Is the Calculation of Height in a Pulley System Accurate?
  • Thread starter Thread starter jiayingsim123
    Tension
The problem involves a pulley system where an object of mass 3m is connected to a scale pan of mass m via a string. An additional mass m falls onto the scale pan from a height h, and the goal is to determine the height to which the mass 3m rises after the mass m lands on the scale pan.
  • The original poster attempts to calculate the speed of the scale pan and the subsequent motion of the mass 3m, raising questions about the accuracy of their calculations and assumptions regarding the masses involved.
  • Some participants question the interpretation of the masses in motion, particularly whether the mass m and the scale pan should be considered as a combined mass during the collision.
  • Others suggest reconsidering the momentum equations used, particularly the treatment of the stationary mass during the collision.
The discussion is ongoing, with participants providing clarifications on the interpretation of the problem and the dynamics involved. There is a focus on ensuring that the assumptions about the masses and their motions are correctly understood, but no consensus has been reached regarding the calculations or the final outcome.
Participants note the absence of a diagram, which may contribute to confusion about the setup of the problem. There is also a mention of differing interpretations of the masses involved in the collision, which affects the calculations presented.
jiayingsim123
An object of mass 3m is connected by means of a light, inextensible string to a scale pan of mass m. The object rests on the ground. The string passes over a smooth pulley and the scale pan hangs suspended. An object of mass m, falling from rest a distance h above the scale pan, lands on it and does not bounce. Show that the mass of 3m will rise to a height h/5.
Sorry but there's no diagram given! The answer I got was 4h/5 instead! :(
To find the speed of the scale pan before the string becomes taut:
mgh=0.5u^2
u=√(2gh)
To find the speed of the scale pan/speed at which the 3m object jerks in motion:
Take upwards direction as negative:
-I = 2mv-2m√(2gh) (this is the change in momentum of the scale pan)
-I = -3mv
Equate both to get:
-3mv=2mv-2m√(2gh)
-5mv=-2m√(2gh)
v=2√(2gh)/5
This speed, v is the initial speed of the upward motion of the 3m mass.
u=2√(2gh)/5
v=0 (mass of 3m rise to a height of h/5 and stop)
To find acceleration, a:
For the 3m mass (it's going upwards):
T-3mg=3ma
For the scale pan+object of mass m (going downwards):
2mg-T=2ma
Equate both equations:
T=3ma+3mg
T=2mg-2ma
3ma+3mg=2mg-2ma
5ma=-mg
5a=-g
a=-g/5
Using an equation of linear motion:
v^2=u^2+2as
0=(2√(2gh)/5)^2 + 2(-g/5)s
s=4h/5
Did I do something wrong in the middle? Was I on the right track in the first place? Thanks! :D :smile:
hi jiayingsim123! :smile:
(try using the X2 button just above the Reply box :wink:)
no, the 2m√(2gh) is wrong …
only the mass m was moving, the pan was stationary! :redface:
(btw, i find this sort of problem easier if i pretend everything is in a straight line …
in this case, a mass m collides with a stationary mass 4m :wink:)​
Hi tiny-tim, thanks for helping out again!
But I thought the mass m drops onto the scale pan, meaning both of it will move downwards as a single entity and therefore the total mass is 2m? So isn't it a mass of 2m colliding with a stationary mass of 3m?
jiayingsim123 said:
… isn't it a mass of 2m colliding with a stationary mass of 3m?
no!
there's 4m of stationary mass, isn't there?? :smile:
(you're being confused by the fact that the 4m is in two parts)
only a mass of m was originally moving, and 4m wasn't :wink:
Okay thanks for clearing that up, tiny-tim! You're really awesome! :)
  • · Replies 23 ·
9K
  • · Replies 31 ·
  • · Replies 35 ·
