How do bonding and antibonding MOs coexist in molecular systems?
  • Thread starter Thread starter HUMERA.S
    Bonding
Bonding and antibonding molecular orbitals (MOs) coexist due to the linear combination of atomic orbitals (LCAO) and valence bond (VB) models. Bonding MOs arise from in-phase overlapping of atomic orbitals, while antibonding MOs result from out-of-phase overlapping. The wavefunctions for bonding (σg1s) and antibonding (σu1s*) can be expressed mathematically, demonstrating their respective energy contributions to potential energy (ΔP.E.). The competition between bonding and antibonding electrons affects the overall stability of molecular systems, as indicated by the Bond Order equation.
  • Understanding of molecular orbital theory
  • Familiarity with linear combination of atomic orbitals (LCAO)
  • Knowledge of valence bond (VB) theory
  • Basic concepts of potential energy (ΔP.E.) and bond order
  • Study the mathematical derivation of wavefunctions in LCAO for various molecular systems
  • Explore the implications of bond order in predicting molecular stability
  • Investigate the role of π-bonds in molecular orbital theory
  • Learn about advanced molecular orbital calculations using computational chemistry software
Chemistry students, molecular physicists, and researchers interested in understanding the interactions between bonding and antibonding molecular orbitals in various molecular systems.
HUMERA.S
hello..
i have checked various resources but am unable to get a clear idea of how bonding and antibonding MO exist simultaneously? [following that bonding MO results due to in phase overlapping of atomic orbitals while antibonding MO results due to out of phase overlapping]
Chemistry news on Phys.org
that's kind of a simplified, cookie-cutter description of what is actually going on. To really understand what's going on you need to use either the LCAO (linear combination of atomic orbitals) or the VB (valence bond) models.
From either model, you would then need to write out the respective wavefunctions for each. Here's an example of a LCAO approximation for a homonuclear system for 1st period atoms:
σg1s=Cg [1sA + 1sB], for bonding
σu1s*=Cu[1sA-1sB] for anti
where "g" stands for gerade (bonding) and "u" stands for ungerade (antibonding)
As a side-note, you can do similar approximations for ∏-bonds as well. Also, these models can be used for systems larger than simple diatomics.
The functions for both σg and σu can be used to determine the ΔP.E. for bonding vrs antibonding electrons. Therefore, given the mathematical relationship between the two functions above, you should be able to see that the bonding electrons result in -ΔE, where as antibonding electrons result in +ΔE.
Thus, you could think of bonding and antibonding electrons in MO's as if they were in competition. As they each have an equal and opposite effect on the ΔPE, they more or less cancel each other out (as given by the Bond Order equation).
16K
11K
