Calculating the pH of an Acid-Water Mixture
  • Thread starter Thread starter Gregory.gags
    Mixture Ph
The discussion revolves around calculating the pH of an acid-water mixture, specifically examining how the addition of water to an acidic solution affects its pH. Participants explore the implications of dilution on pH, the logarithmic nature of pH, and the necessary calculations involved.
  • One participant questions whether the pH can simply be added together or if it requires calculating the hydrogen ion concentration.
  • Another participant explains that pH is defined by the equation pH = -log[H+], and notes that dilution will halve the concentration of H+, leading to a new pH that can be approximated by adding 0.3 to the original pH.
  • A different participant emphasizes that pH is a logarithmic function and that the initial concentration of H+ must be calculated, asserting that the pH after dilution would be approximately 4.3010.
  • One participant calculates a pH of 3.699 after substituting values, suggesting that dilution leads to a lower pH, which is contested by others.
  • Another participant clarifies that diluting an acidic solution increases the pH, and reiterates that the pH of the diluted solution should be higher than that of the original solution.
  • It is noted that the equations discussed are only applicable to acidic solutions, and assumptions made may not hold for neutral or basic solutions.
Participants express disagreement regarding the effect of dilution on pH, with some asserting that dilution increases pH while others suggest it decreases pH. The discussion remains unresolved as multiple competing views are presented.
Participants highlight that the assumptions made in calculations may depend on the pH level of the solution, particularly noting that the equations may not be accurate for pH levels above 6.
Gregory.gags
A flask contains 500 mL of an acid with a pH of 4. If 500 mL of water is added, what will the pH of the new solution be?
I don't want to know the answer please*
I'm just wondering if it is as easy as adding the two pH's ie. 7 + 4
or do I have to work out the H+ of each ie. 10-7 and 10-4 and then add, multiply or divide those. And why?
pH is defined by the following equation:
[itex]\large pH = -log[H^{+}][/itex]
It's not quite as simple as adding the pHs, but when you halve the concentration of H+ (by doubling the volume of the solution), the new pH (which we'll call pH2) is:
[itex]\large pH_{2} = -log\frac{[H^{+}]}{2}[/itex]
Which, by laws of logarithms, is equivalent to:
[itex]\large pH_{2} = -log([H^{+}])-log(2)[/itex]
Since log(2)=-0.301 (approximately), we can say:
[itex]\large pH_{2} ≈ pH_{1}+0.3[/itex]
where pH1 is the pH before the water was added.
pH is not a linear function you can go on adding, it is a logarithmic function. Its addition depends totally upon addition of [H+]
First, we have to calculate the initial concentration of H+. It is 10-4. Now, we diluted it with equal amount of water, so the concentration becomes half.
Note that water also consist [H+] = 10-7, but it can be neglected in front of [H+] of initial solution.
Now pH = -log10[H+]; [H+] = 5 x 10-5
pH comes out to be 4.3010
ok I got pH2=3.699 after substituting 10-4 for [H+] after working through that. This makes sense since the solution is diluted the pH would be less, no?
No No No... Diluting Acidic solution will increase the pH. See, pH is MINUS Log of concentration of H+. If we dilute the solution, the concentration decreases, its log decreases, but pH increases. (see negative sign).
Here we halved its concentration... So the pH increases. By calculating the -log of 10-4/2; we get 4.3010, not 3.699.
3.699 is the pH of the solution if you actually concentrate it. (eg. like boil the solution until half the initial volume remains).
Remember; Dilution increases pH in acidic solutions, decreases pH in basic solution.
With an H+ concentration of 10^-4, your pH1 (before addition of water) would be 4. When you add the water, you add 0.3 to the pH, making the new pH 4.3. The diluted pH is higher because water is neutral with a pH of 7, so unless the water causes a reaction, adding water will always bring the pH closer to 7.
I should mention that the equations I made will only work for an acidic solution. With a neutral or basic solution, the addition of water does not halve the H+ concentration as we assumed in the equations. The assumption we made is accurate to 2 significant figures for any pH below 6, and it's accurate to 4 sig figs below pH 5.
  • · Replies 16 ·
