Finding power needed to heat an oven through radiation and conduction
The discussion revolves around estimating the current needed to heat a Tungsten wire in a multi-layered oven setup to a temperature of 900°C. Participants explore the contributions of thermal radiation and conduction in the heat transfer process, as well as the complexities involved in calculating the required power and current.
  • One participant describes the oven's structure and seeks help in estimating the current needed to reach 900°C, noting the importance of heat transfer mechanisms.
  • Another participant suggests that knowing the heat conductivity and capacity of the components is essential for evaluation, and mentions that the resistance of the Tungsten wire changes with temperature.
  • A different participant raises the possibility of needing a feedback control system for accurate temperature management.
  • One participant expresses confusion about calculating thermal radiation and conduction, emphasizing the need for an estimate of current supply while planning to use a PID temperature controller.
  • Another participant highlights that the required current will depend on the time available to heat the setup, indicating that maintaining temperature may require less current than initially heating it.
  • A participant provides a formula for calculating heat flow through materials and suggests that the thermal conductivity of the ceramic cylinders is crucial for estimates.
  • One participant shares their approach of treating the system as one with added heat resistances and presents a calculated energy transfer result of 120 Watts, seeking guidance on how to use this to find the necessary current.
  • Another participant reiterates the relationship between power, voltage, and current in the Tungsten wire, emphasizing the need for resistance to calculate the required current and voltage.
Participants express various views on the factors influencing the current needed, with no consensus reached on a specific method or final estimate for the current supply. There is acknowledgment of the complexity involved in the calculations and the need for further refinement.
Participants note the dependence on specific material properties, such as thermal conductivity, and the unresolved nature of the calculations regarding heat transfer through multiple layers. The discussion reflects uncertainty regarding the exact relationships and values needed for accurate estimations.
swilly
I was given an oven that comprises of several cylinders that fit inside one another. The innermost cylinder is a Molybdenum oven that will hold a sample of metal. A ceramic cylinder fits over this. A tungsten wire heating element is wrapped around this cylinder. Two more ceramic cylinders fit around this, and then lastly a Molybdenum shield. I am going to be raising the temperature of the Tungsten wire to 900°C. My question is this: how can I estimate how much current to run through the Tungsten wire to reach 900°C?
I know that P=I^2R. I know the resistance of the Tungsten wire. The total power needed is going to equal the sum of the heat transfers (I think?). There is heat transfer by thermal radiation and thermal conduction. I have included a picture of the oven for reference. (Note that in the picture, the wire is not wrapped around the ceramic with threads). Please help me!
Science news on Phys.org
If you know heat conductivity and capacity of all of your components, it is possible to evaluate that. The current will not be constant, as heat loss depends on the temperature of the surrounding material.
Another idea: The resistance of the tungsten wire depends on the temperature. Assuming that the temperature is the same in the whole wire: if you measure voltage and current, you can calculate the resistance and use this as thermometer.
You might need a feedback control. That sort of thing isn't very easy to get accurate. The folks in the mechanical engineering forum might know more about how to solve the thermal resistances.
So, as it heats up, I will need less and less current?
Basically, I'm just trying to estimate the current required to keep the sample of metal at the center at 900 deg C. I'm confused on how I calculate thermal radiation and conductivity. I realize that every part of the system is going emit thermal radiation, and that there's going to be conduction through several layers...
I believe we will be purchasing a PID temperature controller that can control the current, but I wanted an idea of what kind of current supply we would need.
Without any numbers, it is hard to tell. I would guess that conductivity of the ceramic cylinders is the most important part.
Right.
Depends on the time you have to heat the whole setup. The current required to keep the whole system warm should be small compared to the current required to heat it up quickly (i.e. with tungsten at constant 900°C).
The ceramic cylinders are made of Alumina, so I can find the conductivity. I have a lot of time to heat it up. Can anyone help me with the math to estimate the current?
A sheet of material with thermal conductivity [itex]\sigma[/itex], area A, thickness x and temperature difference [itex]\Delta T[/itex] between both sides will have an internal flow of [itex]P=\frac{\sigmaA\Delta T}{x}[/itex]. For cylinders, you need an integration to get an exact formula, but if the radius is large compared to x the difference is negligible.
Multiple materials can be treated with an equation system, or by adding their "heat resistance" (inverse value of the conductivity).
You could try to find the thermal conductivity of your ceramic cylinders and their thickness, this would help to get a rough estimate.
Okay, so I treated it as a system and added the heat resistances, or R-values:
[itex]\dot{Q}[/itex] = [itex]\frac{1173K-Tb}{Rtotal}[/itex]
I calculated Rtotal by adding the R-values for the conductive layers with the R-value for radiation (radiation from the outside of the oven to the walls of the vacuum).
I used Mathematica to solve the Temperature of the outside of the oven (which came out as 798°C), which I then plugged into the original equation to find [itex]\dot{Q}[/itex] . My end result was 120 Watts of energy transfer by heat.
How can I use this result to find the current I need to run through the Tungsten wire?
The power in the Tungsten wire is P = V I = R I2 = V2/R
You need the resistance to calculate required current and voltage.
  • · Replies 17 ·
  • · Replies 16 ·
15K
  • · Replies 23 ·
