Is it possible to theoretically determine a battery's amp-hour ratings?
  • Thread starter Thread starter BayAreaMech
The discussion centers on determining the amp-hour (A-hr) capacities of a lead-acid battery technology that is not yet released. While one participant believes that empirical testing is necessary, another suggests that theoretical calculations can be made based on the overall capacity rating at the 100-hour rate. Key concepts include the relationship between amp-hours and coulombs, as well as the non-linear nature of battery reactions as they approach equilibrium. Understanding these principles is crucial for accurately estimating battery performance metrics.
  • Understanding of lead-acid battery chemistry
  • Familiarity with amp-hour and coulomb calculations
  • Knowledge of battery discharge rates and their implications
  • Concept of chemical equilibrium in battery reactions
  • Research methods for calculating theoretical amp-hour ratings for batteries
  • Study the impact of discharge rates on lead-acid battery performance
  • Explore the principles of chemical reactions in electrochemistry
  • Investigate the effects of equilibrium on battery efficiency and capacity
Battery engineers, electrochemists, and researchers involved in battery technology development will benefit from this discussion, particularly those focused on theoretical modeling and performance estimation of lead-acid batteries.
BayAreaMech
I have been asked to determine the Amp-Hour capacities of a competing battery technology that is not yet released. I'm a bit stumped. I didn't think this was possible. I always thought this was a calculation that had to be determined empirically, but a coworker is insistent that it can be done. Does anyone know how you would take an overall capacity rating (in A-hr, assumed to be the 100-hr rate) and determine the 10hr, 5hr, etc rates? Is this even possible?
Edit: I should note that this is a lead acid battery under investigation.
Chemistry news on Phys.org
I don't see why not. An amp hour is equal to one amp of current for an hour (I think?). An amp is one coulomb per second, so we would need 3600 coulombs of electrons. A coulomb is equivalent to 6.2410^18 electrons.
Assuming we know the chemical reaction that occurs, we could calculate the mass of material required, or vice versa.
That being said, battery reactions are not linear, and it will get much more complicated, because the rate of reaction will decrease as it gets closer to equilibrium.
  • · Replies 28 ·
  • · Replies 23 ·
  • · Replies 26 ·
  • · Replies 19 ·
11K
11K
9K
