L ' Hopital's Rule for x -> infinity
  • Thread starter Thread starter unscientific
    Infinity
The discussion revolves around the application of L'Hôpital's Rule as x approaches infinity, comparing it to its application as x approaches zero. Participants are examining the conditions under which the rule applies and the implications of using Taylor expansions in this context.
  • Conceptual clarification, Assumption checking, Mathematical reasoning
  • Participants explore the validity of applying L'Hôpital's Rule for limits approaching infinity, questioning the assumptions made in the original post. There is a focus on the derivatives of functions and the implications of using Taylor expansions when both functions approach infinity.
The discussion is ongoing, with participants providing insights and questioning each other's reasoning. Some have suggested alternative approaches to the problem, while others are clarifying the conditions necessary for applying L'Hôpital's Rule correctly.
There is confusion regarding the application of Taylor expansions for functions that are undefined at certain points, as well as the need for careful consideration of limits when both functions approach infinity.
unscientific
Hopital's Rule for x -> ∞ applies the same way as x -> 0.
As shown in attached pic.
I tried to prove that x->∞ works the same way as x -> 0, only to get its reciprocal.. Not sure what is wrong with my working..
Why should h or k have a derivative at a? You'll have to come up with different reasoning.
You ask about L'Hopital's rule applying "as x-> infinity" but your attachment has x->a while it is f(x) and g(x) that go to infinity. Which are you trying to prove?
No only that, you applied Taylor expansions of f(x) and g(x) at x = a, where both functions are infinite! You can't do that.
RGV
Sorry for the confusion! I mean f(a) = g(a) = ∞
I earlier showed that l'Hopital's Rule works when its 0/0 but I am now trying to show it works for ∞/∞.
So i took (1/g)/(1/f) to make it 0/0..
But when i use taylor's expansion something's wrong..
What is Taylor's expansion for 1/(f(x)) , expanded about x = a ?
This poses a problem since 1/f(a) is undefined.​
Construct two functions, F(x) & G(x) such that F(a) = 0 = G(a), otherwise F(x) = 1/f(x) and G(x) = 1/g(x) .
Yes i did that, i let 1/g = h, 1/f = k.
then it reduces to [ h'(x)/k'(x) ] which translates to [g'(x)/f'(x)], which is the reciprocal instead..
Check that again.
So, [itex]\displaystyle h(x)=\frac{1}{g(x)}\quad\to\quad h'(x)=-\frac{g'(x)}{(g(x))^2}\ .[/itex]
A similar result holds for k'(x) .
[itex]\displaystyle \lim_{x\to a}\frac{f(x)}{g(x)}=\lim_{x\to a}\frac{h(x)}{k(x)}[/itex]
[itex]\displaystyle =\lim_{x\to a}\frac{h'(x)}{k'(x)}[/itex]
[itex]\displaystyle =\lim_{x\to a}\frac{g'(x)}{(g(x))^2}\frac{(f(x))^2}{f'(x)}[/itex]
[itex]\displaystyle =\lim_{x\to a}\frac{g'(x)}{f'(x)}\ \lim_{x\to a}\frac{(f(x))^2}{(g(x))^2}[/itex]​
Can you take it from there?
SammyS said:
Check that again.
Yes I ended up with that step. So f(a) = g(a), f/g = 1.
Then we have g'(x)/f'(x), which is the reciprocal, where I am stuck at...
What is that reciprocal equal to ?
By right I should get f'(x)/g'(x) as when approximating x→0.
But I'm getting g'(x)/f'(x) instead..
SammyS said:
[itex]\displaystyle \lim_{x\to a}\frac{f(x)}{g(x)}=\dots[/itex]
Suppose both limits [itex]\displaystyle \lim_{x\to a}f'(x) \,,\ \lim_{x\to a}g'(x)[/itex] exist & that [itex]\displaystyle \lim_{x\to a}f'(x)\ne0\ .[/itex]
Then the following should give the desired result.
[itex]\displaystyle \lim_{x\to a}\frac{f(x)}{g(x)}=<br /> \frac{\lim_{x\to a}g'(x)}{\lim_{x\to a}f'(x)}\cdot \lim_{x\to a}\frac{f(x)}{g(x)}\cdot \lim_{x\to a}\frac{f(x)}{g(x)}[/itex]​
I see! then the f(x)/g(x) cancels on both sides leaving only one f(x)/g(x) on the right, then you bring over the g'(x)/f'(x) to the left to give f'(x)/g'(x) as desired!
