Plate Boundaries: Collision, India & Himalayas
  • Thread starter Thread starter TonyTT
    Plate
The discussion revolves around the concept of plate boundaries, specifically focusing on collision boundaries, the geological interactions between the Indian subcontinent and Asia, and the implications for volcanic activity in the Himalayas. Participants explore various aspects of plate tectonics, including the nature of oceanic and continental crust, subduction zones, and the historical movements of tectonic plates.
  • Some participants express confusion about the nature of collision boundaries and question whether continental crust sits on top of the mantle in such zones.
  • There is a proposal that the Indian subcontinent is primarily continental crust, which collided with eastern Asia without significant subduction, leading to the uplift of the Tibetan Plateau.
  • One participant suggests that the lack of volcanoes in the Himalayas is due to the absence of significant subduction in the India-Asia collision zone.
  • Some participants discuss the density differences between oceanic and continental plates, noting that basaltic oceanic crust is denser than granitic continental crust.
  • There is a debate about the role of water on the ocean floor and its potential effects on subduction processes, with differing views on whether it contributes to the subduction or is merely a consequence of the oceanic crust's lower elevation.
  • Participants explore the idea of subduction zones forming between two oceanic plates, referencing examples like the Tonga-Kermadec Trench and the complexities of tectonic interactions in New Zealand.
  • One participant raises the possibility of a "twist" in tectonic plates leading to new plate formations over long time frames.
  • There is mention of the Molucca Sea Plate being subducted from both sides, illustrating the dynamic nature of plate interactions.
Participants express multiple competing views regarding the mechanisms of plate tectonics, the role of water in subduction, and the characteristics of collision boundaries. The discussion remains unresolved with no consensus on several points raised.
Participants acknowledge limitations in the simple models of plate tectonics and the need for a more nuanced understanding of geological processes, particularly in complex regions like New Zealand.
TonyTT
Hi. I am confused about plate boundaries. In school we always drew diagrams where the continental crust sat on top of the oceanic crust. With that in mind, what is a collision boundary? Is this where continental crust sits on top of the mantle? How did India collide with Asia? Is the Indian sub-continent sat on top of oceanic crust and the approach to the Luarentia is a normal destructive plate boundary. If so, why are there no volcanoes in the Himalayas?
Keep that picture - now imagine that the entire crust (continental and oceanic - the whole thickness) has cracks in it that go vertically through from the surface to the mantle. The cracks all join up so the crust is divided into large slabs that float on the mantle. The slabs are the plates.
Since they float they can move about, and hit each other. Where they hit, they can can do one of three things: they can buckle upwards, buckle downwards, or one can slide under the other (they can also slide along each other while they do this).
Google "continental drift".
Hi Tony
welcome to PF
just a little test question for you to set the scene ...
Do you know why the continental crust sits above the oceanic crust in a collision zone ?
Simon's response about doing some info digging on continental drift is good and it will show you a lot about where the different continents started from.
But to get you started ... Gondwana consisted of several distinct continents as we see them today Antarctica, South America, Australia, Africa and India. With rifting that occurred along the "continental margins" those continents moved and are still moving northwards relative to Antarctica.
The Indian continent broke away from Antarctica ~ 220 ma (million years ago) and finally collided with eastern Asia. There wasnt any significant subduction as the Indian continent for the most part is continental crust rather than oceanic crust. Its full on frontal collision, (with only a small amount of subduction) that has caused the raising up of the Tibetan Plateau. If you would like an analogy --- think of the dirt that builds up in depth and width in front of a bulldozer blade, with India being the bulldozer. It is only the continuing collisional forces that are keeping the plateau up. If the collisional forces stopped ie. India stopped its northwards motion, then the Tibetan Plateau would start to subside until it reached isostatic equilibrium There's another term you can google ;)
Its the lack of significant subduction in the India - Asia collisional boundary that is the reason why there are no volcanoes in the Himalayas.
cheers
Dave
Is it true that the ocean plates tend to go down because they are lower and heavier than continental plates, both because they have water on them and because their minerals are more basaltic or full of magnesium and iron than minerals on continents (granitic and felsic)?
hi MK
yes that's the primary reason ... basaltic rocks are denser than continental rocks.
I have never thought about the effect of any of the mass of water sitting on top of the seafloor. That may also help with the subduction ... mite have to do some research on that one :)
Dave
The water on top thing :-- water is on top more as a consequence of the fact that ocean crust is lower, rather than a cause.
? that didnt really make any sense ?
we weren't blaming the water for making the ocean floor lower in general... more so if it has an effect at the subduction zone in particular in aiding the subduction process.
I suspect it doesn't ... but its an interesting idea
Dave
... besides, effects can also be (contributary) causes.
I though you could have a subduction zone between two oceanic plates?
I was thinking about that earlier. ... say the Tonga - Kermadec Trench, where Pacific Plate oceanic crust is subducting under Australian Plate oceanic crust. I wonder what determined the way that subduction zone formed ? that is, was it just pure chance that the Pacific Plate went under the Australian Plate rather than the other way around ?
cheers
Dave
It may be - though I can imagine one end of a plate trying to go one way and the other trying to go another way - getting you a twist in the middle (maybe a tear and a new plate forming?) We are talking about a looong time here.
I always figured that the bit of crust that ends up on top by whatever means will tend to end up, over a long time frame, as a continental plate anyway.
actually I know of one place where that's happening, back in my home country of New Zealand. there's some seriously tectonics happening in the central NZ area.
As you come south down the Tonga - Kermadec Trench, it becomes the Hikorangi Trench off the east coast of the North Island of NZ. The Pacific Plate is subducting down under the Nth Is. and is what fuels the Taupo Vocanic Zone in the central Nth Is. This subduction continues further south and into the top end of the upper South Island.
Then there is a significant change in tectonics and the Pacific Plate changes from subduction to overriding the Australian Plate. It is this oblique slip motion that has given rise (pun intended) to the Southern Alps one of the youngest mountain ranges anywhere on Earth at only ~ 5 million years old. This oblique slip motion has a 3:1 ratio, that is for every 3 metres of horizontal motion there is 1 metre of vertical motion. In a mere 5 million years there has been some 500km of horizontal motion aling the Alpine Fault ( the Pacific - Australian Plate boundary) running most of the length of the South Island.
To top all that off, as you leave the SW corner of the Sth Is., subduction again becomes the predominant tectonics BUT now its the Australain Plate subducting under Pacific Plate, a total role reversal! and this continues further south past Macquarie Island.
the above image shows that in a visual way
The next image shows the rotation poles that produce that motion and the magnitudes of the motion as it varies along the length of the plate boundary
in my next post I will put a couple of images showing the crossections across the South and North Islands
Dave
OK the second part of the post
These are a couple of drawings I did years ago showing the crosssection views across the North Is and South Island of New Zealand. It shows the subduction under the Nth Is and the uplift of the Sth Is.
cheers
Dave
Dave
opps :blushing:
my mistake
btw. i think water does "lubricate" the subduction process.
Certainly. One of the most interesting examples I know of is that of the Molucca sea plate, an ocean plate being swallowed up from both sides. I guess the Earth is hungry!
I see in the NZ example that the "twist" area occurs in a region of continental plate and there is oceanic plate subducting on either side of it.
I suspect that the simple models of plate tectonics being considered at the start of the thread are actually not quite up to handling the nuances of the actual situation.
BTW: small world: I live in Auckland NZ. Kiwi's seem to be more active online than the size of the country would indicate.
Simon Bridge said:
... I suspect that the simple models of plate tectonics being considered at the start of the thread are actually not quite up to handling the nuances of the actual situation.
That may be true but it still makes for good discussion :)
ah hah for some reason I had you pegged as in the UK.
I'm originally from the Dunedin area, Edinbrugh of the South ;) I'm 4th gen Scot.
Did Geology at otago Univ.
Have been in Sydney for the last 12 yrs or so, this side of the Tasman isn't quite as geologically interesting
Dave
Over a dram or three aye ;)
kia ora.
Interesting map of earthquakes, which highlights the Earth's subduction zones.
http://www.ouramazingplanet.com/3114-world-earthquakes-map.html
Incompressible media more or less undergo isochoric (constant volume) process when loads are applied. Compress in one direction and the volume expands in the other two directions, or compress in two directions and expansion occurs in the third direction. If land rises somewhere, it must sink elsewhere. Of course, Earth is a bit more complicated. One must consider thermal expansion and changes in density.
There are volcanos in the Himalayas. The active (last erupted in 1951) volcanic Kunlun Mountains in the Himalayas are the tallest (greatest altitude) volcanos in the northern hemisphere. In terms of prominence, they're not so big. They're just pyroclastic cones. Their great altitude is a consequence of the great altitude of the Himalayas rather than volcanic output.
A better question is "why are there so few volcanos in the Himalayas?"
That's also another mistaken concept. The Indian plate is subducting under the Asian plate. See for example Nábělek et al., Underplating in the Himalaya-Tibet Collision Zone Revealed by the Hi-CLIMB Experiment, Science 325:5946 (2009) DOI: 10.1126/science.1167719That said, there is a big difference between continental collision zones and oceanic subduction zones. One key difference is that the density of the subducting material. This makes continental collision stop much sooner than subduction proper. Another key difference is that a subducting oceanic plate is heavily saturated with water. This water load is a key cause of the volcanism behind the subduction zone. Colliding continents aren't so heavily saturated, hence significantly reduced volcanism.
  • · Replies 33 ·
20K
10K
