Ram Speed vs. Latency: What Matters for Gaming PC Performance?
  • Thread starter Thread starter rollcast
    Ram Speed
The discussion revolves around the considerations for selecting RAM for a gaming PC, specifically focusing on the trade-offs between higher speeds and lower latency. Participants explore the relevance of these factors in real-world gaming performance versus theoretical benchmarks.
  • Some participants suggest that higher RAM speeds are more beneficial for gaming performance, while others emphasize that lower latency may not significantly impact real-world usage outside of benchmarking.
  • One participant argues that the graphics card is the primary determinant of gaming performance, suggesting that investing in a better GPU yields greater benefits than focusing on RAM specifications.
  • Another participant highlights the importance of ensuring RAM compatibility with the motherboard, including considerations for maximum capacity and data transfer rates.
  • A participant provides a method for calculating effective RAM performance by considering both latency and frequency, noting that motherboard and CPU limitations also play a crucial role.
Participants express differing opinions on the importance of RAM speed versus latency, with no consensus reached on which factor is more critical for gaming performance. The discussion remains unresolved regarding the best approach to RAM selection.
Some participants mention the variability in hardware performance based on system configuration and budget, as well as the changing landscape of hardware prices and availability.
rollcast
What should I be looking for if I'm buying ram for a gaming pc, higher speeds or lower latency or is it all just a bit academic and doesn't make that much real life difference apart from benchmarking?
Computer science news on Phys.org
My preference is higher speeds, I don't overclock my systems anymore so I don't really worry about having the best timings to get every point out of a benchmark. As you said outside of benchmarking, its hard to see any real difference in day to day use. Your GFX card is going to be the biggest decider on how good your games run, significantly more than RAM.
So if you have a choice, $50 more for tighter timings or higher frequency or $50 more on the video card, chances are the video card will give you better bang for buck
I recommend the Steam Hardware forums for anything gaming related.
Routaran is correct in my opinion. These days almost any decent quad core processor and 8gb of ram will do the trick and the real decision is what graphics card to buy and how to balance the system for whatever budget you have and games you prefer to play. That's why I recommend the Steam Hardware forums because the prices and quality on parts can change dramatically every few months and they tend to keep on top of such things and maintain a well moderated hardware forum.
You should look for when considering from RAM capacity side, maximum capacity your pc's motherboard support for one RAM slot on motherboard.Also there is a posibility that your pc's motherboard has more than 1 RAM slots.You have to install all RAM slots with the RAMs with the capacity for 1 RAM I explained earlier. Also each RAM should have highest data transfer rate which will compatible with your PC motherboard.If RAM's data transfer rate is lower than that you motherboard supports then you can not get the maximum performance.Because of that each RAM should have highest data transfer rate which will compatible with your PC motherboard.
you need to graphics card for gaming pc also.
rollcast said:
higher speeds or lower latency?
You can do the math yourself. Multiply the latency numbers by (1) / (frequency) to get the total cycle times. Also you're limited to what your motherboard / cpu allows for voltage, speed, and latency settings. In the case of LGA 1155 motherboard / cpus, the cpu's drive the memory bus and Intel processors like the 2600K limit the voltage to 1.5 volts (+/- 5%). Intel link:
http://www.intel.com/support/processors/sb/CS-029913.htm#4
  • · Replies 38 ·
  • · Replies 40 ·
10K
