PeterDonis
Mentor
- 48,997
- 25,089
Naty1 said:In any case, I had been thinking that slowly raising photons from varying gravitational potential depths would result in a different characteristic of light at the surface versus them following null geodesics as when freely emitted; that some changes in characteristics would result. Can you comment about what you think happens?
In a simple model where the light inside the box travels freely except when it hits a wall of the box, the periods of free travel can still be modeled as they would be if the box weren't there. But the collisions with the wall of the box change things.
The simplest assumption is that the walls of the box are perfectly reflecting mirrors; this means that each collision of a photon with a box wall can be modeled as perfectly elastic, with the photon's momentum perpendicular to the box wall reversing direction (and a corresponding change in the momentum of the box). In another thread I used this type of model to describe how one could extract work from a box filled with photons by slowly lowering it instead of letting it freely fall, and how extracting the work would lower the "photon temperature" inside the box, whereas a freely falling box of photons would have the same "photon temperature" inside as it fell (relative to the box, in both cases). But in either case, the "average" motion of the photons inside the box is no longer null, but timelike--it's just the motion of the center of mass of the box+photons.
One could try more complicated models, but I'm not sure what the point would be. The key point is already clear from the above simple model: the behavior of light inside a box, when the interaction with the box is included, does change.
