Calculate new water height in container after adding floating object
The discussion focuses on calculating the new fluid height in a container after adding a floating object, specifically addressing buoyancy principles. The key formula derived is hwith object = (Vsolid/Aliquid) + hstart, where Vsolid is the volume of the solid and Aliquid is the surface area of the fluid. The conversation clarifies that a floating solid displaces its own weight in fluid, and the percentage of the solid submerged correlates to the density difference between the solid and the fluid. The confusion arises when the surface area of the water is nearly equal to that of the solid, leading to a need for a combined formula to determine the fluid height accurately.
  • Understanding of buoyancy principles and Archimedes' principle
  • Knowledge of fluid dynamics and density calculations
  • Familiarity with basic geometry for volume and surface area calculations
  • Ability to interpret physical principles in mathematical terms
  • Research the relationship between density and buoyancy in floating objects
  • Learn how to apply Archimedes' principle in various fluid scenarios
  • Explore the mathematical derivation of fluid displacement formulas
  • Investigate real-world applications of buoyancy in engineering and design
Students and professionals in physics, engineering, and fluid mechanics, as well as anyone interested in understanding buoyancy and fluid displacement calculations.
AmoLago
Hi all,
I've been looking at some buoyancy problems and one continues to vex me, how to calculate the new fluid height within a container after a floating solid is added to it.
I understand that for a completely submerged solid Archimedes comes into play, volume of the solid equals volume of the displaced fluid. Volume of the fluid divided by the surface area of the fluid in the container added to the original fluid height gives me the new fluid height... hwith object = (Vsolid/Aliquid)+hstart ...easy.
Searching around I find that a floating solid displaces it's own weight in fluid. This sounds great, however, I also find that the percent of the solid submerged is equal to the difference between the fluid density and the solid density. So I understand that and object with average density of 0.4g/cm3 will have 40% of it's body submerged in water.
But, what I don't get is that in the case of the water surface area in the container being very close to the surface area of the solid, only one of the above can be true. Either it displaces it's weight in fluid and sinks below the surface, or it remains partially submerged and it doesn't replace it's own weight in fluid.
So I assume there must be a formula to combine the two to work out how high the the fluid will be. Could someone please tell me what it is, or at least tell me what I've misunderstood?
I've attached a picture to help demonstrate what I'm on about.
Cheers
Amo
I think you misunderstand what's meant by displacement here.
The 'displaced' volume is exactly the volume of solid that's below the (final) waterline. If a rectangular block of density 40% that of water floats level, 40% of it will be submerged.
Btw, you've connected Archimedes with the wrong principle. That the submerged volume is the displaced volume would have been obvious. What Archimedes realized is that the buoyancy (upward force) is equal to the weight of the displaced fluid - and that is true whether or not the object floats.
  • · Replies 40 ·
11K
