a rather unambiguous prediction of string theory. A lot of people take it to mean that string theory is wrong. That's why there is a lot of work in alternative quantum gravity models like loop quantum gravity.
One nice thing about LGC is that it *doesn't* produce the types of multiverses that string theory does. You have one universe. The fact that LGC *doesn't* produce multiverses (or at least the types that string theory does) is one reason people like LGC.
Also, the types of multiverses that string theory produces are different than what inflationary cosmology produces, and those are different from the multiverses that the MWI of quantum mechanics produces.
Talk about a purely metaphysical stance! Even eternal inflation can claim to be somewhat less blatantly metaphysical that that string theory claim.
Nothing at all to do with metaphysics. If you start with the assumptions of string theory, multiple universes pops out. If you don't like that, then the answer is simple. Reject string theory. It's not a metaphysical claim. If you start out with the string theory assumptions, you get multiple universes.
True, but a model that makes only obvious predictions is not much of a model either.
Yes it is. For example, cosmological measurements of distant supernova Ia assume that their brightness is constant. We have no theoretical model for this, and we really have no clue why this is true. If someone came up with a model of SN Ia that explained *why* supernova Ia have the same brightness, this would give us more or less confidence in that assumption. Now you can "fix" this problem by coming up with other independent measurements that have nothing to do with SN Ia. You can look at gamma ray bursters or use the Tully-Fisher relationship.
The SNIa results seem to be holding up, but we have a problem since we don't know how Tully-Fisher or GRB work. Having something work with three unknown assumptions that are independent gives you more confidence that you haven't messed anything up, but it's still something to worry about.
Also for things we can't explain the obvious. Take a tube of water. If you pump in the water fast enough, it will turn turbulent. It's something that is trivial to measure, but we do not know how to calculate the exact Reynold's number at which a fluid will go turbulent. What people do when they simulate aircraft is that they use a model that involves punching in parameters that are experimentally measured.
That's a good thing only if it leads to risky predictions. If the "2" is needed to get obviously correct predictions, and that's all you get, then the model is still garbage anyway.
No it's not. Then you can look at what happens if you set it at two.
And sometimes you take what you can get. When people model turbulence, there are a lot of parameters that people just type in based on experiment. You have this relationship that has a free parameter and you set it based on experiment.
Ohm's law. When you build a circuit, you put in a resistor. To calculate how much stuff you have to use to make the resistor, you have to know the material resistance. Being able to calculate that is beyond current physics, so you just measure it, and you put it into your equations. Ohm's law itself is a semi-empirical observation.
Excellent-- so do they make any risky predictions? If so, what? If not, why the heck not?
Etheral inflation predicts that the CMB spectrum is gaussian to arbitrarily low scales. OK, if you claim that prediction is not "risky" then what about alternative models that predict that the CMB spectrum becomes non-Gaussian at low scales?
If you claim that predicting A is not good enough because it's non-risky, and then you claim that predicting not-A is not good enough because it's non-risky. Then I can't help you.
Also you can't *force* a theory to make the predictions you want to make. What keeps physics from "rationalizing" things is math. The math *forces* you to make some conclusions.
The title of the thread is certainly intended to be polarizing-- the truth may lie somewhere in between. That's OK, that's what we are investigating.
A lot of the ways that people "compromise" outside of physics don't work in physics. I claim 50, someone else claims 100. It's not going to work to just say 75.
Metaphysics is notoriously difficult to define, and it can mean a lot of different things in different philosophical applications, but in regard to physics, it seems clear enough that metaphysics is not the laws themselves, it is the interpretation of the meaning of the laws, what we will choose to take as their implications.
To a lot of people this would seem like useless navel-gazing. One thing that you need to do physics is precise definitions, because without precise definitions, you can't figure out precise logical consequences, and if you can't do that, then you can't do physics.
As such, metaphysics tells us what we have accomplished when we arrive at a law, but it is also highly subjective. Since this is also the purpose of interpretations of quantum mechanics, I would certainly say that those interpretations are metaphysics, as long as they are not themselves laws of physics.
That's not the purpose of interpretations of quantum mechanics. The purpose of physics is to make statements that have observable and testable consequences. If different interpretations of QM don't have testable consequences then it's irrelevant from a physics standpoint, you can just do the numbers, and make up something random to explain them.
The reason that physicists are interested in different interpretations is that it's not clear that they don't have some sort of observable consequence, and if you have different consequences, you can do an experiment (which I play to do on my 150th birthday. I think I'll wear a cat suit before zapping myself with gamma rays).
This is important for the early universe, because a lot of the ways that people avoid conflict between different interpretations won't work at the start of the universe. You can show that interaction with the environment will give MWI the same outcome as Copenhagen under "ordinary" situations. But what happens if there is no environment to interact with?
For the Bohm interpretation to work, then every particle in the universe has to match books with every other particle in the universe. However, suppose inflation is right. Then suppose the "bookkeepping" principle goes out to 1000 trillion light years. Then you'll be able to see it in some experiment. You have an electron with a probability distribution function. Does that PDF get "cut off" at the length of the observable universe.
(They could be laws in some future theory, but none of them are as yet.) Hence, there is no requirement to prove that they could not be laws in some other theory-- it suffices to address their current function (which is metaphysical).
In physics, it's not metaphysical. It's to come up with experiments (sometimes thought experiments) to figure out what happens. I create a coherent wave function, part of it falls into a black hole, now what happens? (Too bad we don't have a black hole nearby to find out.)
If we get into the subjective, I don't see the point in arguing about this. You believe what you want to believe. I believe what I believe, and there is no reason to change each others minds. I don't care what your metaphysical beliefs are. At least for the purposes of this thread, I just care that you get the physics right. If you believe in multiverses, fine. If you think they are non-sense also fine. If you believe that the world is 6000 years because God said so, I'm not going to try to change your mind.
The *only* reason I'm arguing with you is that you are getting the physics wrong.
Yes I know-- that was the whole point. It was you who made the claim that we have to prove something scientifically unverifiable before it could be metaphysics
I don't care how you define metaphysics. The trouble is that if you include things in metaphysics which are also in the realm of physics, then you have a potential or actual conflict when rules collide.
I'm pointing out that nothing can ever be proven to be scientifically unverifiable, not even unicorns.
Not true. Mathematical statements are scientifically unverifiable. 2+2=4 is a mathematical assertion that cannot be scientifically verified. Many religions take as dogma that statements about God are not scientifically verifiable. "Do curious dreams squeam furiously?" is not a scientifically verifiable statement because it has unclear meaning.
Also unicorns are a special case, because there is no law of physics or biology that prevents unicorns from existing, and if the biochemists are right, there is a DNA sequence that will generate unicorns. Warp engines on the other hand, conflict with known laws of physics.
By your nonstandard definition, metaphysics would be the empty set, which would make it easy to answer the title question by default, but not terribly informative.
Since you yourself say that the definitions are subjective, then what's wrong with my definition other than it puts metaphysicists out of work? This is the problem with you have unclear definitions, which is that people can change them at will.
Astronomy news on Phys.org
  • #32
Right, in "ordinary physics" you are not inventing new unknown physics to explain a supernova, you are trying to see how already known physics might do it. There it suffices to try models until one works-- because the "risky predictions" were already made and tested, when justifying all the physics you are putting into your model.
No, the chain never gets anchored, until there is the risky prediction. That's the difference, the essential issue that separates true discovery from simple rationalization.
String theory makes that prediction? So I can do an experiment, and if it comes out the coupling constants are random, I say string theory worked, and if they don't come out random, I say string theory didn't work? No, not at all, that is not a prediction of string theory, it is a metaphysical interpretation that many associate with string theory (for quite unsubstantiated reasons). But we need a whole new thread to ascertain which claims associated with string theory are scientific, and which ones are metaphysical. A prediction must be able to say experiment A will come out X, if we cannot agree on the meaning of the term "prediction", we are really up the creek!
OK, that's an interesting point, I didn't realize that. But it is still not a prediction of string theory-- it is a concept that one intends to embed in string theory, if and when one ever really does create a theory there. The predictions must stem from that postulate, and they must be risky, and they must be testable. That's why string theory is a very long way from being a scientific theory, it's more of a signpost to a theory-- nobody really knows what that theory is going to end up looking like, if at all.
And yet I would argue that not implying multiverses is no more scientific than implying them-- either way, it ain't nothing until you make risky predictions that a skeptic of your theory would be inclined to expect to fail. If you are cooking up new physics, whether multiverse or not, you better not just be rationalizing!
Yes, they are all different types of multiverses, yet if one of them comes through the front door, it's hard to reject the others. As none of them yet make any verifiable predictions we'd be inclined to not expect, it's still the back door for all of them.
Nah, it's metaphysics. It's just like in Newton's laws, it's metaphysics to say that forces actually cause acceleration. I can reframe Newton's laws and never mention the word "force" even once, ergo, forces are metaphysics in regard to Newton's laws. They are a way to picture the action of a theory, they are not part of the theory, and they do not make claims on existence. Few people who know Hamiltonian mechanics would even claim that "forces exist." Instead, they (not I) might say "the Hamiltonian exists", and the presence of forces is a kind of illusion that stems from the action of the Hamiltonian. It's a lot like the force carriers-- virtual particles. Is the existence of virtual particles not a question of metaphysics? Note, for example, how subjective that question is, when it shows up on this forum!
No, not at all necessary. I can embrace string theory, and reject the existence of multiple universes, as easily as I can embrace quantum mechanics, and reject that all observations give every possible result. It is indeed a metaphysical claim, it is a quintessential metaphysical claim. Do you really think there is no way to frame string theory, getting all the same testable predictions, and not have the existence many universes? I can even frame chaotic inflation that way, it's a piece of cake.
Not if they invented physics to do it, that's the whole point. If they did it with existing physics, already accepted by virtue of other risky predictions, now that's another matter altogether-- with no connection at all to this thread.
And they don't claim it is a theory of what is really happening in turbulence, nor do they make claims on the physical existence of anything in that model! That is an empirical model. If someone says they are making an empirical model of eternal inflation, more power to them, but then it's obviously metaphysics (and rather lamely supported at that) to claim those other universes actually exist!
That is the closest we've come to evidence of an actual risky prediction. But Gaussian seems pretty easy to get-- I'd be much more impressed by a non-Gaussian prediction that worked, that seems a lot more risky to me-- given the mean value theorem.
You aren't making any sense now.
Baloney. Most physicists are very interested in interpretations, while holding out not the least bit of hope the distinctions will ever be resolved, certainly not in our lifetimes. Count me in that huge class, for example.
Well, if that's the reason you are arguing, you're wasting your time, because you certainly have not demonstrated that in the least, and I don't believe it for a minute.
Obviously, what's wrong is that this thread uses a particular meaning of "metaphysics", which is the standard one among those who use the term. Perhaps I should have replaced "metaphysics" in the OP with the intended meaning, but it seemed unnecessary at the time-- everyone else on the thread seemed to take the same meaning I did, for example.
  • #33
Forgive me for the interruption, but if I may, about "One thing that you need to do physics is precise definitions, etc.."
Shouldn'the better term in place of "precise definitions," "precise conventions"?
Yrreg
  • #34
But there is still "unknown physics". For example, in trying to figure out how supernova work, it's unlikely that we will find out that the speed of light is not constant or that gravity doesn't work through GR. However, putting the pieces together still involves "unknown physics." In the case of inflation, the high energy physics is known well enough so that you are limited in what you can "make up" and so it's a matter of connecting the dots. I don't see how this is much different from supernova or accretion disk jets.
Also, the definition of "risky prediction" is problematic. What's the difference between a "risky prediction" that has already been made with "non-risky prediction" that has already been made.
Yes. It's considered a bad thing that string theory has this characteristic, and people are trying to fix it so that it doesn't.
It's also known from high energy experiments that the effective coupling constants do change at high energies.
Also, if you do an experiment and the vacuum speed of light changes, that would call into question inflation because if the vacuum speed of light does change, then the big problem for inflation disappears. The only logical alternative to inflation (assuming that the big bang actually happened) that anyone has come up with are variable light speed models.
If the FTL neutrino measures had actually confirmed, then *that* would have caused people to question if inflation is necessary.
It's a *prediction* of string theory. If string theory didn't *predict* multiple universes, there would be a lot less interest in them. It's *not* a metaphysical interpretation. If you accept string theory then you end up with multiple universes in much the same way that if you accept the Coprenician model of the solar system, you quickly end up with exoplanets.
I'm not a string theory expert, but this is what the experts tell me. If you don't believe that there are multiverses, then string theory is wrong. This is actually why there is so much work on alternatives to string theory.
They are all scientific.
If string theory predicts A, B, C and multiple universes, and A, B, and C are confirmed, there are no other viable theories that predict A, B, and C, then we wouldn't be crazy in assuming D is true. String theory has not been able to do that, and personally I don't see much hope that it every well. Eternal inflation is much closer to doing that, and we may get to the point where there are enough predictions about the current universe that makes sense that we are willing to accept predictions that are not testable.
The same is true with exoplanets. Once you accept the Coprehenican model of the solar system and Newtonian physics, then you pretty much had to accept that other planets existed even if you couldn't see them.
No. It's a *prediction*. The idea of multiverses isn't something that people added. People started working on string theory in the 1970's and it wasn't until the 1990's, that people realized that string theory would have to predict many, many universes to work. If you reject the concept of multiverses, then you *must* logically reject string theory, which is what a lot of people have done.
To put it crudely as to why, string theory works by symmetry, and in order to have a symmetry that explains the current universe you have to set certain quantities as "quantum mechanically random". If something is quantum mechanically random, that means that different observers in different parts of the universe will "flip the Schroedinger coin" differently and come up with different numbers for those quantities. At that point you explain away the fact that we *don't* see things like the fine structure constant changing in our universe by the fact that some sort of inflation expanded the universe so that the parts that we see are all parts where the "coin got flipped the same way" but that must mean that there are parts that we don't see in which the "coin got flipped differently."
One consequence is that some numbers will be different in different parts of the "multiverse" and some numbers will be the same. Force coupling constants will be different. The speed of light and Planck's constant will be the same. The macroscopic dimensionality of space may be different although the microscopic dimensionality will be the same (i.e. we all live in an 11 dimensional universe, but certain parts may such that more or less than 3 of those dimensions get "blown up").
It's not as if people like the idea of multiverses and added it because it was fun. People generally hate the idea of multiverses, and only add them because the math gives them no choice in the matter. (Also, I'm not a string theorist, so if I've messed up the explanation, corrections are appreciated).
A lot of the interest in things like entropic gravity or loop quantum gravity are to avoid the multiverse problem. In these gravity models, you just care about gravity and QM. You don't care about anything else. Since you don't care about anything else, you don't have to try to fit everything into a symmetry, and since you don't have to fit everything into a single symmetry, you don't get the bad consequences of said symmetry.
One other thing is that the "argument by symmetry" worked beautifully to explain the electroweak force, once people got that done in the early-1970's, it wasn't a crazy idea to try to use it to try to explain everything. Nature had other ideas. The math is hard, so it took about two decades for people to realize that string theory *requires* multiverses to work.
It's a theory. It may be a bad or incorrect theory, but it's a theory. It's a theory because it makes predictions. These may be untestable or silly predictions, but they are predictions. Right now they look silly enough so that the "cool kids" are trying to work in other directions, but science is hard. One thing about string theory is that you can spend two decades arguing about something before you reach a conclusion that it's not going to work, but for things outside of physics, you can argue for centuries and not come to a conclusion.
There is a linguistic ambiguity here. When you say "I don't like hot chocolate" that may either mean "I dislike hot chocolate" or "I have no opinion about hot chocolate." or even "It may be the case that I dislike hot chocolate or that I have no opinion about hot chocolate, but I'll leave you guessing about which one."
When someone says "X does not imply Y" it's not clear whether that means "X implies not Y" or "X has no opinion on Y."
This is why physicists talk in math.
Also "implying *anything*" is science in this context. If you have a theory that says nothing, that's useless. If you have a theory that makes meaningful predictions, even if they are stupid and wrong, that's progress.
Why not? Most of "ordinary science" consists of rationalizations, and I don't see anything wrong with that. If you are on the wrong track, then what will eventually happen is that the rationalizations will lead to a model of the universe that is so crazy that it will collapse under it's own weight.
I don't see anything wrong with "rationalization", since most of science works that way.
A lot of the different types of multiverses are logically incompatible so you *must* reject one if you accept another. If you think that the universe works by collapsing black holes generating new universes, that kills eternal inflation (and vice versa), because the two models are logically incompatible.
Well define "cause" and "exist" and the issue disappears.
No. It's not. Define "exist" and then problem goes away. Do numbers "exist"? Does anything outside my head, "exist"? Do I "exist"?
I don't see how the "existence" of "virtual particles" are any more problematic than the "existence" of "financial risk."
Personally, I'd argue that if you want to argue philosophy, it's best to do that with examples that you are familiar with. The problem with talking about "virtual particles" is that people get the facts wrong.
No you can't. (At least that's what the string theorists tell me.)
They are different situations.
If you have one uranium atom and you watch it decay, you *can* create a set of interpretations so that there isn't some "phantom" atom in an alternative universe.
The trouble is that if the decay of atoms is quantum mechanically random then if you have two uranium atoms next to each other then will probably decay at different times. I got two uranium atoms, they decay differently. OK.
So what happens is that if force coupling constants are quantum mechanically random (and string theory says they are), then when they get set up at the early universe, you are going to end up with different values for different parts of the universe. You can "fix" the problem by blowing up the universe so that we can see only one value, but that creates "other parts of the universe" with different values.
This problem isn't quite as bad with eternal inflation, because you can assume that whatever causes the force constants to be what they are have already caused the numbers to be set.
I'm not an expert in string theory, so I can't say no way. The people I know say that it's hard and they don't know if they can do it. (Again, any corrections from people that know string theory better than I can are appreciated).
I'd like to see you try, because that will help me to explain chaotic inflation to you.
The thing about eternal inflation is that you start with a scalar potential, cause it to inflate the universe, see when it stops inflating, and you'll find that for many scalar potentials, it doesn't.
Now you can come up with scalar potentials in which inflation does stop, so it's possible (but hard) to have inflation without eternal expansion.
But...
The thing about scalar potentials though is that they aren't some random "fudge factor." Once you have a specific scalar potential, then you plug that into your Langrangian for QCD, and that gives you an equation that you can use to calculate lots and lots of things, like the mass of the proton or quark interactions. If you change the scalar potentials then those numbers change.
So you are claiming that you can take any model with eternal inflation and turn it into a model without multiverses with exactly the same predictions.
I claim, you can't without coming up with something close to Last Tuesday-ism
That's not rule in the case of inflation. Inflation comes out of grand unification theories, which is semi-known physics.
Define "really happening" and "physical existence." If you have turbulence, you have waves and eddies which most certainly "physically exists". If you have a theory of turbulence that doesn't describe what is "really happening" then this seems a bit silly.
No more than it is to claim that exoplanets exist or to claim that Paris France exists even though I've never been there. Just because I can't see it doesn't mean that it's not there.
In the case of eternal inflation, the idea of "other universes" is something of a misnomer. The idea is that the total universe is much much larger than we can directly observe, and talking about "other universes" is like talking about "other galaxies." I've never been to Paris, but I can figure out that it exists. Talking about parts of the universe we can't see isn't much different from talking about places in the world that I can't go.
One reason that I tried to avoid getting into philosophy is that I thought that we could *avoid* the philosophical issues once I established *why* cosmologists are talking about multiverses. You take the physical laws as we think they exist or that could reasonably exist, and you end up with large parts of the universe that we can't directly see.
It's not.
There's a difference between "not in our lifetime" and "totally impossible." Also showing whether or not those interpretations are the same or different is what makes it interesting. If it were shown that it doesn't make a difference, then it doesn't make a difference.
The other thing is that we are making some progress. There's been a lot of work on "decoherence" and it's pretty clear that "naive Copenhagen" isn't going to work. The problem with "naive Copenhagen" is that you collapse the wave function by waving a magic wand, but there are lots of systems in which it's not obvious when you should wave that wand.
I've just spend a few pages trying to explain why you've got your physics wrong. If you aren't listening then maybe someone else will. If no one is listening, then it's a waste of my time.
  • #35
Forgive the interruption again, but tell me: Did the math come after some people thought up the idea of the multiverse, meaning, the math was engineered in order to give substance to the idea of the multiverse or to prop up the multiverse?
Or there was established math going on in the mathematical exposition of a physical phenomenon, and some people could not help but come to posit the idea of the multiverse?
And they continued with the established math without engineering or if I may inventing a new math, in order to expound on the multiverse?
Yrreg
  • #36
Ken G said:
There have been a few threads of late on the multiverse concept in cosmology, and whether it can be viewed as a viable, albeit currently underconstrained cosmological theory that is leading us to demonstrably correct discoveries about our universe, or if it is essentially a fairly arbitrary metaphysical conviction that is masquerading as science. I'd like to advance the latter thesis, and central to my argument is the Popperian stance that if, as Feynman said, science should be a way to keep us from fooling ourselves, then we need theories that make "risky" predictions-- predictions that, were we to be skeptical of the theory, we would expect to fail. A theory that only makes predictions that no one can expect to fail, even if they discount the theory, is more like a technique for performing rationalizations than it is a technique for making predictions.
"There have been a few threads of late on the multiverse concept in cosmology, and whether it can be viewed as a viable, albeit currently underconstrained cosmological theory that is leading us to demonstrably correct discoveries about our universe, or if it is essentially a fairly arbitrary metaphysical conviction that is masquerading as science."
So, what is the finding of the published savants of astrophysical and sub-atomic cosmology?
Have they taken a vote on the multiverse whether it is science or masquerading as science?
Yrreg
  • #37
Nope. People weren't looking for multiverses, it just comes out of the math.
Let me talk about one specific example, which is the one that I know the best. The eternal inflation model.
There is a lot of evidence that the universe underwent a huge amount of expansion in the early universe (see wikipedia article on inflation). So then theorists think about what could have caused this expansion. It turns that's easy, you can invent a lots of ways to have the universe suddenly expand. The hard part isn't figuring out how to make the universe expand. It's to try to make the universe stop expanding.
OK, so the theorists go into the back room and figure out ways to get the universe to stop expanding. In the case of inflation, the conditions are extreme, but they aren't so extreme so that our theories will totally fall apart, and people have come up with various mechanisms to stop the universe from expanding rapidly and to get the universe to settle down to "normal" expansion.
But we have another problem. Most of those mechanisms are 100% effective. Which means to say that you can stop rapid expansion in *part* of the universe, but you aren't stopping expansion in *all* of the universe. At that point a theorist points out that this will still work. You don't have to stop rapid expansion in all of the universe, you just need to stop rapid expansion in the part of the universe that we see, which means that mechanisms which stop rapid expansion in an area of the universe that is larger than we see are still possible.
But... Suppose you have a mechanism that stops rapid expansion in 99.999999% of the universe. Most of the universe stops rapid expansion. A tiny part doesn't. Very quickly that tiny part is going to keep expanding and much up most of the universe. Now most of that section may eventually stop expanding, but all you need is a tiny part of that doesn't, and the process ends up going on forever...
At this point you have the eternal universe picture. Now we aren't exactly sure what is the nature of the thing that caused the universe to inflate. There are about hundreds of different ideas. However, you can mathematically show that most of those will lead to the situation in which some part of the universe doesn't stop inflating.
Now as we get more information, we can reduce what is possible. It's possible that once we go through all of the data that the mechanism that works will stop inflation in 100% of the universe. But a lot of the things that are possible right now, will just stop inflation of part of the universe, that that leaves the rest of it expanding. The other thing is that the different mechanisms are the result of high energy physics, so it's possible that particle experiments will give us the "right equation."
I should point out that it may make more sense to stop using the term "multiverse". In the inflationary picture, you have "part of the universe that we can see and that has stopped inflating" and "part of the universe that we can't that hasn't."
If you start the universe inflating, and the mechanism you use to stop it inflating isn't 100% effective, then you will get large parts of the universe that keep inflating. That's a direct consequence of the math.
But you don't need the "stopping mechanism" to be 100% effective to work. You just need it to work in the parts of the universe that we can see, and then it could work. It's a lot easier to come up with a stopping mechanism that is say 10% effective or even 99.99999% effective than 100% effective, and if the stopping mechanism is anything less than 100% effective, you are going to have "parts of the universe that don't stop expanding" and the one part of the universe that doesn't stop inflating is going to make up most of the universe.
No one invented anything particular to get "multiverses." In fact, for inflation, it probably makes more sense to talk about "different parts of the universe" rather than "multiverses."
  • #38
It is important to distinguish between physics as we know it, playing out in as yet unknown ways, versus inventing completely new physics-- especially in regard to whether or not there remains an xunsatisfied need for making "risky" predictions.
Personally, I'd say that anyone who imagines that the story of inflation is going to be just "connecting the dots" of current physics is not being at all honest to themself, but only time will tell who is right-- and probably a lot of time. I'll settle for, if we are on our death beds, and the "dot connecting" isn't done yet by then, then we can agree it had to be something more than dot connecting after all.
Not "problematic" at all: A risky prediction is a prediction that anyone who didn't understand the theory that made it would have no reason to expect to hold.
I certainly wasn't aware that non-perturbative effects observed in the strong force is evidence for a multiverse, rather than simply evidence for non-perturbative effects in the strong force. I daresay you are getting a bit caught up in the string theory hype now. I haven't seen how string theory has fulfilled the grandiose claims we often see about it, and the way it doesn't constrain the coupling constants is usually seen as a serious weakness of string theory-- not a strength that is explaining the observations.
That's just not what a prediction is, period. A prediction always looks like this: experiment A will come out X.
The analogy is not good, because establishing exoplanets involves predictions of exactly the form I just said. Even Newton could have thought of a dozen ways to directly detect them, in his sleep. He just wouldn't have had the technology to do it.
I do know a string theory expert I can ask that. I expect he'll say you can accept any theory without buying the metaphysical baggage (you know, "shut up and calculate", and all that).
In many ways the Copernican principle is the opposite of the multiverse, as the latter asserts that we are living in a very special universe, to account for its seemingly finely tuned attributes.
I don't believe that. I'm sure there's no difficulty rejecting the existence of multiverses, and accepting string theory anyway, as an empirical prescription for making predictions (i.e., as physics, not metaphysics). The same could be said for quantum mechanics-- if one requires that all time evolution be unitary, then one must hold to some kind of many worlds, but one can simply view unitary evolution as a provision of some aspect of the predictive machinery of quantum mechanics, rather than some metaphysical claim on reality-- and still use quantum mechanics quite easily, with only one world.
It's fine to invoke the symmetry, and set the randomness. That's all a prescription for making testable predictions, not a metaphysical claim on reality. The virtual particle example comes to mind again. Symmetries are made to be broken in reality, they are just mathematical devices. Does someone have to believe symmetries really exist to use them in deriving constants of the motion in classical physics? Only the devoted rationalist actually believes their own postulates (and quite against the weight of historical evidence, I might add).
That's all well and good, and so let's observe those other regions where the constants are different. Not possible? Then it ain't science. What is the technology that would be required to detect those other universes where the physical constants are different? The purpose of good science is to answer just that kind of question, not to make metaphysical claims on existence.
I understand, but what I'm saying is the multiverse was added by a strong desire to rationalize issues that we really just have no explanation for. Those who tend to think highly rationalistically, and think the universe "is governed by laws", as if the universe looks up a law or makes a calculation every time it does something, will always be looking for ways to rationalize what happens. But they have to be honest to themselves and ask-- are they just spinning a tale, like a creation myth, because it helps them believe in their rationalistic picture? Or do they really have scientific evidence that their claims on reality are getting supported by successful risky predictions?
Just look at those words-- the math gives them no choice. Quintessentially rationalistic! This is my whole point, the math doesn't rule the universe, the universe, as analyzed by our ability to perceive it, gives rise to the math we put into our theories. Math involves idealizations and approximations, it doesn't make claims on what exists-- unless you adopt rationalist metaphysics. Take the Greek belief in orbits as perfect circles, that was the math leading what exists. But the empiricist works the other way-- the observations are crudely consistent with circles, circles are simple, build a model using circles, but never make claims on what exists based on the math of circles, because you know it's going to be an idealization from the get go, and you know it is going to break down at some level of precision.
Your descriptions actually sound pretty reasonable, I think you are doing a good job of presenting their case, kudos to your descriptions-- but you are missing how rationalistic and metaphysical that case is, and how extraneous it is to the actual predictions of string theory (if and when there really are any such thing), as per the "shut up and calculate" approach to physics.
Those are the questions of metaphysics. Obviously metaphysics goes away if you resolve metaphysics, but you can't, which is why it's metaphysics.
Financial risk is not an ontological claim, virtual particles are to some, and not to others, so they argue the metaphysics of them. You might not like to enter into metaphysical arguments, which is fine, but that doesn't make it not a metaphysical argument-- like the existence of the multiverse.
I agree, which is the entire reason I started this whole thread with an analogy that we are all familiar with! But no one has chosen to avail themselves of the analogy to argue their point.
I don't believe them, I think they are not using their imaginations. I can easily think of a way to use probability distributions on the coupling constants without requiring that any more than one of them is ever instantiated. You need to observe the others or else they are just a mental construct, the "math" telling us what is, like virtual particles.
Yes, but you have two uranium atoms. We don't have that, we have one universe to observe, and we have no idea if there even is another "uranium atom"-- it's pure rationalization that the other one exists. Make a risky prediction that requires that other uranium atom, and then you have something, not just some math that can be rationalized that way (like universal unitary evolution in quantum mechanics).
Well, the mathematical model "creates" that, but creation doesn't actually occur by mathematics-- unless you are a devoted rationalist. Many who are not of that metaphysical bent see that as reversing the correct logic.
It's easy, you only think it's hard because you have limited the metaphysical options. Let's say you give me a theory that says space spontaneously inflates, at random, and with random coupling constants. That's a form of chaotic inflation. You use the theory to make risky predictions (let's pretend that was actually possible, maybe it will be someday), which pan out, so we like your theory.
Now, to you, it makes sense to say that this implies the existence of multiple universes, because inflation keeps happening. I say that your theory is a theory devised by an intelligent being that is capable of interacting with its universe. Of course it is not what the universe is "actually doing", that's an absurd rationalist pipe dream that has never actually been true in the entire history of physics. So instead, we quite reasonably interpret your theory as a kind of idealized toy that makes nice predictions. Then we ask, does this imply the existence of other universes?
Well, we have no way of knowing if the inflation in your model has ever happened before, or if we are the first event. Can we say which is more likely? Well, if your theory only has meaning for describing how an intelligence interacts with its environment, because that's really where the meaning in any physics theory lies, and quite demonstrably so, then it has no sway at all over any situation that is logically inconsistent with the presence of intelligent beings, like coupling constants that cannot be inferred by any intelligence because they are inconsistent with the presence of intelligence. So there is no "fine tuning problem", because a universe that has intelligence in it to interact as we do must infer the constants we infer, and a universe that cannot have intelligence in it to interact with that universe is a meaningless construct that we have no language to even describe, let alone calling it "another universe." Thus, we cannot claim that our universe is unlikely so must be one of many-- go back to the analogy in the OP, I introduced it precisely to handle this situation. As easily as we take the metaphysical stance that chaotic inflation (a random deal) implies there must have been many other deals, we can take the stance that the rules of the game were devised expressly to make the hand we were dealt special in exactly the way we find it to be special. Or, we can just as easily say that the deck from which the cards were dealt (that "random" quantum mechanical distribution) was stacked to produce a hand that could infer a theory like that, given that theories can only be inferred by intelligent beings. So it's all a question of stepping away from the assumptions that highly rationalist thinkers make, those who tend to see the laws as being separate from our involvement in arriving at them.
Now, you may object to my alternatives on the grounds that they seem like less natural assumptions than a multiverse. I might counter that they aren't unnatural at all if we say that theories are beholden to our own ability to arrive at them. But that debate is a metaphysical debate, proving the point that the existence of the multiverse, even for chaotic inflation models themselves, is an inherently metaphysical issue.
You betcha. The analogy in the OP was meant to convey that.
That is a metaphysical exercise. If you argue that is necessary to understand if the multiverse exists or not, I say, "yup, you got it."
Indeed, so let's look at how you figured that out. Was it an interpretation of some law of physics that led you to that conclusion? I'll bet it was observations that led you to that conclusion-- you observed photographs of Paris, you observed people talking about Paris, you observed books that detailed Paris and also talked about other things that you did find to pan out, so you trust the book. Basically, you amassed a wealth of direct empirical information that Paris exists, information that you would have no reason to expect to observe if you were skeptical about the existence of Paris. The existence of Paris makes risky predictions!
Then what are the risky predictions, that's what I keep asking.
If you think physical laws can dictate to what you can't see, which is rationalistic. The empiricist points out that to avoid fooling yourself, you still have to support your stance with successful risky predictions. So it has been true since the ancient Greeks, who were masters of rationalization-- and masters of fooling themselves.
It's not.
And this is the sole substantive issue that has emerged-- whether or not chaotic inflation makes risky predictions that have been supported. Gaussian noise has supported the idea that the noise is quantum mechanical, which supports the inflation phenomenon. That's all I've seen referred to, in places like the WMAP website-- support for inflation, not a multiverse. But even if the single-shot models of inflation that people were toying with did not make that prediction, causing chaotic forms to be currently in vogue, these models are still so vague that it's not clear much more can be said. Those watching the signposts might say they are pointing toward chaotic inflation models, but it remains a leap of faith that that flavor of model can work, because none have yet. There is no model of inflation that is currently indicated as the proper model, which makes the whole issue highly hypothetical at present. But as I stressed above, even for chaotic inflation, the claim that this implies that a multiverse exists is a metaphysical claim, because other ways to interpret that very same model, as in the card game analogy, simply express different metaphysical assumptions-- and result in different conclusions about the need for a multiverse.
This is off topic, but the only thing "naive" about the Copenhagen interpretation is most people's understanding of it. What Bohr was actually talking about was the fact that physics involves an interface between the physicist and her environment, and collapse occurs somewhere in that interface. It was never a requirement of the Copenhagen interpretation that that collapse happen at any given place in that interaction, Bohr knew that he simply didn't have enough constraints to say more. Decoherence doesn't change that in the least, the Copenhagen interpretation has no difficulty whatsoever in accounting for gradual decoherence, because even the experiments that study gradual decoherence always involve "crossing the Heisenberg gap" at some point along the way-- they still represent the interaction of the physicist with his/her enviroment, so Copenhagen still says the collapse is inherent in that interaction, it's just collapsing an incompletely decohered system.
You might imagine that's what you've done, but I still do not see a single statement I made in this entire thread that could be considered wrong physics. Please quote the statement if you think otherwise, rather than making vague and opinionated remarks.
  • #39
The published savants of astrophysical and sub-atomic cosmology talk about the issue to try to avoid "unnecessary philosophy."
A lot of the math is hard, so much of what gets published is of the form "if you assume X, then Y is going to happen." If you don't like Y, then X is wrong. If you can't accept multiverses, then you can't accept string theory as it currently exists.
As it is discussed in the professional papers, it's clearly science. One problem is that what is presented to the public tends to oversimplify things, and it's different from what's in the professional papers.
If you ask me about whether "multiverses" exist, the short answer is "I don't know." The medium answer is what I'm trying to represent here, and it's boring to a lot of people. The long answer involves lots and lots of greek letters. It's not going to make for an interesting video on Youtube.
Whereas if I start saying that "multiverses exist and God doesn't" that gets people's attention, and the stuff goes virial.
One thing that I appreciate about your asking these sorts of questions is that it shows that you (unlike most people) have the patience to listen in what's really going on, rather than just go for the "gee-whiz, quick answer" stuff.
  • #40
The thing that bothers me about 'parallel' universes is the lack of empirical evidence. I agree the mathematical basis for a 'multiverse' is solid, but, unlike Tegmark, I am unwilling to concede their existence without empirical evidence.
  • #41
What's more, I'd say, and indeed have said, that Chronos' empiricist standpoint is extremely common among professional astronomers and educators. The one place where it is much rarer is among cosmology theorists, which goes a long way to explain the divide that is being explored in this thread, as well as the importance of guidance from thinkers like Popper to help avoid the rationalization problem.
  • #42
I'm listening and finding it very interesting. I had no idea about this.
  • #43
It's actually not rare. The problem with asking for empirical evidence is "what constitutes empirical evidence?" If we want to know if eternal inflation is true or not, then what exactly is the observational signal that we should be looking for?
The job of the theorist is to come up with the answer to this question. If multiverses exist, then what are the observational consequences? Trying to figure this out doesn't mean that the person thinks that multiverses exist.
  • #44
I don't think that it does, and yet, it is all too clear that the "persons" we are talking about do not so limit their rhetoric, which is the whole issue. If cosmology theorists limited their language to statements like "my model, motivated by multiverse thinking, predicts this," there would be no motivation to pose the question of this thread-- a theorist making predictions is clearly doing good science, and is allowed to cite any motivation they like. Instead, what we see are highly rationalistic arguments like "the math leads us to conclude this", or arguments along the lines of, since this very simplified class of models, involving scalar potentials that have never been observed in any experiment, require a chaotic form of inflation to get the observations, we can conclude that inflation is chaotic and our universe is one of many. It's similar to statements like "to accept string theory, you have to accept a multiverse"-- they are simply not statements like "expect to observe A if there is a multiverse, and not A if there isn't." That is why, at the very least, we can say the case has not been made that a multiverse is not a primarily metaphysical construct. That may not always be the case, but it appears to be the current state of affairs. Perhaps it goes too far to therefore assert that the multiverse is not science, but it also seems to go too far to assert that anyone who demands an empirical foundation for statements of what exists should hold that the multiverse does.
  • · Replies 71 ·
16K
  • · Replies 64 ·
11K
  • · Replies 62 ·
13K
  • · Replies 19 ·
