Torques: Find Load on Piers Supporting 700N Girder
  • Context: Undergrad
  • Thread starter Thread starter Aidan123
    Torques
The discussion focuses on calculating the load on two piers supporting a uniform girder weighing 700N and measuring 3.0m in length. The girder is supported at points 30cm and 60cm from its ends. By applying the principles of static equilibrium and torque, the load on each pier can be determined. The calculations reveal that the load distribution is influenced by the distances from the supports to the center of gravity of the girder.
  • Understanding of static equilibrium principles
  • Knowledge of torque calculations
  • Familiarity with load distribution concepts
  • Basic physics of forces and moments
  • Study the principles of static equilibrium in physics
  • Learn how to calculate torque and its applications
  • Explore load distribution methods in structural engineering
  • Review examples of similar problems involving beams and supports
Students in physics or engineering courses, structural engineers, and anyone interested in understanding load calculations on beams and supports.
Aidan123
A uniform girder weighing 700N is 3.0m long. It is placed horizontally on top of two narrow piers which is support it at points 30cm and 60cm respectively from its ends. Find the load carried by each pier.
Please post homework questions, and homework style questions in the appropriate homework subforum. Be sure to show your work and explain exactly where you are getting stuck.
Nice description.
So how are you attempting this problem?
  • · Replies 22 ·
  • · Replies 24 ·
