Does Q remain stationary with respect to P all the time?
The discussion revolves around the motion of points P and Q on a rolling body, specifically whether Q remains stationary with respect to P at all times. The context includes theoretical considerations of rolling motion without slipping and the implications of different reference frames.
  • Some participants propose that Q is stationary relative to P in a co-moving rotating reference system, as their distance remains constant.
  • Others argue that Q is not stationary relative to P in an inertial reference frame, as Q moves while P is at the topmost point.
  • A participant notes that while P moves at a velocity of 2v, Q has a velocity of 0, leading to confusion about their relative motion.
  • Another participant clarifies that P and Q, being at fixed positions on the rolling body, will not be in the same position at different times, thus they are not relatively stationary.
  • There is mention of the terminology used in physics regarding "rolling without slipping," which some participants find important for understanding the context of the question.
Participants express differing views on whether Q remains stationary with respect to P, indicating that multiple competing perspectives exist without a consensus on the matter.
The discussion highlights the importance of specifying the reference frame when analyzing motion, as interpretations vary significantly based on this choice.
kalpeshk2011
A body is rolling without slipping. Let P be topmost point at an instant and Q bottom-most point at that instant..Is it true that Q remains stationary with respect to P all the time?
What i thought was the purely mathematical thing. P will have velocity 2v to right and Q will have 0 velocity. Velcoity of Q with respect to P comes out to be -2v. BUt thinking about it, P is always at a distance of 2r from Q. So i am confused as to what should be answer?
hi kalpeshk2011! :smile:
is this a translation?
if the question was originally written in english, it was quite badly written :frown:
the way i read it is that P and Q are particular points which are identified by their position at, say 2 o'clock
since at 2.05 they'll both be in completely different positions, no they're not relatively stationary (thoguh of course they do remain at the same distance from each other)
but i expect the question is meant to mean "Let P be the topmost point at every instant and Q the bottom-most point at every instant"
I assume this is on a level surface. Yes, P will still be 2r from Q, but velocity is a vector. Instantaneously, Q will be stationary while P will move at right angles to the line joining PQ, so the distance between them won't change. A little later, P will still be moving at right angles to the line joining it to the new lowest point, Q', but tending to move away from the new position of Q. But that is counteracted by the way Q is now moving, so the distance PQ stays fixed.
P is a point which is initially at the top. Similarly Q is initially at the bottom..YOu didnt answer my question. Is Q always stationary with respect to P?
no, they'll be in completely different positions, going round each other, so they're not relatively stationary (though of course they do remain at the same distance from each other)
ok thank you very much :)
I don't know which course this is meant for, but keep in mind that in car tire terminology, if it's not "slipping", then it will never roll :smile: There is actually a magnitude called "slip", which has to do with the deformation of the tire. If slip=0, it will stay in place until the end of time.
i know nothing about "car tire terminology", but i do know that in "physics exam question terminology," a tyre that is rolling does not slip :wink:
(the phrase "rolling without slipping" is extremely common in physics exam questions, and indeed occurred at the start of this question)
That's why I mentioned it, in case that it's not the typical physics course :wink:
Yes but also no: it depends on the reference system that you assume - and in this case, you did not specify it. A point is not a reference system. :-p
1. Q remains stationary relative to P all the time in the sense that their distance doesn't change; thus, Q and P are stationary with respect to a co-moving rotating reference system. Another, well known example is that of "geostationary" satellites.
2. Q is not stationary relative to P in the sense that Q is moving relative to P with respect to any inertial reference system - which is what we commonly use for descriptions of physics.
Harald
10K
  • · Replies 97 ·
  • · Replies 35 ·
  • · Replies 16 ·
