How Does Closing a Switch Affect Capacitor Charge Over Time?
  • Thread starter Thread starter thunderhadron
    Charging
The problem involves analyzing the behavior of two capacitors in a circuit when a switch is closed after one capacitor has been charged for a long time. The original poster seeks to determine the charge on the rightmost capacitor as a function of time, given that it was initially uncharged.
  • Participants discuss the initial conditions of the capacitors and the effect of closing the switch on their charge distribution. There are questions about the voltage across the capacitors immediately after the switch is closed and how to account for the discharging of the left capacitor while the right capacitor charges.
Some participants have offered insights into the initial voltage conditions and the behavior of the capacitors after the switch closure. There is ongoing exploration of the charge distribution and the implications of the circuit configuration, with no explicit consensus reached on the final interpretation of the charge dynamics.
Participants note potential confusion regarding the charge values on the capacitors and the role of resistors in the circuit. There is also mention of assumptions about the initial charge on the left capacitor and how it affects the right capacitor's charging process.
  • #31
What do you mean by "the topmost capacitor"?
  • #32
thunderhadron said:
I am sending you an img. http://img3.orkut.com/images/milieu/1340682480/1340707691932/204964818/ln/Zt96paa.jpg?ver=1340707704
Well I mean to say that at the instance of closing the ckt the current has two ways at point c, one from capacitor link and another from resistor through wire cd. So the resistance sorry capacitive reactance of the topmost capacitor is very less at this time hence the charge will flow form capacitor.
Hello thunderharon,
Look at the rectangular loop formed by the right and left capacitor.Apply Kirchhoff's Voltage rule.The capacitances being same they ought have the same charge initially.The left capacitor achieved steady state in the time before switch was closed ,true but now it has to achieve the steady state once again in accordance with Kirchhoff's rules.
regards
Yukoel
  • #33
thunderhadron said:
Many times the problem says at the instance of closing the switch : Current will have two ways on the junction of resistance and cap. but the current will flow through capa at that time, it acts like zero resistance or superconducting wire at t = 0 but the time goes on the cap stores charge by leaps and bounce and resistance of it keeps on increasing.
And after a very long time when it gets fully charged it no charge flow through it, it acts like
R→∞.
ok, i understand now …
you're talking about problems with a resistor and a capacitor (or more than one
capacitor) in parallel, so that the current (or charge) can flow both ways
then yes, you're correct (apart from the "leaps and bounds"): the current (which before the switch closed was flowing entirely towards the resistor) will start flowing entirely towards the capacitor, but will then flow more and more towards the resistor until finally it flows entirely towards the resistor
(as if the capacitor started with zero resistance, and ended with infinite resistance)
  • #34
::Yukoel:: So like "tiny-tim" was telling me Its P.D. will become V/4 now so as the P.D. of the right capacitor. Is this correct?
  • #35
Sorry friend that was a slip of hand. I mean to say Rightmost..:shy:
  • #36
(In aspect of "leaps and bounds"): I mean to say slowly sorry if I use wrong words.
So is this theory doesn't fit for this problem also?
  • #37
thunderhadron said:
Many times the problem says at the instance of closing the switch : Current will have two ways on the junction of resistance and cap. but the current will flow through capa at that time, it acts like zero resistance or superconducting wire at t = 0 but the time goes on the cap stores charge [slowly] and resistance of it keeps on increasing.
R→∞.
yes it does, the two capacitors behave as one capacitor, which at first has zero reactance, with all the current going through it and none going through the resistor, and after a very long time it has infinite reactance, with all the charge going through the resistor
the only difference is that before all this happens, the charge rearranges itself from one capacitor to the other (the same charge)
  • #38
tiny-tim said:
yes it does
i.e. CV/4 , CV/4
And now charges have been redistributed in both of them just after the switch closed. But now the right cap is connected with battery also. Will it accumulate some more charge also? surplus?
  • #39
thunderhadron said:
i.e. CV/4 , CV/4
the left and right capacitors are now one capacitor
just cross them out in the diagram, and replace by one capacitor!
(even if their capacitances were different, they would still form one capacitor, but the initial charges would be CV/6, CV/3, say, and then the charges would stay in that proportion)
  • #40
Yes .As tim says you have to make one capacitor out of the two and technically they have been corrected in parallel.A prerequisite for parallel connection is same P.D. right?After it is done you have capacitor with an initial charge (adjust the charge in it according to the potential difference across the ends).Find the charge on this new capacitor as a function of time and then again using potential difference across it as a function of time you can retrieve what charges subside on the individual capacitors.
regards
Yukoel
  • #41
Hi friends,
As you guys told me to take the capacitors in parallel and try to find the time dependent equation, I am attaching an image of what I did to solve the ckt.
http://img4.orkut.com/images/milieu/1340682480/1341024902370/204964818/ln/Z96sxil.jpg?ver=1341024924
Now this charge will distribute on both the capacitors equally.
Hence the equation of the charge on both the capacitors will be
q = CV/2 (1 - e-t/RC)
But still this doesn't matches with the answer of the main problem.
Please tell me where I am doing wrong?
Thank you in advance for the reply.
  • #42
thunderhadron said:
Hi friends,
Hello thunderhadron,
The image is very small and is not magnified hence difficult to see.Anyways note that at t=0 q=_________? Your equation doesn't yield that .Does it?
Now you have unified the capacitors .The new capacitor will have a different value of charge for the same p.d isn't it?Relate that to each capacitor and get the correct equation.Maybe this would help.
regards
Yukoel
  • #43
hi thunderhadron! :smile:
(your picture is too small to read :redface:)
yes, the total charge on the double-capacitor starts at CV/2, so the left part is correct
but the double-capacitor does not have capacitance C, it has a new capacitance which must go into the time constant …
what is that capacitance?​
  • #44
2C ??
Well sorry for the size of img friends. Well I am attaching the same img. Please check it out.
  • #45
thunderhadron said:
2C ??
yes, of course (two capacitors in parallel, so you add the capacitances) :smile:
sorry, but i don't understand the lettering
j and i seem to be the same currents, and i don't understand when you're using i and when i1
can you please rethink your diagram, and then type your equations directly onto the forum?
(and I'm now going out for the rest of the day)
  • #46
i1 = dq / dt
Applying Kirchoff's law for loop C D E F C,
q / 2C - (i - i1)R = 0
[itex]\Rightarrow[/itex] q / 2C - i.R + i1. R = 0 --------------eqn (i) let
Applying Kirchoff's law for loop A B F G A,
V = i. R + (i - i1)R ----------------------------eqn (2) let
Solving eqn (1) & eqn (2),
eqn (1) X 2 + eqn (2),
q / C + i1. R = V
[itex]\Rightarrow[/itex] i1. R = V - q / C - - - -- - - - -- --eqn (3)
but, i1 = dq / dt
hence putting i1 = dq / dt in eqn (3) we'll get ,
dq / dt = (VC - q) / RC
[itex]\Rightarrow[/itex] dq / (VC - q) = dt / RC
Integrating, above equation
∫ dq / (VC - q) = ∫dt / RC
I don't find definite integral sign here so explaining,
Left integral : Lower limit : 0
Upper limit : q
Right integral : Lower limit : 0
Upper limit : t
[itex]\Rightarrow[/itex] ln [ (VC - q) / VC ] = - t / RC
[itex]\Rightarrow[/itex] (VC - q) / VC = e- t / RC
[itex]\Rightarrow[/itex] ( VC - q ) = VC . e- t / RC
[itex]\Rightarrow[/itex] q = VC - VC . e- t / RC
[itex]\Rightarrow[/itex] q = VC ( 1 - e- t / RC )
Now this charge will distribute in both the capacitors equally as, q = VC / 2 . ( 1 - e- t / RC )
But answer is not the same.
I am also attaching another image. Please check it out.
Please make me clear.
Thank you.
  • #47
thunderhadron said:
i1 = dq / dt
Upper limit : q
Upper limit : t
I think you have misused the limits here.As tim explained at t=0 each capacitor gets a CV/4 amount of charge and thus the resultant 2C capacitor gets ________C of charge,isnt it?
So at t=0 do you really have q=0?Or the value of q is the same as that intended in the blank?
Try substituting the correct value of q at t=0.The rest of your method is correct .With the right value of q at t=0 the answer is also correct.
regards
Yukoel
  • #48
(just got up :zzz: i had a good day yesterday! :biggrin:)
Upper limit : q
Upper limit : t
i wouldn't do the integral like that, with limits
for a ln integral, i'd say …
∫ dq / (q - VC) = -∫dt / RC
so |q - VC| = constant*e-t/RC …​
and then all you need do is find what the constant is (at t = 0) :wink:
(apart from that, as Yukoel :smile: says, that's fine!)
  • #49
Oh My God!
That's a blunder mistake I've done here. Thank you guys I'll get back to you soon.:!)
  • #50
a thundermistake! :smile:
  • #51
lol :-p
  • #52
Hi friends,
There is a problem after integrating with proper limits its going in this manner,
∫dq/ (CV - q) = ∫ dt/ RC
Left limit ==> CV/4 to q &
Right limit ==> 0 to t
ln[(CV - q)/ CV] = - t/RC
Placing the limits,
ln[(CV - q)/ CV] - ln [ (CV - CV/4) / CV] = -t / RC
since, ln a - ln b = ln (a/b)
hence,
ln [(CV - q) / (3CV/4) ] = -t / RC
==> (CV - q) / (3CV/4) = e-t / RC
==> (CV - q) = (3CV/4) . e-t / RC
==> q = CV - (3CV/4) . e-t / RC
==> q = CV ( 1 - 3/4 . e-t / RC )
Now it'll distribute in both as,
q = CV/2 . ( 1 - 3/4 . e-t / RC )
Still it is not the answer as given, q = CV / 2 . ( 1 - 1/2 . e-t / RC )
  • #53
no, you're getting confused …
your q is the charge on both capacitors combined, so at t = 0 that's q = CV/2 :wink:
(and i really really REALLY think you should stop using this "limits" method, use standard integration as in my previous post :redface:)
  • #54
Oh My dear tim,
I got the correct answer. And I've understand the problem completely now. And that is only by din't of you & Yukoel.
Cordially Thank you very much guys.
I appreciate your help.:approve::approve::approve::approve::!)
