PeterDonis
Mentor
- 50,218
- 26,286
Vandam said:Scrap all those ambiguous words. Easy cake. Talk about simultaneity, not the 'sense' of simultaneity. Moving trains are shorter, not 'appear' shorter, and definitely not 'seems' to get shorter (for reasons explained in my post).
I see the advantages of this approach, but you still have to be careful not to draw unwarranted deductions from it. As with:
Vandam said:Face what Einstein found out and accept the consequences: block universe, even if you feel uncomfortable with the consequences (such as free will).
And as I and others have argued in a number of threads by now, SR does *not* imply hard determinism! So if the language you suggest is going to make people believe that it does, then that, IMO, is a big disadvantage in your proposal.
Vandam said:I know that most people refuse to take that step.
Because it's not logically justified. SR is *consistent* with hard determinism, but it does not *require* hard determinism.
Perhaps it's worth expanding on this. SR, if we consider it as an exact theory, is *wrong*. Spacetime is not globally flat; it's curved. SR is an *approximate* theory that works OK in cases where spacetime curvature can be neglected. There are many such cases.
GR is a more comprehensive theory which includes SR as a special case; and one could argue that GR, if it were an exact theory, would imply hard determinism. But GR includes something crucial that SR does not: dynamics. SR, in itself, has no dynamics; it's all kinematics. You have to *add* some dynamics to SR for it to actually make physical predictions. GR, all by itself, can give you dynamics in any case where gravity is the only significant factor involved. Again, there are many such cases. So even if GR would imply hard determinism if it were exactly right, SR can't, because hard determinism is a claim about dynamics, not just kinematics.
But GR, as an exact theory, is also wrong; it predicts infinite spacetime curvature in certain cases, such as the r = 0 singularity of a black hole or the initial singularity in an FRW spacetime. Infinite spacetime curvature is not physically reasonable, so GR as a theory can't be exactly right. So even if GR would imply hard determinism if it were exactly right, that's irrelevant, because it's not.
