Can the Photoelectric Effect Cause Metal Oxidation in a Vacuum?
The discussion centers on the photoelectric effect and its implications for metal oxidation in a vacuum. When light with sufficient frequency strikes a metal, electrons are emitted, leading to a positive charge accumulation on the metal. However, oxidation in the traditional chemical sense does not occur, as metals do not have individual atoms that can be oxidized; instead, they possess a collective electron cloud. To prevent excessive positive charge buildup, metals are typically grounded to allow for electron replenishment.
  • Understanding of the photoelectric effect and its principles
  • Knowledge of Coulomb's law and electric potential
  • Familiarity with metal properties and electron behavior
  • Basic concepts of grounding in electrical experiments
  • Research the principles of the photoelectric effect in detail
  • Explore the implications of Coulomb's law on charged particles
  • Study the properties of metals and their electron clouds
  • Learn about grounding techniques in electrical experiments
Physicists, electrical engineers, and anyone interested in the interactions between light and matter, particularly in the context of the photoelectric effect and its implications for metal behavior in vacuum conditions.
mihir23
For the photoelectric effect, when light hits a metal, and the frequency is above the work function, electrons are given off.
I am curious if the metal becomes more and more positive if this happens. i.e oxidation without reduction??.
For this question, assume that it is done in a empty vacuum and thus the meal can't take electrons from anything else
1) I am curious if the metal becomes more and more positive if this happens.
Right. But there is Coulomb force that slows and stops escaped electrons and they can't go to the infinite. But as frequency goes higher kinetic energy of escaped electrons is higher and positive charge accumulates more effective.
2) i.e oxidation without reduction??
I think no, coz there are no single atoms in metal as i.e. in any chemical solution. Atoms have collective electron cloud. Or it's possible to call oxidation of hole speciment not atom.
3) For this question, assume that it is done in a empty vacuum and thus the meal can't take electrons from anything else
4) If u have enough energy for electrons to break through Coulomb barier (and big volume of vacuumed space) than electrons move to infinite and u have positive charged piece of metal
1) In principle yes. The metal will loose electrons and the potential will increase until the work function+potential = photon energy and no more electrons are emitted.
Usually one does not want this to happen during such an experiments. Therefore the metal is connected to ground so that electrons are replenished and the potential is kept constant. It is possilbe to measure the current going from the metal to ground, and this is frequently done.
2) There is no oxidisation in the chemical sense. In a metal, it is not meaningful to assign an ionic charge to the atoms.
3) Correct.
