Japan Earthquake: Nuclear Plants at Fukushima Daiichi
The discussion revolves around the technical aspects and current status of the nuclear plants at Fukushima Daiichi following the earthquake and tsunami in Japan. Participants are seeking reliable information regarding the operational conditions, safety measures, and potential risks associated with the nuclear reactors in the aftermath of the disaster.
  • Some participants express skepticism about the reliability of media reports and emphasize the need for technical information from official sources like TEPCO and METI.
  • There are concerns regarding the reactor pressure levels, with reports suggesting that pressure may have exceeded safe limits, which some participants describe as a significant issue.
  • Questions are raised about the likelihood of a meltdown, with differing opinions on whether this is a realistic concern or media exaggeration.
  • One participant explains the role of coolant in a nuclear power plant, noting that it is essential for cooling the reactor and managing decay heat after shutdown.
  • There is discussion about the reactor's ability to be scrammed (shut down) and the implications of losing coolant, with some participants clarifying that decay heat continues to be produced even after shutdown.
  • Concerns are raised about the explosion of the containment building and its implications for safety, with speculation about the potential release of radioactive materials.
  • Participants discuss the wind direction at the time of the explosion and its potential impact on the dispersion of any radioactive materials released.
Participants do not reach a consensus on the likelihood of a meltdown or the implications of the current situation at Fukushima Daiichi. There are multiple competing views regarding the severity of the situation and the reliability of information being reported.
Participants note the limitations of available information, including the reliance on second-hand reports and the challenges in verifying the status of the reactors and containment structures. There are also unresolved questions regarding the operational status of safety systems and the exact nature of the explosion.
  • #13,561
etudiant said:
So why hurry, if all of the work has to be done by humans? Better to play for time and push the teleoperator technology forward as fast as possible. That way Japan might also hopefully still get something useful out of this disaster.
*sigh* for what it is worth, I will repeat what I have said here and in other fora. The site remediation work will, must be slow. This, however, should not be seen as an excuse to not instrument the site and not do forensics.
As for pushing teleoperator tech: don't be ridiculous, what is being done now is so far behind the curve, it would be funny if it weren't sad.
Humans are constantly being sent into high radiation fields to manipulate door-handles and other such things; contact with tele-operated machines (no they are not robots) is being lost, as if wi-fi repeaters, Faraday cages and lead shielding had not been invented yet.
In other words, the survey/forensics work is underfunded to an incredible degree.
  • #13,562
Sadly, your comments are indisputable.
The site management has not changed since the accident, even though the emergency is past. There has not been any recognition that TEPCO is a power utility, not a nuclear cleanup expert.
The site needs a separate management, divorced from TEPCO, tasked solely with performing this cleanup. Leaving TEPCO as a paymaster avoids the problem of setting up a very visible, very costly remediation authority and ensures the site management remains eager to minimize the outlays required. The cheeseparing evident all through the past year makes sense for the TEPCO controllers, but is surely penny wise, pound foolish from a national policy perspective.
  • #13,563
Well, that's THE problem. In fact, TEPCO cheapness is what CAUSED the accident, from
the siting to the resistance to fortifying the plant against obvious hazards. But, TEPCO
is so big, they SET national policy, not the other way around. And, this has been the
clear situation for decades, where they have had a number of serious accidents.
Jon
  • #13,564
yeah...everybody is prepared for a 40+ foot wave and a 9.1 earthquake.
I'm pretty sure this is the scientific discussion thread.
The apportioning of blame thread is elsewhere.
  • #13,565
Well, if the fixing process is starved for funds, that is a factual operational issue imho, not an apportioning of blame.
Also, the certification process is usually somewhat respectful of local conditions.
Japan has excellent data on earthquakes and tsunamis going back over 1000 years.
Disregarding that record seems a mistake, in retrospect.Whom to blame is another topic.
  • #13,566
The 9.1 magnitude earthquake was certainly at the upper end of what Japan experiences,
but they HAVE had earthquakes of this magnitude before. The 15 m tsunami run-up
is guaranteed in Japan, you just have to wait long enough for one of those to hit your
particular region.
Their earthquake resistance pretty much handled the event (we think, but there MAY have been some serious damage that has either been covered up or not discovered yet due to
difficulty inspecting parts of the plant.) One area where there seems to be a LOT of damage is in the water-tightness of the plant basements, where they seem to have massive water
leaks, now.
But, since the tsunami threat was completely known and they knew their defenses were very inadequate, this seems to be a serious shortcoming of NISA (is that the right agency?) to make TEPCO harden the plant against the tsunami risk. So, that's why I made the comment about
TEPCO setting policy.
Jon
  • #13,567
really? when was that?
Actually, what is important is the ground motion at the plant site, not the magnitude of the 'quake (which is an attribute at the location of the earthquake itself). IIRC, the motion at Fukushima Dai-ichi did exceed the design basis (well, what they call the 'back-check' motion, which is like the latest design basis), but not by too much.
But, since the tsunami threat was completely known and they knew their defenses were very inadequate, this seems to be a serious shortcoming of NISA (is that the right agency?) to make TEPCO harden the plant against the tsunami risk...
I don't know about 'completely known' but I think most agree that the design basis tsunami was far too low. That (in my view) is a failure by the regulator and the licensee. They both had to close their eyes and say "I don't believe it will happen."
  • #13,568
I can't say I've been terribly disappointed with the real data so far, simply because I never expected it to be easy to obtain lots of high quality data and facts even if the operations were being carried out by the best resourced, most competent and open organisation imaginable. I want to know more, but some of the limitations are down to limitations of technology & science, not just lack of will or resources.
It strikes me as rather normal to be relying on model analysis for a range of things, and I was not expecting to learn much more about the cores of the reactors or much inside containment at this point.
Rather my main complaints are to do with the story told early on, lack of good data for people living there to act rationally upon, etc. There are things I wish had been presented to us in a far more cohesive manner, but plenty of it would still be model-based or speculative at this point. I actually want more speculation on various possible forms of containment breach, corium pathways etc, but I don't expect hard facts to emerge on this front any quicker than they have so far. But for example when they lowered that probe into the torus room and its water, and got some rather high readings, I would like either the company, government agencies, journalists or whoever to talk about what possibilities the resulting data, however limited, points to.
Perhaps my biggest complaint about data/facts since the first weeks of the disaster has been photographic etc evidence with decent analysis of various potential containment failure points. To say that they didnt go out of their way to draw attention to or explain even the stuff they have published about this sort of thing would be an understatement.
Meanwhile for those taking a more visual approach to observing the aftermath of the disaster, it seems that in a few hours the webcam will be moving to a new position that should afford us a better look at the work going on at reactor 4 (now that there is no interesting demolition stuff going on) & hopefully a vaguely reasonable view of 3 as well.
  • #13,569
Using the data from 1895 (edit), the nuclear power plants were carefully placed outside or at the edges of the new madrid area where the most damage occurred....for a 6 on the richter scale.
I'm pretty sure more than a few would be in danger if a 9.0 hit in new madrid.
My point is that I doubt anybody can successfully guarantee against damage from a 9.0 earthquake.
  • #13,570
HowlerMonkey said:
Using the data from 1985, the nuclear power plants were carefully placed outside or at the edges of the new madrid area where the most damage occurred....for a 6 on the richter scale.
I'm inclined to always ask, what's the appropriate risk model (cost/benefit) in the case of 9.0 earthquake in an area with a nuclear power plant? That is, dedicate some amount of funds, whatever you like ($300B?) to prevention of damage to life and property in the case of that 9.0. What should be the priorities? Based on what I hazard to guess would save the most lives, near the top of my list would be reinforcement of existing structures (residential/office/municipal), gas lines, dams and the like, then perhaps training for emergency services. Or build sea walls at sites near the sea. Maybe down around 10th on the list I might start allocating money to improvements at the local nuclear plant.
  • #13,571
Reinforced structures, gas lines and all this don't really matter in an exclusion zone, I guess.
And, how much is the genetic degenerative damage to be valued? Is genetic health of later generations a "priority" at all?
If you could ask your descendants seven generations later, they might strongly disagree with today's "priorities".
tsutsuji said:
That's right. It was a mistranslation.
計装配管の健全性を確認 should have been translated as "checking instrumentation pipe soundess" or "we shall check instrumentation pipe soundness".
There is a second handout on the same topic dated July 13: www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120713_04-e.pdf
Hmm, could the pipe simply have molten and welded shut?
  • #13,572
If you could ask your descendants seven generations later, they might strongly disagree with today's "priorities"...
The 15,867 deaths from the Fukushima quake and tsunami are documented. The collapsed structures, fires, and flooding that killed them matter. They'll have no further descendants. The future genetic damage you refer to, though perhaps serious, is speculative.
  • #13,573
By the speed genetic engineering is moving, in a hundred years or so we will be able to "dial a genome" of our children.
  • #13,574
tsutsuji said:
Fukushima Daiichi accident workshop, July 23-24 2012
http://www.nisa.meti.go.jp/shingikai/700/14/240723/program.pdf program
http://www.nisa.meti.go.jp/shingikai/700/14/240723/240723.html presentations, July 23
http://www.nisa.meti.go.jp/shingikai/700/14/240724/240724.html presentations, July 24
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120723_05-e.pdf Tepco presentations, July 23
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120724_02-e.pdf Tepco presentations, July 24
Here is the program with English titles when provided or translations of Japanese titles:
Workshop on Tokyo Electric Fukushima Daiichi nuclear power plant accident - distributed documents
Index
http://www.nisa.meti.go.jp/shingikai/700/14/240723/program.pdf Program (Japanese)
July 23 (meeting hall A)
AM-1 Session: accident events analysis (1)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/AM-1-1.pdf Tepco, Detailed analysis of the accident progression of Units 1 to 3 by using MAAP code (some Japanese, some English)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/AM-1-2.pdf JNES, Accident Sequence Analysis of Unit 1 to 3 Using MELCOR Code (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/AM-1-3.pdf JAEA, Analysis for Accident Progression with THALES2 Code (English)
AM-2 Session: accident events analysis (2)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/AM-2-1.pdf Toshiba, Hitachi-GE, Study for the leakage potential of PCV which have suffered by the condition of Fukushima accident (Japanese)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/AM-2-2%281%29.pdf JNES, Analysis of reactor water level and PCV pressure and temperature in the hypothesis of very small piping leaks: (1) Reactor water level analysis using RELAPS5 Code (Japanese)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/AM-2-2(2).pdf JNES, Analysis of reactor water level and PCV pressure and temperature in the hypothesis of very small piping leaks: (2) PCV pressure and temperature analysis using MELCOR Code (Japanese)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/AM-2-3.pdf JNES, Accident sequence analysis using event tree of level 1 PSA (some Japanese, some English)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/AM-2-4.pdf JNES, Analysis of concrete erosion depth caused by melted fuel (Japanese)
AM-3 Session: estimates of released quantities
http://www.nisa.meti.go.jp/shingikai/700/14/240723/AM-3-1.pdf JNES, Source Term Analysis Using MELCOR Code (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/AM-3-2.pdf Tepco, Estimation of radioactive release resulting from Fukushima Dai-ichi NPS accident (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/AM-3-3.pdf JAEA, Estimation of Time Trend of Atmospheric Releases on 131I and 137Cs (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/AM-3-4.pdf CRIEPI, Direct release rate of radionuclides to the ocean from the Fukushima Daiichi Nuclear Power Plant estimated numerically by a regional ocean model (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/AM-3-5.pdf JAMSTEC, Estimation of the total amount of 137Cs direct release associated with the Fukushima accident (English)July 23 (meeting hall B)
BM-1 Session: Offsite status
http://www.nisa.meti.go.jp/shingikai/700/14/240723/BM-1-1.pdf Cabinet Office, Designating and Rearranging the Areas of Evacuation (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/BM-1-2.pdf Ministry of Environment, Overview of offsite cleanup activities (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/BM-1-3.pdf JAEA, Overview of the Results of the Decontamination Model Projects (English)
BM-2 Session: Present plant status and present countermeasure implementation status
http://www.nisa.meti.go.jp/shingikai/700/14/240723/BM-2-1.pdf Tepco, The overall status of Fukushima Daiichi NPS (Japanese)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/BM-2-2.pdf Tepco, The mid to long term roadmap toward decommissioning and research and development plan (Japanese)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/BM-2-3.pdf Tepco, Condition inside PCV assumed based on the atmosphere gas measurement results (hydrogen, xenon and krypton behaviors) (Japanese)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/BM-2-4.pdf JNES, Evaluation of xenon concentration in unit 2 PCV atmosphere (Japanese)
http://www.nisa.meti.go.jp/shingikai/700/14/240723/BM-2-5.pdf Tepco, Progress status of the fuel removal from Unit 1-4 spent fuel pools (Japanese)
July 24 (meeting hall A)
AT-4 Session: Earthquake, tsunami
http://www.nisa.meti.go.jp/shingikai/700/14/240724/AT-4-1.pdf Tepco, Earthquake Ground Motion Observed at the NPS and the Ground Motion Simulation (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240724/AT-4-2.pdf Tepco, Tsunami Survey Results in the NPS and Reproduction Analysis Using Tsunami Inversion (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240724/AT-4-3.pdf JNES, The JNES model on the construction of a design basis tsunami based on probabilistic tsunami evaluation (Japanese)
http://www.nisa.meti.go.jp/shingikai/700/14/240724/AT-4-4.pdf Tepco, Fukushima Daiichi NPS after the Tohoku-Chihou-Taiheiyou-Oki Earthquake: Impact of ground motion on Fukushima Daiichi NPS Units 1-3 (Japanese)
AT-5 Session: Liquid phase leaks from PCV
http://www.nisa.meti.go.jp/shingikai/700/14/240724/AT-5-1.pdf Tepco, Investigation result of the inside of PCV and the investigation plan to identify the leakage path of radioactive materials (Japanese)
http://www.nisa.meti.go.jp/shingikai/700/14/240724/AT-5-2.pdf Tepco, Various Approaches for Understanding State of Plants (Japanese)
http://www.nisa.meti.go.jp/shingikai/700/14/240724/AT-5-3.pdf JNES, Inference of PCV cooling status based on data after nitrogen injection (Japanese)AT-6 Session: Lessons learned from the accident
http://www.nisa.meti.go.jp/shingikai/700/14/240724/AT-6-1.pdf Cabinet secretariat, Reform of Nuclear Regulation Organisation and System in Japan (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240724/AT-6-2.pdf NISA, Discussion on basic direction of safety regulation on severe accidents (English)
July 24 (meeting hall B)
BT-3 Session: Unit 4 spent fuel pool
http://www.nisa.meti.go.jp/shingikai/700/14/240724/BT-3-1.pdf Tepco, Investigation of the cause of hydrogen explosion at the Unit 4 Reactor Building (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240724/BT-3-2.pdf JNES, Study on the Issues about Hydrogen Explosion at Fukushima Dai-ichi NPS (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240724/BT-3-3.pdf Tepco, Regarding the integrity of the spent fuel pool at unit4 (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240724/BT-3-4.pdf JNES, Analysis of Fuel Heat-up in a Spent Fuel Pool during a LOCA (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240724/BT-3-5.pdf Kajima corporation, Seismic safty evaluation of the Spent Fuel Pool at the unit4 (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240724/BT-3-6.pdf JNES, Seismic Safety Evaluation of the Spent Fuel Pool at the Unit 4 (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240724/BT-3-7.pdf US NRC, Fukushima Lessons Learned : Spent Fuel Pools (English)
http://www.nisa.meti.go.jp/shingikai/700/14/240724/BT-3-8.pdf IAEA, Safety of the Spent Fuel Pool (English)
  • #13,575
http://www.nisa.meti.go.jp/english/files/program_en.pdf 23/24 July workshop program in English
http://www.nisa.meti.go.jp/english/files/1FWS_handout.html 23/24 July workshop document links with English titles
  • #13,576
The 8th mid & long term meeting was held on 30 July 2012: http://www.meti.go.jp/earthquake/nuclear/20120730_01.html
1) Previous related topics:
The 7th meeting (25 June 2012) https://www.physicsforums.com/showpost.php?p=3979794&postcount=13512
The 6th meeting (25 May 2012) : https://www.physicsforums.com/showpost.php?p=3933442&postcount=13399
The 5th meeting (23 April 2012) : https://www.physicsforums.com/showpost.php?p=3881074&postcount=12979
The 4th meeting (28 March 2012) : https://www.physicsforums.com/showpost.php?p=3838108&postcount=12764
The 3rd meeting (27 February 2012) was translated into English on Tepco's website : http://www.tepco.co.jp/en/nu/fukushima-np/roadmap/conference-e.html
2) Translation:
30 July 2012 government-Tokyo Electric mid and long term response committee, steering committee (8th meeting)
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01a.pdf Agenda
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01b.pdf Participants
Document 1
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01c.pdf Abstract of the proceedings of 7th steering committee meeting
Document 2: Plant status
Document 2-1: Plant status
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01d.pdf Plant parameters
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01e.pdf Accumulated water storage status
Document 3 Study and execution of each special plan
3-1 Cooling by closed loop water injection
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01f.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01g.pdf Unit 2 alternative thermometer installation progress status
3-2 Treatment of accumulated water
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01h.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01j.pdf Improvement of closed loop line reliability
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01k.pdf Multinuclide removal facility (ALPS) qualification test and facility design status
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01m.pdf Subdrain purification test status report
3-3 Countermeasures to reduce environmental radiations
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01n.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01p.pdf Future schedule as regards harbour related works etc.
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01q.pdf Consequences on water quality of the covering of the sea floor in the harbour
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01r.pdf Future operation policy of the seawater circulation purification device
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01s.pdf Results of evaluation of additional releases from reactor buildings
3-4 Improvement of working conditions
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01t.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01u.pdf Results of questionnaire survey in relation with improvement of working conditions at Fukushima Daiichi nuclear power plant and future course of action
3-5 Countermeasures for spent fuels pools
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01v.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01w.pdf Debris removal work, reactor building top part, unit 3
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01x.pdf Debris removal work, reactor building top part, unit 4
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01y.pdf Unit 1 operating floor status survey
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01z.pdf Unit 4 spent fuel pool fresh fuel (unirradiated fuel) integrity survey
3-6 Preparations for fuel debris removal
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01aa.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01bb.pdf Survey into unit 3 torus room, reactor building underground floor
3-7 Treatment and disposal of radioactive waste
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01cc.pdf Schedule
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01dd.pdf Debris, cut down trees management status
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01ee.pdf Collection of samples to analyse debris and cut down trees
Document 4
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01ff.pdf Fukushima Workshop on the development of machinery and equipments toward the decommissionning process, etc. of Tokyo Electric Fukushima Daiichi NPP (event guide) [7 August 2012, in Koriyama, Fukushima prefecture]
Document 5
http://www.meti.go.jp/earthquake/nuclear/pdf/120730/120730_01gg.pdf roadmap progress (abstract)
  • #13,577
When will the area around the Fukushima Daiichi Nuclear Power Plant be repopulated?
How much land is off limits in terms of Square Miles or Kilometers?
Are the radiation risks serious or negligible within this area if one lives there permanently?
Do the benefits of nuclear power offset the economic loss of this land possibly being rendered useless?
  • #13,578
Off-topic (sorry):
I logged in and read the following ad:
Hi Tepconium-311, have you thanked a PF Mentor today? They spend hours each day making sure PF is a great site! Spend two minutes and send a Mentor a PM or VM thanking them. Makes their day! :)
May I ask why tsutsuji has not yet been awarded Mentor status?
IMHO he deserves it. May I suggest him as a Mentor candidate?
(Thank you tsutsuji for your great contributions)
Edit:
I'd be curious, too, how much all that restricted land and property would have cost if bought at once at a real estate broker. (Before accident, of course)
  • #13,579
Has there been any analysis of the seawater contamination incident at the Chubu Electric Hamaoka #5 reactor?
According to this article posted Aug 4, 2012 at Atomic Power Review:
http://atomicpowerreview.blogspot.com/2012/08/hamaoka-no-5-seriously-contaminated.html
there was a pipe failure in the main condenser during shutdown, so that a lot of secondary cooling circuit sea water contaminated the reactor.
In the current environment, that unit is probably a writeoff, but there are surely some real lessons to be learned if a deliberate shutdown can cause such a damaging failure to occur.
  • #13,580
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120806/index.html Tepco has released part of the accident's teleconference videos. Journalists can go to Tepco's main office and watch there 150 hours of the videos taken for 5 days starting on 11 March 2011. They are not allowed to record the videos or the sound. An about one and a half hour edited abridged version prepared by tepco is available for the public to watch.
http://www3.nhk.or.jp/daily/english/20120806_30.html (same story, English version)
http://www.tepco.co.jp/tepconews/library/movie-01j.html The teleconference edited version is available on the last tab on the right, under "2012/8/6 本店会議録... (1:28:58)".
Thanks for your support. I was given the "PF contributor" status and I feel very honoured by that.
http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120803_02-e.pdf Investigation on the Misconnection of Thermometer Wiring at Fukushima Daiichi Nuclear Power Station :
[unit 1] 3. Dry well water level*: 1
Connected to the digital recorder with the wiring on the work site side switched off
→Connection was redone properly
* Set value: O.P. +27,150mm (Approx. 20m from the bottom of PCV)
What are we supposed to do with this "set value"? Isn't the water level more likely to be very low, a few cm above the bottom like at unit 2?
  • #13,581
I didnt really understand that one myself when I read about it, especially since it also says they've set the reactor 2 one to an even higher level. For all intents and purposes I believe such instrumentation is useless right now anyway, will just have to wait for actual surveys of DW conditions at the other reactors.
  • #13,582
There is more about the alternative thermometer insertion plan and related assumptions in the following document.
  • #13,583
1 March 2012 report ( https://www.physicsforums.com/showpost.php?p=3795578&postcount=12465 part 1, https://www.physicsforums.com/showpost.php?p=3796935&postcount=12485 part 2, https://www.physicsforums.com/showpost.php?p=3799356&postcount=12492 part 3)
23 April 2012 report: https://www.physicsforums.com/showthread.php?p=3939578#post3939578 (insertion and freezing mock-ups)
28 May 2012 government-Tokyo Electric mid and long term response committee, steering committee (6th meeting): https://www.physicsforums.com/showt...ighlight=alternative+thermometers#post3941037 Results of the surveys on location concerning the environment improvement for the purpose of installing alternative thermometers in unit 2's RPV
01 June 2012 videos:
http://photo.tepco.co.jp/en/date/2012/201206-e/120601_02e.html "Decontamination around the truck bay door at Unit 2, Fukushima Daiichi NPS" (released on 1 June 2012)
http://photo.tepco.co.jp/en/date/2012/201206-e/120601_01e.html "Mock-up test to check the insertability of the alternative thermometer at Unit 2" (released on 1 June 2012)
25 June 2012 Mid & long term meeting : Unit 2 alternative thermometer installation progress status: https://www.physicsforums.com/showpost.php?p=3984965&postcount=13523
12 July 2012: Checking SLC pipe integrity handout 1: http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120712_05-e.pdf
13 July 2012: Checking SLC pipe integrity handout 2: http://www.tepco.co.jp/en/nu/fukushima-np/images/handouts_120713_04-e.pdf
2) Translation:
01/11
02/11
03/11
  • #13,584
Translation:
04/11
05/11
06/11
  • #13,585
Translation:
07/11
08/11
09/11
  • #13,586
Translation:
10/11
11/11
  • #13,587
http://www3.nhk.or.jp/news/genpatsu-fukushima/20120807/index.html It was found by viewing the teleconference videos that on 12 March 2011 after the unit 1 explosion, late in the night an official said "disband !" and almost all high rank officials left the main office response center that was supposed to support Fukushima Daiichi during the accident. Tepco explained that although high rank officials had left, "technicians were remaining and were responding".http://ajw.asahi.com/article/0311disaster/fukushima/AJ201208070052 "The following scene, from March 14, 2011, highlights the difficulties between those at the plant trying to deal with the emergency and executives at TEPCO's Tokyo headquarters trying to provide advice"
http://ajw.asahi.com/article/0311disaster/fukushima/AJ201208070055 "TEPCO's edited video sheds little light on truth"
  • #13,588
Indeed, how rotten must this nuclear plant look inside now, if immediate photos after discovery already remind of scrap metals yard.
See here for images!
tsutsuji said:
Translation:
04/11
05/11
06/11
"The obstruction is inferred to be inside the RPV."
This is very interesting.
Let's remember how RPVsapparently fail.
Look at this (the sources are reputable, I hope) which I found here.
Let's say it in a very prosaic manner: they seem to p!ss, instead of sh!tting.
I mean, look at Swedish experiment still photo. Hottest and softest area first gets penetrated. It flows, it doesn't drop.
What if corium sploshing out of vessel warmed up pipe, making a (near) perfect weld in combination with containment overpressure?
(NUCENG, any idea?)
(BTW, tsutsuji, thank you again very much for translating this mega-interesting piece of information!)
  • #13,589
Those failures tests are on vessels with considerably less mass and wall thickness and a bone dry simulated RPV. It also doesn't have the myriad of protrusions that the normal RPV has. I'm not sure you can draw much from that test when looking at fukushima.
50K
  • · Replies 41 ·
  • · Replies 2K ·
60
471K
21K
  • · Replies 763 ·
284K
  • · Replies 38 ·
17K
12K
