Could an ~12ft rocket launch some sort of probe into space
The discussion revolves around the feasibility of using a 12-foot model rocket to launch a probe, such as a telescope, into space. Participants explore various aspects including the necessary power, height, and methods of launching, as well as the physics involved in reaching orbit.
  • Some participants argue that a 12-foot rocket would not have enough power to reach space, suggesting that larger rockets are typically required for such missions.
  • Others mention that while a 21-foot amateur rocket has reached space, launching into orbit requires significantly more power.
  • One participant proposes launching the rocket from a balloon to gain altitude, which could potentially reduce the amount of power needed for the rocket itself.
  • Concerns are raised about the stability of the rocket at high altitudes due to wind conditions.
  • Discussions include the concept of escape velocity, with some participants providing different figures and clarifying that approximately 8 km/s is needed for low Earth orbit.
  • Participants discuss the limitations of rocket design, including the dry mass to fuel ratio and the challenges of achieving sufficient velocity to maintain orbit.
  • There are references to the costs associated with launches, particularly emphasizing the challenges of the initial phase of a launch.
Participants do not reach a consensus on the feasibility of launching a probe with a 12-foot rocket. Multiple competing views are presented regarding the necessary size and power of rockets, the effectiveness of launching from altitude, and the physics of reaching orbit.
Limitations include assumptions about the rocket's design, the definitions of terms like "space," and the unresolved calculations regarding fuel requirements and stability at different altitudes.
Turtle^2
could a large 12ft model rocket be used to launch a probe into space, such as a telescope?
Astronomy news on Phys.org
Welcome to PF, Turtle.
Does "12'" refer to length or diameter?
No.
People have tried. There are amateur rocket builders who are working on it. First you need a lot of power to get into space - so you'd need a bigger rocket, the bigger the rocket the more power you need, and the bigger the rocket the harder it is to control it. So, pretty big rockets are usually required to put even relatively small things in space.
They need to be big...
About this big http://www.orbitcast.com/archives/satellite-launch.jpg
Probably not, you need something slightly bigger.
A 21 foot tall amateur rocket using just solid propellant reached past the official boundary of space, up to 116km though! So 12 feet isn't THAT far off.
Source: http://en.wikipedia.org/wiki/Civilian_Space_eXploration_Team
Note however that if you want to launch something into ORBIT, or on an escape trajectory, the amount of power necessary increases manifold.
What happens if you launch it from a ballon? Amateurs get ballons up to 30km+.
Probably 4 ballons with the rocket between them, and use a RC/unit with an arduino or raspberry pi to control levelling and launching.
You simply get yourself 30 km up in the air and don't need to make it up using the rocket. It makes it easier to get into space, but not to get into orbit. Getting into an orbit requires accelerating from near zero to about 8 km/s for a low Earth orbit.
I wonder how much extra height you would get? I guess most of the fuel is used closer to the ground so I imagine it would add more than +30km.
Probably not. As was mentioned earlier amateur rocket enthusiasts compete annually with larger rockets and do not reach orbit. Actually, if you have MATLAB I have a program which does a first iteration calculation of altitude achieved based on some rocket parameters. I could find it but I doubt it's accurate enough to be useful.
"Not to orbit" is fine but the question was "how much difference it makes, launching from 30km up" :-)
I am pretty sure that because of thinner air, you will less fuel 30-60km than you use 0-30km
I'm trying to find some data on it. No, I don't expect the answer to be "orbit".
I am worried about stability though. High winds up there. Lower winds at ground level and easier to stabilise yourself once in motion.
8 km/s where are you getting that figure?...That's 23 times the speed of sound. The max speed of the space shuttle was 1.3 km/s
Hi krd,
Look here:
http://en.wikipedia.org/wiki/Orbit_velocity
The high velocity is required because that is the velocity needed to be in uniform circular motion around the earth, with gravity
being the centripetal force.
edit/add: http://www.space.com/12127-8-surprising-space-shuttle-facts.html
Here's another something similar:
http://en.wikipedia.org/wiki/Escape_velocity
It's the velocity required for a body to escape the pull of gravity.
(example: you shoot a cannon ball straight up, but it normally falls back down. If you shoot it fast enough (escape velocity or above), then it'll never fall back down
If you were to use all your kinetic energy at the surface of the Earth in 1 instant (time approaches 0 or power approaches infinity), you would need about 8 km/s as an initial velocity. This is the definition of "escape velocity".
Escape elocity for the Earth is a little more than 11 km/s.
As drakith stated 8 km/s is needed for a low Earth orbit.
As you want to launch a telescope, I assume that it should (at least) reach a low Earth orbit, otherwise it re-enters quickly and the mission lasts just some minutes. With conventional rockets, there is a physical limit on the dry mass to fuel ratio, given by the rocket equation.
[tex]m_{total} = m_{dry\,mass} \exp\left(\frac{8km/s}{v_{exhaust}}\right)[/tex]
The best chemical propellants reach an exhaust velocity of about 4km/s, therefore the exponential is about e2 or ~7. However, this does not account for atmospheric drag and the required time of the acceleration - both increase the number of 8km/s, which increases the required ratio exponentially. In addition, it does not take into account that the payload is just a small fraction of the dry mass. Staging can improve this ratio a bit, but it cannot avoid the physical limits of the whole design.
Compare it with real rockets:
The space shuttle could launch about 25 tons into low Earth orbit, but required a total mass of 1500 tons -> ratio 1/60. However, that reusable shuttle was not really ideal in terms of "payload to orbit"
The Saturn V was bigger, and with a better ratio: 120 tons payload, 2800 tons total mass -> ratio 1/23
Soyuz-U: 7 tons payload, 313 tons total mass -> ratio 1/45
As you need some systems regardless of size, smaller rockets tend to have a worse ratio. Let's look at commercial rockets:
Falcon 1 (21m height, 1.7m diameter) can launch 0.7 tons with a total mass of 39 tons (1/56), the bigger Falcon 9 with 10,5 tons / 333 tons (1/32) is better. Falcon heavy: 53 tons / 1400 tons (1/26)
I've heard it stated that the most expensive part of a launch is the first 2 inches!
I would love to have a link to learn more about that!
That was just a qoute I heard during an interview ten or twenty years ago. If you're looking for more info, dare I say Google It!
In terms of required fuel... well, yes, the "fuel per distance" ratio decreases with velocity, and the initial velocity is 0 for conventional rocket launches (=all rocket launches up to now). But this does not mean that lifting the rocket by 2 inches would help in any way. Accelerating it to something like 500m/s or more would indeed help.
I think what that means is getting it 2 inches off the ground without it malfunctioning and exploding is the most expensive part of the launch.
Couldn't get anything by googling the first time around. It also seems logical that the cost of fuel and safety would be very high for the initial part of the launch. What I wanted was data resembling breakup of amount of fuel required as the rocket gets higher or something like that.
  • · Replies 21 ·
  • · Replies 28 ·
  • · Replies 18 ·
  • · Replies 23 ·
  • · Replies 66 ·
