Voltage spawning a cathode ray
The formation of a cathode ray is a result of electrons emitted from the cathode and accelerated by a negative voltage applied to the vacuum tube. This process involves thermionic emission, where the cathode is heated, or the use of a cold cathode, which requires a high voltage to ionize the gas within the tube. The potential difference necessary for this acceleration is created by the voltage between the cathode and the anode.
  • Understanding of thermionic emission
  • Knowledge of vacuum tube technology
  • Familiarity with electron behavior in electric fields
  • Basic principles of voltage and potential difference
  • Research the principles of thermionic emission in detail
  • Explore the design and function of cold cathodes
  • Learn about the physics of electron acceleration in electric fields
  • Investigate the historical development of vacuum tube technology
Physics students, electrical engineers, and anyone interested in the principles of electron behavior and vacuum tube technology.
vanmaiden
In descriptions of the cathode ray, various sites mention how the ray is formed from a voltage applied to the tube which spawns the ray on sees in the vacuum tube. Could someone elaborate on how a voltage can spawn this beam? As in, where does the potential difference come from and so on.
Thank you
A "cathode ray" is simply an electron that has been emitted from the cathode and accelerated by the negative voltage applied. (Or a positive voltage from an anode) The electrons can be emitted through "thermionic emission" by heating the cathode, or a "cold cathode" can be used in which a very high voltage ionizes the remaining gas inside an evacuated vacuum tube.
http://en.wikipedia.org/wiki/Cathode_ray
Thank you! :smile:
  • · Replies 28 ·
  • · Replies 48 ·
  • · Replies 17 ·
  • · Replies 16 ·
