Could Gravity Transport Energy?
TheEtherWind
I've heard that gravitational fields carry energy themselves, and are therefore a source for their own existence. I take this as a "pre-requisite" of a sort for gravitational waves. If I were to shoot a high energy laser in space and cause a rippling effect of space-time. Could somebody, somewhere else, convert gravitational waves back into energy?
In a word, yes.
If I remember correctly, gravitational waves have yet to be confirmed to exist by experiment?
They haven't been detected directly, but analysis of the decay rate of the binary pulsar PSR B1913+16 indicates that it is losing energy at a rate that can be explained by gravitational wave emission. This work was worth the 1993 Nobel prize in physics.
In this video I can see a person walking around lines of curvature on a sphere with an arrow strapped to his waist. His task is to keep the arrow pointed in the same direction How does he do this ? Does he use a reference point like the stars? (that only move very slowly) If that is how he keeps the arrow pointing in the same direction, is that equivalent to saying that he orients the arrow wrt the 3d space that the sphere is embedded in? So ,although one refers to intrinsic curvature...
ASSUMPTIONS 1. Two identical clocks A and B in the same inertial frame are stationary relative to each other a fixed distance L apart. Time passes at the same rate for both. 2. Both clocks are able to send/receive light signals and to write/read the send/receive times into signals. 3. The speed of light is anisotropic. METHOD 1. At time t[A1] and time t[B1], clock A sends a light signal to clock B. The clock B time is unknown to A. 2. Clock B receives the signal from A at time t[B2] and...
So, to calculate a proper time of a worldline in SR using an inertial frame is quite easy. But I struggled a bit using a "rotating frame metric" and now I'm not sure whether I'll do it right. Couls someone point me in the right direction? "What have you tried?" Well, trying to help truly absolute layppl with some variation of a "Circular Twin Paradox" not using an inertial frame of reference for whatevere reason. I thought it would be a bit of a challenge so I made a derivation or...
