Exploiting a the inverse to determine eigen vectors?
This discussion focuses on the potential of using a matrix A and its inverse A^{-1} to efficiently calculate the eigenvalues and eigenvectors of A, particularly in the context of RCW(FMM) analysis of light on crossed gratings. The author identifies unique symmetries in a block matrix that complicate traditional eigenvalue calculations, noting that QR routines are ineffective while LU routines may offer a solution. The author proposes developing a method to leverage these symmetries for calculating the inverse, thereby facilitating the extraction of eigenvalues and eigenvectors.
  • Understanding of eigenvalues and eigenvectors in linear algebra
  • Familiarity with block matrix structures and their properties
  • Knowledge of LU decomposition and QR factorization techniques
  • Basic principles of matrix inversion
  • Research methods for exploiting block matrix symmetries in eigenvalue problems
  • Learn about LU decomposition techniques specific to block matrices
  • Investigate advanced matrix inversion algorithms that utilize symmetries
  • Explore the application of eigenvalue problems in RCW(FMM) analysis
Researchers in applied mathematics, physicists working with light analysis, and mathematicians focusing on linear algebra and matrix theory will benefit from this discussion.
Jonnyb302
Hello, this is related to my research on RCW(FMM) analysis of light shone onto crossed gratings.
main question: can you exploit having matrix A and its inverse A^{-1} to calculate the eigen vectors/values of A in a more effective way?
backgroud:
so my problem is this: I have an unusual matrix with some strange symmetries and I need its eigen vectors. Only when I rewrite it in block form, do these symmetries become apparent. I would post it here but I am not at home so I do not have my saved LaTeX document with useful macros. But the symmetries have no real name, and most people will not be familiar with them.
I have searched quite a bit on the internet and can not find a way to exploit these block matrix symmetries. QR routines do not seem to go well with block matrices. While LU routines might.
However, I think I could devise a scheme to more efficiently calculate the inverse given these symmetries. Hence I am hopping to calculate the inverse, then exploit it to calculate the eigen values and vectors.
The question for the eigenvalues of ##A## or of ##A^{-1}## is essentially the same, so you will not have additional useful information.
