Lagrangian, particle/magnetic need solution check
  • Thread starter Thread starter AbigailM
    Lagrangian
The discussion revolves around deriving the Lagrangian for a charged particle moving in a uniform magnetic field, specifically \(\boldsymbol{B} = B\boldsymbol{\hat{z}}\). The proposed Lagrangian is \(L = \frac{1}{2}mv^{2} + q\boldsymbol{v.A}\), which is intended to yield the Lorentz force equation \(m\mathbf{a} = q\mathbf{v} \times \mathbf{B}\). Participants emphasize the necessity of providing a clear derivation and justification for the choice of the potential energy term \(U\) in the Lagrangian, as well as verifying that this formulation correctly reproduces the expected force law.
  • Understanding of Lagrangian mechanics
  • Familiarity with the Lorentz force law
  • Knowledge of vector calculus, particularly the curl operator
  • Proficiency in classical electromagnetism concepts
  • Study the derivation of the Lagrangian for charged particles in electromagnetic fields
  • Learn about the vector product rule in the context of Lagrangian mechanics
  • Explore the implications of gauge invariance in electromagnetic theory
  • Investigate the relationship between Lagrangian mechanics and Hamiltonian mechanics
This discussion is beneficial for physics students, particularly those studying classical mechanics and electromagnetism, as well as educators preparing for exams in these subjects.
AbigailM
Preparing for classical prelim, just wondering if this solution is correct.
A particle with mass m and charge q moves in a uniform magnetic field [itex]\boldsymbol{B}=B\boldsymbol{\hat{z}}[/itex]. Write a Lagrangian describing the motion of the particle in the xy plane that gives the correct Lorentz-force equation of motion,
[itex]m\mathbf{a}=q\mathbf{v}\times\mathbf{B}[/itex]
L=T - U
[itex]\frac{d}{dt}\left(\frac{\partial L}{\partial \dot{q}}\right)=\frac{\partial L}{\partial q}[/itex]
[itex]\boldsymbol{B}=\boldsymbol{\nabla \times A}[/itex]
[itex]\boldsymbol{E}=-\boldsymbol{\nabla}\phi +\frac{\partial \boldsymbol{A}}{\partial t}[/itex]
I'm going to start with the complete lorentz force and remove the electric potential from the lagrangian later.
[itex]\mathbf{F}=q(\mathbf{E}+\mathbf{v}\times\mathbf{B})[/itex]
[itex]\mathbf{F}=q(\mathbf{E}+\mathbf{v}\times (\boldsymbol{\nabla \times A}))[/itex]
[itex]\mathbf{F}=q(\mathbf{E}+\boldsymbol{\nabla} (\mathbf{v.A})-\boldsymbol{A}(\boldsymbol{\nabla . v}))[/itex]
[itex]\mathbf{F}=q(-\boldsymbol{\nabla}\phi+\frac{\partial\boldsymbol{A}}{\partial t}+\boldsymbol{\nabla}(\boldsymbol{v.A})-\boldsymbol{A}(\boldsymbol{\nabla v}))[/itex]
[itex]U=q(\phi -\boldsymbol{v.A})=q\phi-q\boldsymbol{v.A}[/itex]
We are only interested in the magnetic field so we'll ignore [itex]q\phi[/itex].
[itex]U=q\boldsymbol{v.A}[/itex]
[itex]L=\frac{1}{2}mv^{2} + q\boldsymbol{v.A} \hspace{2 mm}\mathbf{:Answer}[/itex]
As always thanks for the help!
This is correct, but you should explain how you got it (i.e that you used a specific vector product rule and that 2 of the terms were zero and why) on your exam if you want full marks.
Your choice of generalized potential is not immediately obvious when looking at this. How did you choose [itex]U[/itex] from this when there are 2 other terms present that depend on your generalized coordinates, momenta and time? There is a step missing in between which will make the choice of [itex]U[/itex] much easier to argue.
Did you actually show that this choice of Lagrangian gives the correct force law?
I only see an incomplete motivation for choosing such a Lagrangian, and no calculations to show that it is indeed a correct choice.
  • · Replies 0 ·
  • · Replies 21 ·
