Drawing Vector Diagrams from Point Data
The discussion revolves around the creation of vector diagrams from a set of point data, specifically focusing on how to visualize vectors defined by their x and y components at various coordinates. Participants explore different software options and coding approaches to achieve this visualization, including Excel, Mathematica, and Python.
  • Homework-related
  • One participant seeks software to create vector diagrams from multiple points, providing an example of the data format needed.
  • Another participant suggests using Excel for plotting the vectors, questioning the sufficiency of the provided data.
  • A participant shares a Mathematica implementation for generating vector diagrams, emphasizing the need for careful verification of the code.
  • Python is proposed as another viable option for creating vector diagrams, with a specific example using the pylab module.
  • Concerns are raised about the original poster's lack of experience with Python and other software, suggesting that learning is necessary to implement the provided solutions.
  • Participants discuss the need for specific data files required for the Python implementation and the potential issues with data formatting in Excel.
  • One participant expresses gratitude for assistance received and mentions successfully creating the diagram, while also inquiring about resources for learning Python.
Participants generally agree on the need for software to visualize vector data, but there are multiple competing views regarding the best tools and methods to use. The discussion remains unresolved regarding which software is most suitable for the original poster's needs.
Some participants express uncertainty about the completeness of the data provided for plotting vectors, and there are mentions of potential formatting issues when transferring data between applications. The discussion reflects varying levels of familiarity with the suggested software and coding languages.
This discussion may be useful for individuals looking to create vector diagrams from point data, particularly those interested in using software like Excel, Mathematica, or Python for visualization in scientific or engineering contexts.
niloy112
Do anyone have any software by which i can make a vector diagram from a group of points.you can think it like..suppose you have x & y component of a vector at a point..you can draw that easily but i will have to draw a vector diagram for 100 or more points arranged on a surface...i will give the co-ordinate(x,y) of that points and x&y component values of vectors which works at the respective points..as an example...
x y Vx VY
0 0 2 3
1 0 5 1
2 0 3 3
It is urgent
You've really never heard of Excel?
Thank you "Angry Citizen" for your prompt reply.It will be very helpful for me if you show me the way for 2 or 3 points in excel...Thanks
Post your 100 or so starting and ending points and what kind of output file format you need.
Thank you Mr. Bill Simpson for your reply. I am attaching files for your consideration. i am wanting this type of figure.
Thank you for your reply.
  • Vector diagram.xls
    Vector diagram.xls
I don't think the exel file has enough information to plot what you want...you talked about x,y,Vx,Vy...and all I see is x,y,z
I am guessing about a few things, but here is a quick and dirty Mathematica implementation.
In[1]:= v=Import["Vector Diagram.xls"];
In[2]:= vv=Map[Drop[#,1]&,Drop[v,5]]; (*discard "labels"*)
In[3]:= g=Show[Graphics[Reap[
For[y=5/2,y≥0,y-=1/10,
For[x=0,x≤5,x+=1/2,
mx=2x+1;my=10(5/2-y)+1; (*create suitable subscripts*)
Sow[Line[{{x,y},{x+1/15Cos[vv[[my,mx]]Degree],y+1/15Sin[vv[[my,mx]]Degree]}}]];
Sow[Point[{x+1/15Cos[vv[[my,mx]]Degree],y+1/15Sin[vv[[my,mx]]Degree]}]]
][[2,1]]]]
In[4]:= Export["vectors.gif",g,ImageResolution->300]
Check this carefully before you depend on it
Thanks gsl for your reply. I am giving you the x and y component of the vec
Thank you Mr. Bill Simpson for your reply. Please give a favor about one thing. i will use your coding in which software?
Thank you.
Mathcad is another application that will do what you want.
According to your latest excel file where you include separate component for x,y velocity...this is what I get, using python and the pylab module
Code:
from pylab import *
X,Y = meshgrid(arange(0,5.5,0.5), arange(0,2.6,0.1))
U = genfromtxt("vectors-U.txt", dtype=float, delimiter='\t')
V = genfromtxt("vectors-V.txt", dtype=float, delimiter='\t')
figure()
Q = quiver(X,Y,U,V,pivot='mid',color='red',scale=300)
plot(X,Y,'k.')
axis([-1.0,6.0,-0.5,3.0])
title('Velocity')
show()
Thank you everyone for their cordial help.
One thing more "gsal" your given picture is my required one.
But the problem is i have never used python before.If i use your code on this software after installing will it be ok?
Thanks
niloy112 said: "the problem is that I have never used python before"
...I think we all figured that was going to be the problem...not matter whether the solution was given to you in Mathematica, Mathcad, Matlab, Octave, FreeMat, SciLab, etc...do you know any of these?
...so, one way or another, you are going to have to learn something...
As far as your question about using the code after installing the software "will it be o.k.?" I am not sure whether you are asking for permission or asking whether it will work or not...Of course you have permission to use the code and I am sure it will run o.k., too...just make sure you install the pylab module, too.
Thank you "gsal" for your reply. I need one more favor from you that is " Can you please give me the file named 'vectors-U.txt' and 'vectors-V.txt' which you used on your pylab module". Actually i have started to learn PYTHON that is why i am facing problems.
Hoping to get reply from you.
I am not at the computer where I have the files; but, I just simply copied the data from the excel file that you posted into two separate files, one for the x component and another for the y component of velocity...no x-heading row and no y-column, though, just data; the x and y values for the grid I put it together in the python file, as you can see.
By the way, when you pasted the data into excel, you must have messed it a bit...
Dear 'gsal' thank you for your help. I have finally managed to make diagram. Full credit goes to you. I can use now these type of figure on my paper. Again thank you for helping me.One thing more is there any manuel or user file for python user like fortran or C?
Of course there is a manual for python...there are plenty. There is a lot of documentation for Python; depending on what distribution you install, it may come with some docs installed locally...otherwise, you can simply consult the on-line manuals.
There are also many books for python and even free ones like Dive into Python.
Python has come a long way on its own merits and is very big within the scientific and engineering community. It is also becoming the scripting language of choice (for scripts, macros, etc) in other applications whether they are free/open-source and even commercial ones.
Learning python is going to be one the best you will ever do for yourself. :-) Keep it up.
